Old 04-04-2013, 12:25 PM   #16711
babuja
babuja's Avatar
Oddometer: 353
Originally Posted by cognugget View Post
WHy do you clutch every shift when the only proven effect in doing so is wearing out clutch components.
Good point on that
Cheers guys
Babuja
________
KTM 950 ADV
www.babuja.smugmug.com
http://www.nomadstrail.net/site/
babuja is offline   Reply With Quote
Old 04-04-2013, 12:52 PM   #16712
Shibby!
Oddometer: 1,656
Proof?
Tour of Idaho T1 Challenge - https://spotwalla.com/tripViewer.php...551f1642711d75
Eat. Sleep. Ride - The Great Divide: http://advrider.com/forums/showthrea...4#post19193704
Go, Get Lost - Heading South: http://advrider.com/forums/showthread.php?t=735690
Dirt Donkeys Do Baja: http://advrider.com/forums/showthread.php?t=671095
Shibby! is offline   Reply With Quote
Old 04-04-2013, 06:46 PM   #16713
mitchn06
mitchn06's Avatar
Oddometer: 548
ummmm...... have i been driving a motorcycle the wrong way for the last 10 years??? i missed out on the no clutch thing.
2000 Honda XR650R (Under the Knife) LINK
mitchn06 is online now   Reply With Quote
Old 04-04-2013, 07:06 PM   #16714
ktmnate
ktmnate's Avatar
Oddometer: 3,016
"O" Ring problems
I need some help. first a little background. I have always wanted an XR. about two years ago, I found a California plated XR for a good price (Thanks James at Renazco). The bike is a 2000. I have done the CS seal and bushing. I added a stator, lights and turn signals. I have no clue about the carb or jetting. Never been in there. The motor I'm guessing is stock other than being uncorked. I adjust the valves and change the oil. It starts usually on the first or second kick. I have had it down to Baja three times and each trip was over 2k miles. I have also done the Oregon Back Route Discover route for another 2.5K miles. and countless local romp sessions. I have had no fewer than 8 of these "O" rings replaced. usually before I need to change the oil. thanks in advance for your help.
ktmnate is offline   Reply With Quote
Old 04-04-2013, 07:07 PM   #16715
Lostsaffa
Half Man Half BRP
Lostsaffa's Avatar
Oddometer: 636
I have seen this no clutch approach mentioned from to time but it logically makes no sense to me to not use the clutch - if it was so revolutionary then why doesn't Honda lose the clutch on all its bikes?
Just sounds like laziness to me, and not understanding what a clutch actually does.....
Blog: XR650R.Blogspot.com
FB Page: https://www.facebook.com/BajaXR650R
Lostsaffa is offline   Reply With Quote
Old 04-04-2013, 07:22 PM   #16716
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,320
Think i would rather use consumables rather than hard parts
Sean-0 is offline   Reply With Quote
Old 04-04-2013, 08:20 PM   #16717
woodsxr
Oddometer: 180
So you are saying you are going through a back tire per 1000 miles? sounds about right if you are pushing it decently
Wish I had the time to do that
woodsxr is online now   Reply With Quote
Old 04-04-2013, 08:25 PM   #16718
slickwill
Exhiled
Oddometer: 209
I sorta felt this way until I had it all apart and studied the design of the transmission very carefully and realized that for upshifts there isn't any reason why you have to use the clutch. On the street and relaxed riding I still use it to obtain smoother shifts but on the track I never use it for upshifts. Upshifting under race conditions just burns up clutch plates for no reason.
slickwill is offline   Reply With Quote
Old 04-04-2013, 08:51 PM   #16719
Cpt. Ron
Advrider #128
Cpt. Ron's Avatar
Oddometer: 3,268
Tee hee.
Buuutttt.......
you think that's bad, buy a 950.....
Cpt. Ron
"I don't know what you do, but I know what I do, and I don't do that." --Uncle Doug, R.I.P.
"Without the possibility of death, adventure is not possible"--Reinhold Messner
Cpt. Ron is online now   Reply With Quote
Old 04-04-2013, 08:59 PM   #16720
ktmnate
ktmnate's Avatar
Oddometer: 3,016
Originally Posted by Cpt. Ron View Post
Tee hee.
Buuutttt.......
Hiya Ron, I still have the 950. It too is hard on tires as you know. The only tire I have been able to get 3k is the Dunlop 908. I just wish they were cheaper.
Nate
Old 04-05-2013, 02:45 AM   #16721
BuRPsa
Finally growing up..
BuRPsa's Avatar
Oddometer: 548
Demn, too late, my comment would have been akin Wood's
A thou mile with that "o-ring" is fine, no worries, and the other o-ring will prolly last a notch longer
BuRPsa is offline   Reply With Quote
Old 04-05-2013, 03:18 AM   #16722
medisyn
Oddometer: 149
For clutch-less upshifting I have heard so many conflicting opinions on if its good or bad. I have never heard of a failure due to it though. I have tried it a few times, it feels smooth.
medisyn is offline   Reply With Quote
Old 04-05-2013, 10:08 AM   #16723
ZXRaziel
ZXRaziel's Avatar
Location: Grey skyes and rain of Good old England ( NEast)
Oddometer: 454
Originally Posted by Sean-0 View Post
yep fckn cool shot i recon ....aussie's giving the pig a gut full
BTW some1 answer my question on the front fender ...i wanna crf typ but need to know what 1 to buy that will fit and suit the bike
i cannot post pictures on here but if you check fockers forum i will post one on there for ya .
Be warned that the crf red its slightly different shade to the xr red .
link -
http://www.dirtbikexpress.co.uk/grap...nder_cr_crf_xr
good things them hondas
ZXRaziel screwed with this post 04-05-2013 at 10:27 AM
ZXRaziel is offline   Reply With Quote
Old 04-05-2013, 10:24 AM   #16724
crypto666
Oddometer: 1,231
Whaaatttt?
Using your clutch to shift does not abnormally wear out clutch components. Not using it will abnormally wear the shift drum and dogs, as well as be harder on the entire drive.
Trying combining clutch motion with throttle control, its amazing.
crypto666 is offline   Reply With Quote
Old 04-05-2013, 11:29 AM   #16725
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 14,550
Originally Posted by crypto666 View Post
Whaaatttt?
The Honda trans is too clunky for me to shift without the clutch. My 610 was butter smooth and I'd shift it without using the clutch, up and down, but it had a broken clutch cable most of the time, so I had to.
My riding buddy with an XRR shifts without the clutch and it's been falling out of 4th and dropping into 3rd on it's own...bent shift fork. Now he gets to split the cases to fix it.
Times are GMT -7.   It's 12:50 PM.
