Old 03-20-2013, 08:18 AM   #16531
Shibby!
Oddometer: 1,657
Originally Posted by crypto666 View Post
You just have to be different don't you?
I do.
I'm not saying they are great chains. I likely won't use one again (primary drive), but after having an RK chain snap on me as well (the links broke, not the pins!) I don't think I'll use RK either. Their price range is great, but I'd have a tough time trusting it.
DID's are just way too expensive.
Tour of Idaho T1 Challenge - https://spotwalla.com/tripViewer.php...551f1642711d75
Eat. Sleep. Ride - The Great Divide: http://advrider.com/forums/showthrea...4#post19193704
Go, Get Lost - Heading South: http://advrider.com/forums/showthread.php?t=735690
Dirt Donkeys Do Baja: http://advrider.com/forums/showthread.php?t=671095
Shibby! is offline   Reply With Quote
Old 03-20-2013, 08:35 AM   #16532
BuRPsa
Finally growing up..
BuRPsa's Avatar
Oddometer: 548
Depends who you ask. This is the OEM Jap bikes come with, and I've found anything else an also-run - hence will only buy this brand.
BuRPsa is offline   Reply With Quote
Old 03-20-2013, 10:45 AM   #16533
ride4fun562
ride4fun562's Avatar
Oddometer: 207
Nice video , also glad to see a land owner that doesent have a stick up their ass
Originally Posted by cognugget View Post
ride4fun562 is offline   Reply With Quote
Old 03-20-2013, 12:01 PM   #16534
medisyn
Oddometer: 149
Originally Posted by achile View Post
I opened up link from x-ring chain when I shortened it. I was running a DIY chain oiler. The interior had nice, clean oil. The oil will also keep the chain clean. It's not messy if you have it properly tuned.
The o-rings and x-rings have to be lubed and cleaned, but no more. This is a picture made after running an oiler on the street for 3000 km whitout maintanance. It's on a Yamaha XTZ 750. For offroad use, it's a bit tricky to install the oiler in a safe position
You got instructions you followed for your DIY setup? I know a chain oiler is pretty simple to bodge together, but I am curious. I wanna run a oiler on my non XR-R.
medisyn is offline   Reply With Quote
Old 03-20-2013, 01:40 PM   #16535
poppy
Slow and Steady
poppy's Avatar
Oddometer: 2,286
Originally Posted by mitchn06 View Post
Nice, did you use an impact, or hold the flywheel with something? I've read that you can demagnetize the flywheel somehow.
Yeah, as Will said, impact works a treat. No issues with magnatism
poppy is offline   Reply With Quote
Old 03-20-2013, 02:57 PM   #16536
mitchn06
mitchn06's Avatar
Oddometer: 553
Rebuild parts list
Here is a link to my rebuild OEM parts list i have created so far. does this look good? did i miss anything vital? i'm hoping some of the bearings are fine so i can save some $$. thinking about skipping the tensioner also, since it works fine, along with some other things.
LINK
2000 Honda XR650R (Sold) LINK
2014.5 Kawasaki KLR650 NE
mitchn06 is offline   Reply With Quote
Old 03-20-2013, 03:51 PM   #16537
woodsxr
Oddometer: 188
LINK
Couldn't access list
woodsxr is offline   Reply With Quote
Old 03-20-2013, 04:19 PM   #16538
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,036
I do.
I had a primary drive o-ring on an XR400, got two weekend rides on it, probably 400 miles. It's supposed to be their "good" chain. The link plates started splitting where the pins are inserted on at least 1/2 of the links. It could have snapped anytime, surprised it didn't. I won't trust them anymore, too much risk of getting stranded or jacking up the bike.
Chris
"Life's journey is not to arrive at the grave safely in a well preserved body, but to rather skid in sideways, totally worn out, shouting ... Holy Shit, what a ride!"
CL Adventure Ride 2013 /CL Revisited 2014 / 700 Miles of Scenic Utah Backcountry / MY VIDEOS / RIDEFREAK TV
RideFreak is offline   Reply With Quote
Old 03-20-2013, 04:58 PM   #16539
mitchn06
mitchn06's Avatar
Oddometer: 553
try now
Old 03-20-2013, 06:01 PM   #16540
sintax
Oddometer: 495
LINK
Thats actually a really good resource for the part numbers too.
sintax is offline   Reply With Quote
Old 03-20-2013, 07:31 PM   #16541
mitchn06
mitchn06's Avatar
Oddometer: 553
Did a small update to the list, the highlighted red is obviously all of the parts on the list.
the highlighted blue is slimmed down list:
i know i need to replace camshaft bearings( should have done it when i replaced camshaft three years ago)
crankshaft because the connecting rod is being replaced
i kept all the main oil seals, skipped out on a few o-rings
should be fine with the gasket selection
the cam chain tensioner functions as it should
still might do the tensioner arm, as i havn't had it out to look at it yet
all the other parts i know are needed so i kept them on the list.
Updated List
Old 03-20-2013, 07:58 PM   #16542
dohcfox
meh
dohcfox's Avatar
Oddometer: 144
There has been a lot of talk of Primary Drive chains being junk lately. Onthe other hand, if I remember correctly, Shibbly has gotten a lot of use out of their steel sprockets. Can anyone chime in on this? I ask this question because I know that the budget minded might be looking at their sprockets. I'll personally be picking up an Ironman sprocket, being that they are local and all that...
Ser decente no cuesta un culo y queda uno putamente bien!
dohcfox is offline   Reply With Quote
Old 03-21-2013, 03:03 AM   #16543
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,036
I've used their sprockets, they're OK, nothing special but they'll get you down the trail.
Chris
Old 03-21-2013, 08:24 AM   #16544
crypto666
Oddometer: 1,257
When I bought a new drive this season, I replaced a PD counter sprocket with a Renthal. The Rental fits a lot tighter on the shaft, the PD had more slop than I care for. Others have pointed this out over a year ago on this thread.
I would point out that my PD chain snapped a roller, and Ridefreak is seeing side plates split. Now if we could just get both of those failures in the same batch, that would be one badass chain; God damn thing would explode as soon as you hit the throttle. Imagine the look on peoples faces? "I don't know, its just got a lot of powa!"
crypto666 is offline   Reply With Quote
Old 03-21-2013, 10:55 AM   #16545
ADVSearcher
ADVSearcher's Avatar
Oddometer: 133
Question
Some quick clearification wanted regarding chain slack ...
This is what the manual says:
Does this mean ?:
Alternative 1 (tight)
Or alternative 2: (a bit less tight)
Can add that I have now done it as alternative 1 but the chain feels way to tight on side stand (& measured of course the slack with free hanging wheel)
Or ... is it according to this ?
Alternative 3: (not even close to tight )
ADVSearcher screwed with this post 03-21-2013 at 11:20 AM
ADVSearcher is offline   Reply With Quote
Times are GMT -7.   It's 02:45 PM.
