Old 02-07-2013, 10:55 PM   #15976
lstzephyr
Solo con rambo
lstzephyr's Avatar
Oddometer: 1,711
Send a message via AIM to lstzephyr
If you are planning on using stock throttle cables I'm betting you will need a stock throttle too. The cables thread into the stock throttle housing.
lstzephyr is offline   Reply With Quote
Old 02-08-2013, 07:16 AM   #15977
Shibby!
Oddometer: 1,382
Originally Posted by FlyGuy View Post
Just to let people know my experience with intake valves I switched to the Kibbles black diamond valves and with near 12,000 miles (19,000 kmi) I have only checked clearance one time and have yet needed an adjustment, Prior to that with stock valves it required adjustment roughly every 3,000 mi or when it started backfiring and dying at idle
The Kibbles have what looks like a nitride coating and that may wear out eventually causing accelerated wear, but so far they are great. I would recommend them.
This somewhat discredits the poor air filter theory.
I use a stainless screen type filter, 35 micron I am very happy with it. MSR has them for very reasonable pricing, They are reusable and filter well
I also recommend the magnetic drain plugs for the case and down tube, It makes it easy to identify potential problems with some experience.
If you run the magnetic drain plugs I believe you can see the wear from the buildup of magnetic particles.
from my not too scientific experience I found 1,500 (2500 Kmi) road miles to be a good point to change Oil at, If I run farther I see an acceleration of particles on the magnets.
I run Rotella T6
I hope you keep your 650r going, I plan on riding mine for a few more years of fun.
KTM Orange??? Really!??
Those are good points. If I did rebuild this engine I would most deifnitely use Kibbles valves. They aren't cheap, but rarely anything good are. I'm at a cross roads of decided to rebuild mine over the next two years, or keep an eye out for another clean one. I think for now I'll wait. Most non-street used ones around here have very little K.
I was hoping to get the magnetic drain bolts, but at the time of my trip they were back-ordered and it would have held up my shipment on other parts. My next bike will have at least one of those in addition to the oil temp stick.
Thanks for bringing that up.
Tour of Idaho T1 Challenge - On Dual Sported XR650R's: Coming Summer 2013
Eat. Sleep. Ride - The Great Divide: http://advrider.com/forums/showthrea...4#post19193704
Go, Get Lost - Heading South: http://advrider.com/forums/showthread.php?t=735690
Dirt Donkeys Do Baja: http://advrider.com/forums/showthread.php?t=671095
Shibby! is offline   Reply With Quote
Old 02-08-2013, 07:49 AM   #15978
RideFreak
Torque Junkie
RideFreak's Avatar
Oddometer: 3,556
Originally Posted by AirCommando View Post
Thanks for the info. Any recommendations on where to attach the choke cable?
Chris
VIDEOS
RideFreak is offline   Reply With Quote
Old 02-08-2013, 10:10 AM   #15979
Shibby!
Oddometer: 1,382
If you have a 6.3 you won't need an extension. The tank provides reasonable access to the TM-40.
Otherwise the above look nice and clean.
Old 02-08-2013, 10:22 AM   #15980
Oddfellow
Beasty Rider
Oddfellow's Avatar
Oddometer: 368
Originally Posted by Cpt. Ron View Post
Dumb question here. My bike came with an Edelbrock and a Motion Pro throttle housing that goes with it. Looks like this:
I'm going to try out my new-to-me stock carb and am wondering if I need to buy an OEM throttle housing/throttle tube, or one like this:
Anybody know the answer?
My bike came with an Edelbrock. When I couldn't rebuild it I switched to a TM-40 and found out that the Edelbrock throttle was proprietary. I ended up buying a stock assembly with cables off of Fleabay and it worked fine for my TM-40.
Oddfellow
'02 BMW R1150 GS Adventure (Beasty)
'05 Honda XR650R (Mr. Bill)
'06 Honda Ridgeline RTL
Oddfellow is offline   Reply With Quote
Old 02-08-2013, 03:10 PM   #15981
kjazz
Oddometer: 200
Side Panel Riv-nut size....
Can someone tell me what size Riv-nut I should purchase to replace the one in the sub frame which hold the right side panel on please??
