Old 04-14-2013, 01:28 PM   #16861
XR650Gnar
Oddometer: 14
Anyone know what the torque value is for the main cylinder bolt studs (4) I got 4 new ones for the rebuild, I know that the manual says 49lbs/ft for the nuts, is it the same for the studs themselves?
XR650Gnar is offline   Reply With Quote
Old 04-14-2013, 01:42 PM   #16862
dirtyoffroad
dirtyoffroad's Avatar
Oddometer: 539
just locktite them and thread them in,they should bottom out or run out of thread.
07 Honda XR 650R
11 BMW R1200GSA
dirtyoffroad is offline   Reply With Quote
Old 04-14-2013, 01:49 PM   #16863
XR650Gnar
Oddometer: 14
So as long as theyre snug and bottomed out they shouldnt have to be torqued? I guess that makes sense as the torque comes from the head nuts.
Old 04-14-2013, 02:33 PM   #16864
dirtyoffroad
Oddometer: 539
that is correct,no torque required till you are holding something together
07 Honda XR 650R
11 BMW R1200GSA
Old 04-15-2013, 02:19 AM   #16865
TJE
Space Emperor
Oddometer: 72
model specifications?
I'm about to order some parts for my Pig online, but they have some odd model names: AC/A, A/A, A/B and AC/B. I can only find info about the D, DK, DM, U, etc type of model nomenclature ...
Can anyone explain what it means?
2006 Vespa Grantourismo 125L
1998 Honda XRV750 Africa Twin
2003 Honda XR650R
My gallery: http://www.subsignal.com
TJE is offline   Reply With Quote
Old 04-15-2013, 02:34 AM   #16866
tractor4play
Oddometer: 111
axle
Originally Posted by Adamco2 View Post
"i am having issues getting my hands on a front wheel spindle."
If it is an axle that you are looking for, seems the same as spindle, I have one or two laying around. I'll look into what it would cost send it to you in Ireland if you like.
By the way the CR/CRF axle is a different axle. I never found one that would work in it's place.
Adam
yea Adam front axle.
if your checking shipping prices remember i am in the north which comes under uk rather than Ireland.
i can only get to my computor twice a week so bare with me and thanks in advance for any help.
Ian.
tractor4play is offline   Reply With Quote
Old 04-15-2013, 10:02 AM   #16867
crypto666
Oddometer: 1,329
I believe AC is a california model with smog junk.
I would use A/A, but chances are that it doesn't matter for 95% of the parts, and the 5% of parts not the same are the ones you won't be wanting to replace anyhow.
crypto666 is offline   Reply With Quote
Old 04-15-2013, 04:32 PM   #16868
Jayrod1318
Poster
Jayrod1318's Avatar
Oddometer: 1,640
I'm looking at DID x-ring chains. Do these come with both the rivet style and clip style master links? Did website is not much help.
My 13 year old stock chain is getting bound up and kinky.
Jayrod1318 is offline   Reply With Quote
Old 04-15-2013, 06:03 PM   #16869
slogger
Oddometer: 654
It depends on what model you order and who you order it through. Make sure to verify it prior to ordering.
slogger screwed with this post 04-16-2013 at 09:17 PM
slogger is offline   Reply With Quote
Old 04-16-2013, 07:42 PM   #16870
TJE
Space Emperor
Oddometer: 72
Awesome, thanks crypto!
2003 Honda XR650R
Old 04-16-2013, 09:57 PM   #16871
ODSC1
ODSC1's Avatar
Oddometer: 194
Originally Posted by jm-2008 View Post
Looking for a source for these (male & female) XR650R OEM wiring loom plugs -
Used where the Rec/Reg plugs into the wiring loom behind the head light
Any help appreciated
Many thanks,
JM-2008
http://jm-2008.smugmug.com/Motorcycl...4389&k=Z7hrXfz
If you need OEM connectors check http://vintageconnections.com/ . I used their products on a recent project. If you buy the bullet connectors get the 3.5mm ones as they match oem. Also their crimper does a factory like crimp.
Brian
ODSC1 is offline   Reply With Quote
Old 04-16-2013, 10:36 PM   #16872
jm-2008
jm-2008's Avatar
Oddometer: 513
Vintage Connections
[QUOTE=ODSC1;21204563]If you need OEM connectors check http://vintageconnections.com/ . I used their products on a recent project. If you buy the bullet connectors get the 3.5mm ones as they match oem. Also their crimper does a factory like crimp.
Brian
Brian,
Thanks for the tip.
Burpsa (inmate) put me onto them and have placed an order.
Their pin removal tool looks handy as well.
Regards,
JM-2008
jm-2008 is offline   Reply With Quote
Old 04-18-2013, 03:19 PM   #16873
BuRPsa
Finally growing up..
BuRPsa's Avatar
Oddometer: 548
As far as I know (and have been supplied) all DIDs come with a clip-link .... which you should throw away immediately, they're not even good enough for a lawnmower.
Only a rivet-link* on a bike, especially this big one. Invest in a DID riveting-tool also, it's by far the best I've seen. And yes, the most costly one too, but horses for courses, it'll last you your life, not the bike's.
If anyone comes telling here they've always used clip-links - you lucky lucky bugger you!!!
* you buy two (2!) when you buy the chain. This will allow you later to either fix or re-join the chain if you have to take it off. Buying one later is problematic because the one you need can't be had anymore.
BuRPsa screwed with this post 04-18-2013 at 03:24 PM
BuRPsa is offline   Reply With Quote
Old 04-18-2013, 06:29 PM   #16874
bamfslap
Oddometer: 205
Eh I've never had an issue with the clip types (even when raced). I lost a clip once on a fooked DID chain on my 600 (I think the tweaked chain guide was to blame tbh) but on my Renthals I've gone thousands of miles and the clip is still secure as new. I think installation is key and make sure your guides are good.
bamfslap is offline   Reply With Quote
Old 04-18-2013, 07:30 PM   #16875
Lostsaffa
Half Man Half BRP
Lostsaffa's Avatar
Oddometer: 656
I tend to agree, always used clip links - never had a problem. I do however check the clip regularly and make sure it is fully engaged under the lip of the pin links on both sides. For people that often remove the master link, I would replace the clip after every removal as they can be bent during removal quite easily.
Some people also place a blob of glue/silicone over the clip for extra security.
Ultimately the clip is only preventing the side to side movement, not the tensile force of the chain when under load.
Just my 2c but I can understand why some people choose riveted links.
Blog: XR650R.Blogspot.com
FB Page: https://www.facebook.com/BajaXR650R
Lostsaffa is offline   Reply With Quote
Times are GMT -7.   It's 01:21 PM.
