Old 03-19-2013, 02:12 PM   #16516
slickwill
Exhiled
Oddometer: 209
Originally Posted by crypto666 View Post
After breaking a chain and rebuilding the engine I use:
DID 520ZVM2 X-Ring 520
I'm pretty sure that's what I have on mine.
Sent from my DROIDX using Tapatalk 2
slickwill is offline   Reply With Quote
Old 03-19-2013, 02:21 PM   #16517
achile
achile's Avatar
Oddometer: 289
my next chain kit:
- honda transalp front sprocket
- ktm 990 adventure rear(with some special farkles)
- 525 DID ZVM
- automatic chain oiler
achile is offline   Reply With Quote
Old 03-19-2013, 02:32 PM   #16518
ZXRaziel
ZXRaziel's Avatar
Location: Grey skyes and rain of Good old England ( NEast)
Oddometer: 495
The best chain i have managed to find for the XR is D.I.D 520ZVMX-110 Gold Extreme cost me over here 100 ( about 150 $ ) The updated Sunstar o-ring chain is very good too ( othervise honda would never use them as OEM for the pig ) and RK chains are very good also and slightly cheaper than D.I.D .
Go with the best you can find all the well known makers are making strong chains in this day and age , not worth it to save few dollars and end up paying thousands for the repair , also good chain will last you long time if cared for .
good things them hondas
ZXRaziel is offline   Reply With Quote
Old 03-19-2013, 02:39 PM   #16519
crypto666
Oddometer: 1,276
Originally Posted by achile View Post
my next chain kit:
- 525 DID ZVM
If you are running an o-ring chain, forget the oiler, it will only make a mess. IN fact, I wonder why I even oil my o-ring chain other than to keep the o-rings squishy. If the o-rings are working, they will keep oil from getting to the parts that need it, correct?
crypto666 is offline   Reply With Quote
Old 03-19-2013, 02:49 PM   #16520
achile
achile's Avatar
Oddometer: 289
I opened up link from x-ring chain when I shortened it. I was running a DIY chain oiler. The interior had nice, clean oil. The oil will also keep the chain clean. It's not messy if you have it properly tuned.
The o-rings and x-rings have to be lubed and cleaned, but no more. This is a picture made after running an oiler on the street for 3000 km whitout maintanance. It's on a Yamaha XTZ 750. For offroad use, it's a bit tricky to install the oiler in a safe position
Old 03-19-2013, 03:04 PM   #16521
ZXRaziel
ZXRaziel's Avatar
Oddometer: 495
Originally Posted by galland1 View Post
RK lists the Latest iteration of 520xso at 8500# Before I started using RK I used DID VM2 Not sure what they call it now.
Sent from my Galaxy Nexus using Tapatalk 2
DID ZVMX tensile strenght 8745 , not huge difference both good chains .
Old 03-19-2013, 06:51 PM   #16522
mitchn06
mitchn06's Avatar
Oddometer: 547
can a guy use a high grade 20x1.5 bolt as a makeshift flywheel puller, instead of the Motion Pro one, that i may not be able to get for a few days
2000 Honda XR650R (Sold) LINK
2014.5 Kawasaki KLR650 NE
mitchn06 is offline   Reply With Quote
Old 03-19-2013, 09:32 PM   #16523
DocAxeYarYar
RideDualSport.com
DocAxeYarYar's Avatar
Oddometer: 784
ADV Ready - CDT, Rio Grande Gorge, White Peak
Here is a mock up of my XR650R outfitted for long distance riding. *This June me and a small crew are embarking on a roughly 1,200-1,500 mile adventure using Dell City Texas as start/finish. Joining up on the CDT, turning around at CO, dipping down the Rio Grande Gorge, cutting across to White Peak, then south through numerous national forests.
I was looking for some more budget priced luggage alternatives and came down on running Wolfman E12 bags, a dry bag on the ManRack, and a Giant Loop Buck and Roll tank bag. The ManRack is on the smaller side, which I got so I dont get tempted to over-load if I used a larger rack. I like that the Wolfman bags dont need any additional brackets or supports. I am running the GL heat shield also.
I am going to be ruthless about packing light (much lighter than my last TAT and other adventures on my DR650). The crew can also spread the load on things like tools, tubes, cooking gear, and other items we can share. I hope to end up with a smaller dry bag on the back, so I can have plenty of room get my weight back when needed.
The XR also sports a steel sub-frame just for added peace of mind when carrying a load.
Also, I highly recommend Ironman Dual Sport for your luggage and bike needs. Great quick service from a local business.
http://www.ironmandualsport.com/Home_Page.php
My XR650R Build:
http://ridedualsport.com/forum/index.php?topic=2748.0
DocAxeYarYar is offline   Reply With Quote
Old 03-20-2013, 12:21 AM   #16524
poppy
Slow and Steady
poppy's Avatar
Oddometer: 2,310
yes you can.
poppy screwed with this post 03-20-2013 at 01:48 AM
poppy is offline   Reply With Quote
Old 03-20-2013, 05:03 AM   #16525
BuRPsa
Finally growing up..
BuRPsa's Avatar
Oddometer: 548
Buell,
that strap holding the bag tied around the frame will probably melt due to exhaust heat. Mine did (GL), had to make a bracket for this.
BuRPsa is offline   Reply With Quote
Old 03-20-2013, 05:20 AM   #16526
mitchn06
mitchn06's Avatar
Oddometer: 547
Originally Posted by poppy View Post
yes you can.
Nice, did you use an impact, or hold the flywheel with something? I've read that you can demagnetize the flywheel somehow.
Old 03-20-2013, 05:53 AM   #16527
DocAxeYarYar
RideDualSport.com
Oddometer: 784
Strap heat
Originally Posted by BuRPsa View Post
Buell,
Thanks for the heads up! I will look into some other solution!
My XR650R Build:
Old 03-20-2013, 06:35 AM   #16528
slickwill
Exhiled
Oddometer: 209
I've used an impact both times that I've done it. Very slick.
Old 03-20-2013, 06:40 AM   #16529
Shibby!
Oddometer: 1,657
Buell,
All depends how you tie it. Mine hasn't and it's got lots, and lots of K on it with the ultra thin Powerbomb header.
As for chain talk, the XRR has seen a few primary drive chains, but the one that broke? The RK X-ring.
Thankfully it didn't pile up.
Tour of Idaho T1 Challenge - https://spotwalla.com/tripViewer.php...551f1642711d75
Eat. Sleep. Ride - The Great Divide: http://advrider.com/forums/showthrea...4#post19193704
Go, Get Lost - Heading South: http://advrider.com/forums/showthread.php?t=735690
Dirt Donkeys Do Baja: http://advrider.com/forums/showthread.php?t=671095
Shibby! screwed with this post 03-20-2013 at 07:18 AM
Shibby! is offline   Reply With Quote
Old 03-20-2013, 07:03 AM   #16530
crypto666
Oddometer: 1,276
Originally Posted by Shibby! View Post
All depends how you tie it. Mine hasn't and it's got lots, and lots of K on it with the ultra thing Powerbomb header.
You just have to be different don't you?
Times are GMT -7.   It's 06:43 AM.
