Old 04-01-2013, 04:25 PM   #16666
babuja
babuja's Avatar
Oddometer: 353
Originally Posted by sintax View Post
So back on the topic of radiators from china,
I know a few of you guys have gotten them already, did they have mounts for the smog gear on them? The pics dont appear to have the mounts on ebay...
I'd like to still mount a SPAL fan
The reason for bigger radiators is better cooling. I've Just added a fan and seems to work fine for me, temp. between 180-200F with outside temp. between 70 to 95F.
I do regular oil change (no more than 1000km) and refrigeration liquid every year (mostly to avoid sand deposits and premature wate pump failer.
Cheers guys
Babuja
________
KTM 950 ADV
www.babuja.smugmug.com
http://www.nomadstrail.net/site/
babuja is offline   Reply With Quote
Old 04-01-2013, 04:25 PM   #16667
slickwill
Exhiled
Oddometer: 209
Originally Posted by babuja View Post
Manual recomends cleaning at every oil change?!? I'll give them a check next time.
I do every other. It never seems to have much on it except right after a rebuild.
Sent from my DROIDX using Tapatalk 2
slickwill is offline   Reply With Quote
Old 04-01-2013, 05:50 PM   #16668
Icelander-DR650
Icelander-DR650's Avatar
Oddometer: 42
I was going to wait until I received the new countershaft seal before I pulled the old one, but I thought I'd get it done in case I had problems...there were none, popped out easy!
All ready for the new seal!
My makeshift workshop...
Thanks for the advice guys!
Icelander-DR650 screwed with this post 04-01-2013 at 07:34 PM
Icelander-DR650 is offline   Reply With Quote
Old 04-01-2013, 05:59 PM   #16669
sintax
Oddometer: 495
Has anyone had or heard of any overheating issues with Devol radiator guards? Just spotted a few things about it on thumpertalk....
sintax is offline   Reply With Quote
Old 04-01-2013, 07:05 PM   #16670
Lostsaffa
Half Man Half BRP
Lostsaffa's Avatar
Oddometer: 667
I had them fitted here in Queensland temperatures and didn't notice a difference to stock. Personally I wouldn't buy Devol guards ever again, they are not at all designed to protect impact from a fall. They are only good for stopping flying debris from hitting the front of the rads, but then the OEM ones can do that too....
UniBikers are far better.
Blog: XR650R.Blogspot.com
FB Page: https://www.facebook.com/BajaXR650R
Lostsaffa is offline   Reply With Quote
Old 04-01-2013, 08:30 PM   #16671
AJ..
AJ..'s Avatar
Oddometer: 1,621
Laugh
Hi,
it's that crfx rear fender.?
can I know more about it?more day pics please!
HONDA XRV750-02,(woot-woot)BMW R1100GS-'98()BMW F650GS-01
Suzuki XF650Freewind-01
Husqvarna TE510centennial Rallye-04
KTM640ADV,KTM620DUKE projected()[COLOR=red]VF750C-96(project tracker)
http://www.facebook.com/pages/AJs-friends/158711187491373?v=wall[/URL]
AJ.. is offline   Reply With Quote
Old 04-01-2013, 09:16 PM   #16672
cognugget
cognugget's Avatar
Oddometer: 243
Sweet motard
Plated XR650R
cognugget screwed with this post 04-01-2013 at 09:34 PM
cognugget is offline   Reply With Quote
Old 04-01-2013, 09:22 PM   #16673
Icelander-DR650
Oddometer: 42
Aj..
Yes, it's a CRFX. Unfortunately I don't know much about it off hand, I just bought the bike but I have seen the thread that explains how to do it somewhere. I'm not home right now, but will look for the thread and post a link...
I have a few more photos on the XR650Rforum.com site (Icelander-XR650R there). Look in Introduce Yourself and Post Photos threads. I can post a few here tomorrow too if you like.
Old 04-01-2013, 09:34 PM   #16674
cognugget
cognugget's Avatar
Oddometer: 243
Got a question.
When I snap the throttle, I get a hesitation off idle, any ideas?
Uncorked
Stock carb
178 main
68s pilot
HONDA NEEDLE SET 16012-MBN-771 on the 3rd cli
Plated XR650R
Old 04-01-2013, 10:14 PM   #16675
jm-2008
jm-2008's Avatar
Oddometer: 513
Filter cleaning?
[QUOTE=babuja;21085232]hy guys,
just found this image in the net. Could found what this part is? Some kind of oil filter?
Don't think cleaning the filter will help much there!
jm-2008 is offline   Reply With Quote
Old 04-01-2013, 10:53 PM   #16676
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,477
Sean-0 is offline   Reply With Quote
Old 04-01-2013, 11:12 PM   #16677
bamfslap
Oddometer: 205
[QUOTE=jm-2008;21088347]
hy guys,
It's a banjo bolt and there is a screen there above it (IIRC). You can open it up and clean it, but usually it's clean.
Originally Posted by cognugget View Post
Got a question.
Uncorked
Stock carb
178 main
68s pilot
That's pretty normal with these carbs. You have to do hard rolls on or it bogs. The best way to fix it is to by a TM40 pumper carb kit.
Originally Posted by Sean-0 View Post
Nice! We need more action shots in this thread.
bamfslap is offline   Reply With Quote
Old 04-02-2013, 02:41 AM   #16678
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,477
yep fckn cool shot i recon ....aussie's giving the pig a gut full
BTW some1 answer my question on the front fender ...i wanna crf typ but need to know what 1 to buy that will fit and suit the bike
Old 04-02-2013, 03:45 AM   #16679
TJE
Space Emperor
Oddometer: 72
Originally Posted by smoothride View Post
Stop riding it there is something wrong. Take it apart and check your work. You will burn your new clutch up.
I already took it apart once, and all looks fine!
Originally Posted by slickwill View Post
This. There shouldn't be ANY slipping with new clutch parts.
Yeah, I guess you're right! My AT had no such issues after a clutch change
Originally Posted by poppy View Post
Did you pull everything out of the clutch assembly , including the skinny clutch plate the judder spring and the flat spring seat?. How did you assemble it.
You should have had a flat spring seat 1st, then the judder spring. The judder spring is the one on an angle. It should be touching the spring seat on the bottom and leaning out toward you at the top, then you install the skinny clutch plate, then a steel. The steels have 2 different sides, one a flat square egde type, the other side will have like a radius edge. These can go either way, but install them all the same way. I soak my clutch plates in oil before installing.
So after you put the skinny plate in, then a steel, then a normal clutch plate, steel , clutch plate , steel etc etc. You should have 6 normal plates , 6 steels, 1 skinney plate ,1 judder spring and 1 flat spring seat.
Thanks, poppy! Yeah, I went totally by the book, in the order that you mention. I did try to sort the steel plates as you describe, but by then, they were all greased up, so could have placed one the other way. Though I'm sure this would not cause it to slip?
Could it be the wrong plates? The previous owner sold them with the bike, but since the skinny plate was missing, perhaps they're not the right ones, and have a different thickness?
I have good slack in the lever, so it's not a problem there.
There doesn't seem to be any slip when letting go of the clutch in 1st gear, by the way.
2006 Vespa Grantourismo 125L
1998 Honda XRV750 Africa Twin
2003 Honda XR650R
My gallery: http://www.subsignal.com
TJE screwed with this post 04-02-2013 at 03:50 AM
TJE is offline   Reply With Quote
Old 04-02-2013, 04:18 AM   #16680
AJ..
AJ..'s Avatar
Oddometer: 1,621
nice shot!!
and nice bike setup..
Times are GMT -7.   It's 06:55 AM.
