03-20-2013, 05:01 PM
#16546 | |
Oddometer: 341
Thanks |
03-20-2013, 06:31 PM
#16547 |
Oddometer: 78
Did a small update to the list, the highlighted red is obviously all of the parts on the list.
the highlighted blue is slimmed down list: i know i need to replace camshaft bearings( should have done it when i replaced camshaft three years ago) crankshaft because the connecting rod is being replaced i kept all the main oil seals, skipped out on a few o-rings should be fine with the gasket selection the cam chain tensioner functions as it should still might do the tensioner arm, as i havn't had it out to look at it yet all the other parts i know are needed so i kept them on the list. Updated List |
03-20-2013, 06:58 PM
#16548 | |
meh
Oddometer: 102
Ser decente no cuesta un culo y queda uno putamente bien!
03-21-2013, 02:03 AM
#16549 | |
Torque Junkie
Oddometer: 3,539
03-21-2013, 07:24 AM
#16550 | |
Oddometer: 609
When I bought a new drive this season, I replaced a PD counter sprocket with a Renthal. The Rental fits a lot tighter on the shaft, the PD had more slop than I care for. Others have pointed this out over a year ago on this thread. I would point out that my PD chain snapped a roller, and Ridefreak is seeing side plates split. Now if we could just get both of those failures in the same batch, that would be one badass chain; God damn thing would explode as soon as you hit the throttle. Imagine the look on peoples faces? "I don't know, its just got a lot of powa!" |
03-21-2013, 09:55 AM
#16551 |
Oddometer: 77
Some quick clearification wanted regarding chain slack ...
This is what the manual says: ![]() Does this mean ?: Alternative 1 (tight) ![]() Or alternative 2: (a bit less tight) ![]() Can add that I have now done it as alternative 1 but the chain feels way to tight on side stand (& measured of course the slack with free hanging wheel) Or ... is it according to this ?Alternative 3: (not even close to tight )
ADVSearcher screwed with this post 03-21-2013 at 10:20 AM |
03-21-2013, 10:23 AM
#16552 | |
Oddometer: 609
I shoot for an inch, whether its measured from center to center of top to top. It isn't super critical as long as it is not too tight. |
03-21-2013, 10:48 AM
#16553 |
Oddometer: 78
I have asked this question about many different bikes. Never received a good answer. Everyone does it differently.
Sent from my Galaxy Nexus using Tapatalk 2 |
03-21-2013, 10:57 AM
#16554 |
Oddometer: 437
while not the easiest,but the most accurate way is to cycle the suspension without the shock hooked up.The chain will usually be tightest up around full compression.Set adjusters from that point,connect shock,make note of chain play on stand now and that is where you should always set it.
09 Husaberg FE 570 07 Honda XR 650R 11 BMW R1200GSA |
03-21-2013, 11:20 AM
#16555 | |
Oddometer: 77
OK ?!? So this is really rocket science ![]() Well, did measure the slack with the bike lifted up, as stated in the manual. Will go for alternative 2, that's the way it's described for my Beamer F800GS (they were crystal clear in that manual Thank's for answering guys ! |
03-21-2013, 11:58 AM
#16556 |
Oddometer: 78
i find it kinda comical that this conversation comes up, but at the same time, educational. One of the most basic procedures that nobody knows. haha. me either i guess, although my riding partners can hear my chain slapping better than they can hear their own bikes. maybe i need to rethink this.
03-21-2013, 01:01 PM
#16557 |
Oddometer: 77
03-21-2013, 01:33 PM
#16558 |
Exhiled
Oddometer: 187
As mentioned you want to make sure that there is at least some slack when things are compressed. That can mean having your fattest friend sit on it, ratcheting it down, unlinking the shock, etc. Once you verify that you have at least some slack at that point then figure out how much slack you have when on the stand to give that same value compressed. Then you'll never have to go through the compressed check again. I think that a lot of chain issues are caused from over tightening. The first time you hit hard with a tight chain you really stretch it a bunch.
Sent from my DROIDX using Tapatalk 2 |
03-21-2013, 02:09 PM
#16559 | |
Oddometer: 1,381
Good to know. It's been awhile since I've used PD chains. I might try RK again but hold have my reserves.. The price point is right when they are around 80$ for their X-ring chain. PD rear sprockets are great. Front ones fit loose on shaft. I wouldn't go that route again. I might splurge for Ironman next time but I think our conditions will still make quick work of them. Hurts when the drives are 150$ instead of 30-40$. They'd have to last 4 times as long to make them worth it but I'd doubt a sprocket can survive our gritty dirty that long. I picked up another pumpkin last night... *blush*. Bought my buddies 2011-250XC.
Tour of Idaho T1 Challenge - On Dual Sported XR650R's: Coming Summer 2013 Eat. Sleep. Ride - The Great Divide: http://advrider.com/forums/showthrea...4#post19193704 Go, Get Lost - Heading South: http://advrider.com/forums/showthread.php?t=735690 Dirt Donkeys Do Baja: http://advrider.com/forums/showthread.php?t=671095 |
03-21-2013, 02:14 PM
#16560 | |
Oddometer: 1,381
You always hear your friends louder then your own. Ride beside a wall or crash barrier and you'll see that you then hear YOURS. I measure top to top. I have never confirmed, but most say tightest spot is when chain, swingarm axle, and wheel axle are aligned. That makes sense to my gr 9 geometry... and a few years of engineering. Sliders could come into play though.
