Old 04-03-2013, 08:42 AM   #16696
cognugget
cognugget's Avatar
Oddometer: 243
How I feel when I see other wide load dual sports, a repost, but funny every time.
http://www.youtube.com/watch?v=_ztsP...endscreen&NR=1
Plated XR650R
cognugget is offline   Reply With Quote
Old 04-03-2013, 09:51 AM   #16697
mitchn06
mitchn06's Avatar
Oddometer: 542
Originally Posted by Jayrod1318 View Post
Got an oil analysis done. bike has 3,000 miles on it. oil is shell rotella 15w-40.
Oil has 950 miles on it.
Bike has been well taken care of its whole life.
Not quite sure about the wear metals in this sample.
That is quite interesting. i also wonder about the high levels of metal in you sample.
2000 Honda XR650R (Sold) LINK
2014.5 Kawasaki KLR650 NE
mitchn06 is offline   Reply With Quote
Old 04-03-2013, 10:06 AM   #16698
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 14,972
Looks like somebody has been slipping the clutch to me. Try being super smooth on starts and time the shifts to perfection, snick it into neutral at long red lights and see how the next sample looks.
Old 04-03-2013, 01:17 PM   #16699
Jayrod1318
Poster
Jayrod1318's Avatar
Oddometer: 1,641
I'm thinking it is clutch contamination too. The bike runs and sounds fine.
I'm going to make sure I have enough lever free play and make sure I use neutral at lights.
Jayrod1318 is offline   Reply With Quote
Old 04-04-2013, 09:16 AM   #16700
BuRPsa
Finally growing up..
BuRPsa's Avatar
Oddometer: 548
If you're worried about the Ali then open up the oilpump & inspect, and do keep in mind this bike's oil-'tank' is an aluminium frame.
If you're worried about the steel then keep 1 thing in mind - this is a bike, not a car!
No car has a gearbox in it's crankcase like bikes have, hence is lubricated by the engine oil rather than a gear-oil.
On top of all this there's indeed a wet clutch also, so in all I'd not worry too much
BuRPsa is offline   Reply With Quote
Old 04-04-2013, 09:23 AM   #16701
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 14,972
I was trying to say, change your clutch operation as a test, do another sample, see if the numbers improve, if not you need to dig in and see what's up. I'd be willing to bet that it's all from the clutch, including the aluminum...basket fingers wear really fast, especially if you clutch every shift like I do.
Old 04-04-2013, 11:06 AM   #16702
cognugget
cognugget's Avatar
Oddometer: 243
WHy do you clutch every shift when the only proven effect in doing so is wearing out clutch components.
Plated XR650R
Old 04-04-2013, 11:25 AM   #16703
babuja
babuja's Avatar
Oddometer: 353
Good point on that
Cheers guys
Babuja
________
KTM 950 ADV
www.babuja.smugmug.com
http://www.nomadstrail.net/site/
babuja is offline   Reply With Quote
Old 04-04-2013, 11:52 AM   #16704
Shibby!
Oddometer: 1,658
Proof?
Tour of Idaho T1 Challenge - https://spotwalla.com/tripViewer.php...551f1642711d75
Eat. Sleep. Ride - The Great Divide: http://advrider.com/forums/showthrea...4#post19193704
Go, Get Lost - Heading South: http://advrider.com/forums/showthread.php?t=735690
Dirt Donkeys Do Baja: http://advrider.com/forums/showthread.php?t=671095
Shibby! is offline   Reply With Quote
Old 04-04-2013, 05:46 PM   #16705
mitchn06
mitchn06's Avatar
Oddometer: 542
ummmm...... have i been driving a motorcycle the wrong way for the last 10 years??? i missed out on the no clutch thing.
Old 04-04-2013, 06:06 PM   #16706
ktmnate
ktmnate's Avatar
Oddometer: 3,079
"O" Ring problems
I need some help. first a little background. I have always wanted an XR. about two years ago, I found a California plated XR for a good price (Thanks James at Renazco). The bike is a 2000. I have done the CS seal and bushing. I added a stator, lights and turn signals. I have no clue about the carb or jetting. Never been in there. The motor I'm guessing is stock other than being uncorked. I adjust the valves and change the oil. It starts usually on the first or second kick. I have had it down to Baja three times and each trip was over 2k miles. I have also done the Oregon Back Route Discover route for another 2.5K miles. and countless local romp sessions. I have had no fewer than 8 of these "O" rings replaced. usually before I need to change the oil. thanks in advance for your help.
ktmnate is offline   Reply With Quote
Old 04-04-2013, 06:07 PM   #16707
Lostsaffa
Half Man Half BRP
Lostsaffa's Avatar
Oddometer: 657
I have seen this no clutch approach mentioned from to time but it logically makes no sense to me to not use the clutch - if it was so revolutionary then why doesn't Honda lose the clutch on all its bikes?
Just sounds like laziness to me, and not understanding what a clutch actually does.....
Blog: XR650R.Blogspot.com
FB Page: https://www.facebook.com/BajaXR650R
Lostsaffa is offline   Reply With Quote
Old 04-04-2013, 06:22 PM   #16708
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,431
Think i would rather use consumables rather than hard parts
Sean-0 is offline   Reply With Quote
Old 04-04-2013, 07:20 PM   #16709
woodsxr
Oddometer: 202
So you are saying you are going through a back tire per 1000 miles? sounds about right if you are pushing it decently
Wish I had the time to do that
woodsxr is offline   Reply With Quote
Old 04-04-2013, 07:25 PM   #16710
slickwill
Exhiled
Oddometer: 209
I sorta felt this way until I had it all apart and studied the design of the transmission very carefully and realized that for upshifts there isn't any reason why you have to use the clutch. On the street and relaxed riding I still use it to obtain smoother shifts but on the track I never use it for upshifts. Upshifting under race conditions just burns up clutch plates for no reason.
slickwill is offline   Reply With Quote
Times are GMT -7.   It's 05:34 AM.