I've got the tool to properly set another, cannot find something that specifies the nut's size/dimension etc.
kjazz is offline   Reply With Quote
Old 02-09-2013, 07:53 AM   #15982
duckfart
Oddometer: 16
Does any one run a rear rack? i have been looking at the rear rack made by manracks. Does any one have any input on this brand. Good- Bad any input would be great....
duckfart is offline   Reply With Quote
Old 02-09-2013, 08:27 AM   #15983
bill pierce
I don't wana pickle
bill pierce's Avatar
Oddometer: 688
The one for the side panel is 6mm x 1.0 thread pitch
bikes
BMW R1100s,destroyed by deer strike.
Yamaha FZR 1000 (sold)
Honda Cr 500 sold
bill pierce is offline   Reply With Quote
Old 02-09-2013, 11:48 AM   #15984
K75STER
Oddometer: 279
XRR Questions
I'm arriving to the XR650R party a little late, but better late than never
I got it last year & did a few things-BD stator rewind, H4 bulb, fuse panel, GPR stabilizer that came with rebuilt, side panel airbox mod, manrack under fender rear support,it came with a Clarke 4.3 and just swapped that out for a Sahara with the tankerbrace.
Got a couple questions for those in the know-
With the bigger tank, anyone using that tank foam stuff?
How do you try to seal the airbox side panel? Intake is quite a bit lower than my XR400
Chain-don't need one yet but when I do-Rivit or master? If rivit what tool do people like for that?
I got a case saver and a case of the Dumbasses! Can't seem to attach it with what came with it-
Looks like it might work if rear mount bolt and nut were removed and flipped 180 and not use the nut-Is this correct?
Trying to set it up the way I want, was going to do LAB2V with it last year but it didn't work out. Now I'd eventually like to do Baja on it, we'll see.
Lov'in the bike so far.....
K75STER is offline   Reply With Quote
Old 02-09-2013, 12:19 PM   #15985
hontri
Global Bummer!
hontri's Avatar
Oddometer: 266
I have the IMS 7 gallon tank and see no reason to add the foam.No problem with sloshing at all.It is just something else to break down and plug the filter imo
As for the air box i use a heavy grease to seal around the edge.
I use master links on my XRR's both ADV and super moto. Never had a problem.On my KTM 990 with rivet links i use this tool. It is small and works awesome. http://terra-x.com.au/chainbreaker/
Your right on the case saver
Great bike your gonna love it!
hontri is offline   Reply With Quote
Old 02-09-2013, 12:21 PM   #15986
Buell78753
AKA DoctorXRR
Buell78753's Avatar
Oddometer: 645
Manracks
Fartduck, I have the Manrack for my XR650R and very happy with it. I like it because its not too huge, and wont be tempted to overload it. I had mine powder coated red. It comes with a support under it that bolts to the subframe too. Overall very nice and I recommend it.
My XR650R Build:
http://ridedualsport.com/forum/index.php?topic=2748.0
Buell78753 is offline   Reply With Quote
Old 02-09-2013, 01:18 PM   #15987
Shibby!
Oddometer: 1,382
That chain guide/guard should just bolt to your case. You might have to take the primary off and put them both on the same time with chain in place. Keep in mind some are designed for certain sprockets so a larger then intended sprocket won't allow the guide to fit.
No need for fuel foam. You won't notice it.
I use clip links too. Easier to fix in the field with basic tools. Never had one fail. Rivets are nice, but have their issues too. Just make sure the closed end of the clip is going in the direction of chain. And keep an eye on wearing of the clip.
Old 02-09-2013, 01:53 PM   #15988
K75STER
Oddometer: 279
Great bike your gonna love it![/QUOTE]
Cool- Thanks for the answers!
I'm good with the ML, just wondered cause it has riveted on now.
Man I was all twisted up about that case saver, makes sense now. It fits around the CS I have now, the gold double threaded spacer was throwing me off. That's kinda what I thought of the foam too. No foam is good foam!
Old 02-09-2013, 02:32 PM   #15989
Desert Scoundrel
Oddometer: 181
That gold "double threaded nut" replaces the upper rear motor mount nut on the left side. It is a spacer. You thread it on in place of the stock nut and then the counter sink allen head bolt threads into it. You will have to turn the motor mount bolt around so that the nut is on the left and not the right like it is in your picture. The other 2 bolts thread into the case where the stock "case saver" was.
Desert Scoundrel is offline   Reply With Quote
Old 02-09-2013, 03:36 PM   #15990
galland1
galland1's Avatar
Oddometer: 78
Yes flip the bolt. The gold part is the new nut. Take off the old case saver.
Sent from my Galaxy Nexus using Tapatalk 2
galland1 is offline   Reply With Quote
Times are GMT -7.   It's 11:13 PM.
