02-05-2013, 10:48 AM
#15946 |
Oddometer: 1,381
Yea, but you're making the Yammer and the Suzy? look bad!
Nice work.
Tour of Idaho T1 Challenge - On Dual Sported XR650R's: Coming Summer 2013 Eat. Sleep. Ride - The Great Divide: http://advrider.com/forums/showthrea...4#post19193704 Go, Get Lost - Heading South: http://advrider.com/forums/showthread.php?t=735690 Dirt Donkeys Do Baja: http://advrider.com/forums/showthread.php?t=671095 |
02-05-2013, 12:23 PM
#15947 |
Wheee!
Oddometer: 21
Spring Rates...lol
I know this is beating a dead horse,but I need some opinions on what spring rates to use. I weigh 185 i'm 6'5" and I plan on packing some lightweight things in my coyote saddle bags... I have stock springs in there, and I want to do all the Borynack fork mods, with the shim stacks etc. I'm just torn on what spring rates to use. Should I spring it for the added weight of my gear(40-60lbs?) and oversized tank(4.3)? I was thinking of going with .45 in the front and 10.5 or 10.2 in the back?
Any help appreciated!
02-05-2013, 01:04 PM
#15948 | |
Oddometer: 1,381
Now... it's been awhile, but I THINK i have a 10.5 in my rear and I used to weigh as much as you... No idea where I got the extra 15lbs recently... Either way, I think the rear is a bit low. I'd probably go 11 or 11.5 now with the matching front springs. I have a Acerbis 6.3, Race light, and carry 40-70lbs of luggage semi regularily. I weight 200, 6'4" + gear For the front, you can play around with with a spacer / cut spring till you know. Once again, my suspension never or rarely bottoms, but it's a bit too soft for my liking and when I load her up with fuel and lugage it's sagging more then I want. It still rides quite well though. I need to play around with it more but i"m looking for a big boy rear spring and forks springs though. With that said, size your weight, your gear, half to 3/4 of your fuel, and consider luggage weight. Then base your decision on this. If you want a 10.5 I think I have an extra one in my garage.
02-05-2013, 01:51 PM
#15949 | |
Wheee!
Oddometer: 21
![]() How much you want for that 10.5? |
02-05-2013, 01:52 PM
#15950 | |
Oddometer: 39
They have an application that gives you an idea of what spring rates you need.
RJ Nelson '09 R1200GSA 01' XR650R |
02-05-2013, 01:55 PM
#15951 |
Wheee!
Oddometer: 21
Borynack states that those spring rates are based on a computer program that calculates the rates for use on a MX track. AKA stiffer than needed for normal riding. Maybe that's what i need though?
02-06-2013, 10:45 AM
#15952 |
Oddometer: 44
I am sorry. I do not know where to place. Russian song about MX.
http://www.youtube.com/watch?feature...&v=YHZd5v192Mc |
02-06-2013, 04:47 PM
#15953 |
I've got bike ADD
Oddometer: 1,067
I replaced my counter sprocket with a 15T tonite. I didn't notice if the stock one had any slop in it, but the new one does. Not "in and out" but a tiny bit of "side to side" slop. I can always put the original one back on and check, but I know plenty of you all's have done it already. Normal, right?
02-06-2013, 05:00 PM
#15954 |
Oddometer: 1,381
It can, and does cause wear on the shaft.
I'd look for a tighter one. Saying this from experience and seeing signs of some slight wearing on mine. (I'm assuming you mean wiggle on the shaft. As in the splines aren't perfectly matching)
02-06-2013, 05:07 PM
#15955 |
I've got bike ADD
Oddometer: 1,067
Exactly, wiggle is the word I was looking for. it's a new Moose steel unit. The splines on the shaft are not worn, I'll pop it back off tomorrow and compare to the original one.
02-06-2013, 08:18 PM
#15956 | |
Oddometer: 187
Give Diane a call. She's real knowledgeable and can answer any questions you may have. PC definitely knows XR's.
2003 DL1000 2003 XR650R 2006 GSXR600 |
02-06-2013, 08:22 PM
#15957 |
Oddometer: 187
Here's my setup sheet.
![]() Invoice:
02-06-2013, 09:06 PM
#15958 | |
Wheee!
Oddometer: 21
It really helps to get a look at the receipt, I was gonna do the shim stacks/ drill out the compression valve myself,but sending it out could be an option
02-06-2013, 09:23 PM
#15959 |
Half Man Half BRP
Oddometer: 271
A similar overhaul here in Australia is more like $1200+ and that ain't by someone as well known as PC. You guys get some good prices on bikes and services in the US!
My Blogs: http://xr650r.blogspot.com.au/ http://dirttbikediaries.blogspot.com.au/ |
02-06-2013, 09:29 PM
#15960 |
Wheee!
Oddometer: 21
