Old 03-30-2013, 06:32 AM   #16636
Icelander-DR650
Icelander-DR650's Avatar
Oddometer: 42
I had a can of brake cleaner and gave it a good blast and it looks good The tire is brand new too, it has one ride on it. I'd rather not throw away $180.00 so I'll give it a good blast again with cleaner and go play in an empty parking lot to see if it feels funny or slips... A friend suggested after blasting it again a little buffing with a belt sander wouldn't hurt...
Icelander-DR650 is offline   Reply With Quote
Old 03-30-2013, 08:45 AM   #16637
RRP13
Kinda superbikey
RRP13's Avatar
Oddometer: 143
Originally Posted by Icelander-DR650 View Post
Thanks for the reply! I have the snap ring out already but won't pull the seal until I get a new one so the motor stays sealed. Well, kinda sealed I guess. I'll be sure to lube up the new one on the way in. Speaking of lubed up, I'm kinda surprised I didn't end up on my ass...never had this on a tire before...
And I was turning both right and left....
Wipe it off really well with xylene. Tire won't last long but at least it won't be a total write off.
Mark S.
XR400R - thumper
R1100GS - tractor
SV650 (and then there was one.) - road racer
GSXR750 - oiler project
RRP13 is offline   Reply With Quote
Old 03-30-2013, 10:25 AM   #16638
Unsung
Oddometer: 60
I had a question about gearing. I am running 15/43 and it seems gutless over 65mph. I was going down the highway at about 75 and it just seemed wound too high and not wanting to pull. I kicked it wide open hoping to pass some people but gave up. I weigh 175lbs, stock wheels with shinko 705, uncorked with aftermarket exhaust. What am I missing here? Should I swap to a 14 front, or do I need to rejet and put an aftermarket air filter in it?
I'm starting to wonder now. I think my bike is losing power, is this possible? I have no speedo so it's hard to judge. But I chased a friend down in their car and passed them easily at 65 a few weeks ago. Blew by them and kept adding it on. Is it possible the problem was a lot of wind? Bah, asking all these questions when I should just go ride it down the highway again. Maybe there was too much wind, or people were going a lot faster than I thought.
Unsung screwed with this post 03-30-2013 at 11:29 AM
Unsung is offline   Reply With Quote
Old 03-30-2013, 02:54 PM   #16639
jm-2008
jm-2008's Avatar
Oddometer: 513
Tyre Clean
[QUOTE=Icelander-DR650;21068047]I had a can of brake cleaner and gave it a good blast and it looks good The tire is brand new too, it has one ride on it. I'd rather not throw away $180.00 so I'll give it a good blast again with cleaner and go play in an empty parking lot to see if it feels funny or slips... A friend suggested after blasting it again a little buffing with a belt sander wouldn't hurt...
A few KM's on a dry/dirt/gravel road wouldn't do any harm
Repeated us of chemicals would concern me re potential for degradation of the curing/compound in the tyres.
jm-2008 is offline   Reply With Quote
Old 03-30-2013, 02:58 PM   #16640
jm-2008
jm-2008's Avatar
Oddometer: 513
Case saver wear
Looks like some wear/clearance issues on the case saver.
Is this normal with a 15T as marked or are there other geometry/suspension considerations with the MOTARD wheels
Old 03-30-2013, 08:34 PM   #16641
sintax
Oddometer: 495
MT - 43 Trials
So i'm tossing around the idea of swapping on a MT-43 in Moab to use for the second half of the TAT. Does anyone have any personal experience running this tire on the XR loaded down? I plan on traveling light, but its still a big ol bike with a 210 lb rider + a good bit of gear.
We are not 100% sure we are going all the way to OR, but its possible.
Any theory on if that tire could make the whole rest of the trip if necessary?
sintax is offline   Reply With Quote
Old 03-30-2013, 09:27 PM   #16642
Icelander-DR650
Oddometer: 42
RRP13 and jm-2008:
I was wondering about tire damage with chemicals....I might just use a spray readily available here called 'Spray 9' that I've used quite a bit and removes grease and tar without damaging the interior of vehicles. Thought I'd soak the tire and go at it with a plastic bristled brush. The advise of playing in the dirt will be exercised, sounds like a good idea, I've done this to new tires to get rid of the slippery surface they have.
I don't think the wear on the case saver is from geometry issues, the chain was a bit slack and was adjusted when the new tires went on. I'm thinking that the marks are from the loose chain making contact during hard acceleration and deceleration periods. The mark on the bottom during acceleration and the one on the top during deceleration... I could be wrong. I noticed it too and planned on cleaning up the marks and then watch for further indications of contact or wear.
Old 03-30-2013, 09:53 PM   #16643
bamfslap
Oddometer: 205
Originally Posted by PeteN95 View Post
Only the CRF450R is EFI, not the X and neither are 6 spd.
As for skid plates, mine came with an Al and I have always used Al ones, but I just bought an Acerbis plastic one for my other bike and it is very nice. Lighter than Al and much thicker than the stock XRR unit. So far it has held up very well.
And neither are good for dual sport or as durable as the mighty 650.
And dat torque!
bamfslap is offline   Reply With Quote
Old 03-31-2013, 06:09 AM   #16644
1bigrn
Oddometer: 212
Warp9 Racing Radiators
Anyone running these Warp9 radiators.
http://www.warp9racing.com/accessories_radiators.html
They appear to be a ripoff of the Fuidyne. Any thoughts or experience?
1bigrn is offline   Reply With Quote
Old 03-31-2013, 08:55 AM   #16645
TJE
Space Emperor
Oddometer: 72
Hi Lads! I just installed a set of new clutch plates (metal + friction plates, except for the inner smaller friction disc, which I had somehow missed) and now when I go hard, the engine revs, but the bike doesn't accelerate. Any idea why the clutch is slipping now? Is this normal until it's worn in or something? I've only gone about 20km on the new clutch so far.
Any help would be greatly appreciated, as I'm a bit new to this beast :)
2006 Vespa Grantourismo 125L
1998 Honda XRV750 Africa Twin
2003 Honda XR650R
My gallery: http://www.subsignal.com
TJE is offline   Reply With Quote
Old 03-31-2013, 09:36 AM   #16646
smoothride
smoothride's Avatar
Oddometer: 234
Stop riding it there is something wrong. Take it apart and check your work. You will burn your new clutch up.
00 XR650R plated
08 DR650
smoothride is offline   Reply With Quote
Old 03-31-2013, 10:25 AM   #16647
sintax
Oddometer: 495
those look like the same ones that are all over ebay.
I know there are a few diff guys running them. They sure are priced well. I'm currently debating picking up a set vs fluidyne
Old 03-31-2013, 11:39 AM   #16648
slickwill
Exhiled
Oddometer: 209
This. There shouldn't be ANY slipping with new clutch parts.
Sent from my DROIDX using Tapatalk 2
slickwill is offline   Reply With Quote
Old 03-31-2013, 12:12 PM   #16649
1bigrn
Oddometer: 212
warp 9 radiators
Most of the reviews about the fleabay ones are positive. Most negatives are the holes don't line up. I would hope Warp took care of this issue if they put their name on it!
Old 03-31-2013, 04:36 PM   #16650
mitchn06
mitchn06's Avatar
Oddometer: 542
i think you should do it, be OUR Big Red Guinea Pig
2000 Honda XR650R (Sold) LINK
2014.5 Kawasaki KLR650 NE
mitchn06 is offline   Reply With Quote
Times are GMT -7.   It's 03:04 PM.
