Old 04-11-2013, 08:14 PM   #16846
Capt. Egregious
Capt. Egregious's Avatar
Oddometer: 376
Originally Posted by FlyGuy View Post
I added a spal fan to My xr650r it already is a DC system (required)
It is a simple setup and not to pricy, It works automatically no manual switch in the circuit
the fan switch is from summit it can handle better than 10 amps more than enough for the 4" spal
http://www.summitracing.com/parts/der-16731/overview/
I priced shopped and best I could find was Ultra rev
http://www.ultrarev.com/30103018-spal.html
I removed the right radiator and welded on .090 soft aluminum angles
Drilled and added clip-nuts
Install fan and add Hi heat tape to act as a shroud
(may need to improve this with a larger shroud later?)
Drill and tap thermostat housing 1/8 pipe
one terminal goes to ground (not like you see in picture go to the frame or engine) the other wire goes to the negative fan wire
then supply ignition power to the positive fan wire
No relay needed
Now I just hope it warms up enough to try it out.
Are you trying to pull a ground off your T-stat housing? If you are you may think about grounding the housing.
Capt. Egregious is offline   Reply With Quote
Old 04-11-2013, 09:57 PM   #16847
hontri
Global Bummer!
hontri's Avatar
Oddometer: 304
No relay needed
You might want to check your fan to fuel tank clearance. My 4" Spal fan sat right on the rad (no need for a shroud) and it just barely cleared the fuel tank.
hontri is offline   Reply With Quote
Old 04-11-2013, 10:17 PM   #16848
sintax
Oddometer: 495
First thing I was thinking
sintax is offline   Reply With Quote
Old 04-11-2013, 10:33 PM   #16849
One Fat Roach
One Fat Roach's Avatar
Oddometer: 1,587
Originally Posted by Icelander-DR650 View Post
Have you given any thought to a DR650SE? I had one and loved it. The bike seems to be placed between the XRR and KLR as far as capabilities. They do road better than an XRR and dirt better than a KLR. My was quite modded, I had both off road and Sumo wheels. The aftermarket is huge, as well as the DR650 thread here on ADV.
Just a thought....
not too much thought. Just those two mainly.
Originally Posted by Mr. Fisherman View Post
This is an adventure, not a field trip!!
One Fat Roach is offline   Reply With Quote
Old 04-11-2013, 10:50 PM   #16850
Capt. Egregious
Oddometer: 376
Haha. I didn't read your post about the fan install, just looked at the pictures. You even said you changed the wiring. Clearance with my 7 gal. IMS tank is tight with the fan mounted close to the radiator(fan mounted under the tabs, not on top). Still pretty tight with the stock tank.
Old 04-11-2013, 11:11 PM   #16851
FlyGuy
MachineHead
FlyGuy's Avatar
Oddometer: 169
Ahh your a picture looker too. got to read the text where i stated where to ground it. Was a laughable moment when I first tried to test it and figured out what was going on. (had taken picture earlier)
Good observation
FlyGuy is offline   Reply With Quote
Old 04-11-2013, 11:24 PM   #16852
FlyGuy
MachineHead
FlyGuy's Avatar
Oddometer: 169
Thanks I took a double take (look)
I have a small IMS 3.2 And got good clearance, but it is tight. might impede flow a bit?
Sounds like you have a non shrouded set up that works fine?
Good to know.
I have had thermostats stick open after getting up in the 230f temps
this ought to prevent that?
Old 04-12-2013, 07:12 AM   #16853
Shibby!
Oddometer: 1,660
Good to know.
These T-stats are known to stick open.
Mounting the fan on the rad (or very close) is what most do here. Works perfect. Hontri actually mounted them on the front of the rads I think last time I checked.
I've been meaning to do a fan switch eventually to make it automatic. Otherwise I know when it's going to be running hot and leave it on for city driving, single track, and idling for pictures, etc.
Most people with DC systems float the ground as to not interfere with the frame grounded A/C system of the bike.
Tour of Idaho T1 Challenge - https://spotwalla.com/tripViewer.php...551f1642711d75
Eat. Sleep. Ride - The Great Divide: http://advrider.com/forums/showthrea...4#post19193704
Go, Get Lost - Heading South: http://advrider.com/forums/showthread.php?t=735690
Dirt Donkeys Do Baja: http://advrider.com/forums/showthread.php?t=671095
Shibby! is offline   Reply With Quote
Old 04-12-2013, 08:58 AM   #16854
KYLEISCOOL
Who
KYLEISCOOL's Avatar
Oddometer: 144
stock wheels
Hey gents. Got a stock set of wheels posted in the FM.
Gotta ride something! 02' XR650R slightly personalized
KYLEISCOOL is offline   Reply With Quote
Old 04-13-2013, 03:34 PM   #16855
jm-2008
jm-2008's Avatar
Oddometer: 513
Wiring loom plugs needed
Looking for a source for these (male & female) XR650R OEM wiring loom plugs -
Used where the Rec/Reg plugs into the wiring loom behind the head light
Any help appreciated
Many thanks,
JM-2008
http://jm-2008.smugmug.com/Motorcycl...4389&k=Z7hrXfz
jm-2008 is offline   Reply With Quote
Old 04-13-2013, 03:45 PM   #16856
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,439
you could buy any 4 pin plug to suit ,,, jaycar comes to mind
or service honda
Sean-0 is online now   Reply With Quote
Old 04-13-2013, 03:53 PM   #16857
jm-2008
jm-2008's Avatar
Oddometer: 513
4 Pin Plug
[QUOTE=Sean-0;21178738]you could buy any 4 pin plug to suit ,,, jaycar comes to mind
or service honda
Thanks Sean-O
Will check out J-Car
Old 04-13-2013, 06:51 PM   #16858
Jayrod1318
Poster
Jayrod1318's Avatar
Oddometer: 1,642
Front wheel
Front wheel for sale, let's make a deal?
http://www.advrider.com/forums/showp...ostcount=10946
Jayrod1318 is offline   Reply With Quote
Old 04-14-2013, 08:35 AM   #16859
thouk
Oddometer: 196
For Jm
http://www.electricalconnection.com/...ts/hitachi.htm
My Miss Piggie, a dual sported Honda Xr650r.
My Ottoman, a lovely Honda PC800 Pacific Coast
May God look upon you as you ride with Jesus with the Holy Spirit in your heart.
thouk is offline   Reply With Quote
Old 04-14-2013, 11:15 AM   #16860
BuRPsa
Finally growing up..
BuRPsa's Avatar
Oddometer: 548
Here?
http://www.vintageconnections.com/
BuRPsa is offline   Reply With Quote
Times are GMT -7.   It's 02:55 AM.
