Old 04-27-2013, 07:20 PM   #16936
phorensic
phorensic's Avatar
Oddometer: 13
I tried retrofitting my Baja Designs headlight with an HID kit. I broke the plastic clip that holds the bulb into the headlight housing. IIRC, there is a standard car headlight assembly that will swap right in, right? I want a metal housing and a metal spring clip to hold the bulb in. Anybody know what headlight from the car world will swap in?
Edit: I'm just going to glue the HID bulb to the headlight housing. Screw it =P
phorensic screwed with this post 04-29-2013 at 06:42 AM Reason: Decided to go a different direction
phorensic is offline   Reply With Quote
Old 04-28-2013, 10:31 AM   #16937
1bigrn
Oddometer: 212
Globetrottin fairing with 2x3600 lumens
i was considering the Globetrottin fairing with the twin 3600 lumnen lights. i have an entire D/C system so I do not expect there to be any significant issues hooking it up. Does anyone have any experience with the Universal Globetrottin fairing? Is it tough/ How is the fit? How much power does the twin 3600 LED take?
Also I would likely be painting it red. does anyone know what red paint code would match the 2001 xr650r plastic?
1bigrn is offline   Reply With Quote
Old 04-28-2013, 11:11 PM   #16938
Adamco2
Part time adventurer
Adamco2's Avatar
Oddometer: 127
Originally Posted by tractor4play View Post
any luck with front axle?
Sent you a PM.
Adamco2 is offline   Reply With Quote
Old 04-29-2013, 07:51 AM   #16939
crypto666
Oddometer: 1,329
is that 3600 measured lumens, or advertised? They likely are not the same.
I have never heard of a single LED that puts out 3600 lumens. Most of the led assemblies I see putting out that kind of light start at $500 per unit and run upwards of $1200.
Either way, I would expect it to pull about 25w based on a 150w/lumen max efficiency, or perhaps closer to 50w in the real world.
Who knows what leds they are using, since they don't say, I would cut the lumen output by atleast half, and still expect 20W draw per light.
And if you run them on the street, you are an asshat.
crypto666 is offline   Reply With Quote
Old 04-29-2013, 08:20 AM   #16940
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,177
3600 is pretty impressive, I'm skeptical too. Obviously it'd have to be an LED array to produce that kind of light. a 4300 lumin soltice pulls 50W or a little over 4A and they are very well made lights. Best I can figure it's 80 lumins per watt, so 2x 3600 will put you close to the max output of a rewound stator (at maximum output) and that's using both 100/125W outputs. One thing to remember, the system load shouldn't be sized close to the system output, there's a rule of thumb (I forget the percentage) that the load should consume compared to the output. It's something like 60 or 75%, otherwise you get into issues like overheated conductors, burnt switches etc.
I agree, that's way too much light for street use.
Chris
"Life's journey is not to arrive at the grave safely in a well preserved body, but to rather skid in sideways, totally worn out, shouting ... Holy Shit, what a ride!"
CL Adventure Ride 2013 /CL Revisited 2014 / 700 Miles of Scenic Utah Backcountry / MY VIDEOS / RIDEFREAK TV
RideFreak is offline   Reply With Quote
Old 04-29-2013, 10:14 AM   #16941
smoothride
smoothride's Avatar
Oddometer: 232
Tried to post a pic from my iPad it did nt work.
00 XR650R plated
08 DR650
smoothride is offline   Reply With Quote
Old 04-29-2013, 11:02 AM   #16942
smoothride
smoothride's Avatar
Oddometer: 232
http://s1305.photobucket.com/user/sm...22a3.jpg.html][/URL]I tried to post this pic earlier. I use one light in the fairing for high and one for low when on the street. When more light is needed I turn the ones on the bars on.
00 XR650R plated
08 DR650
Old 04-29-2013, 12:54 PM   #16943
walkergreenlabel
Oddometer: 213
Question Rekluse EXP
After many hours I have read EVERY page of this thread. thanks to all who have contributed to all of the great info!
Originally Posted by PeteN95 View Post
Not sure what you mean? On the highway the clutch should be locked up? The only time the Rekluse slips is when the rpm drops near idle. What model Rekluse are you using, EXP or Z-start? Are you using a clutch lever? If the plates are warped at all, it will cause excess drag and not work properly.
I have herd quite a few people comment on how a autoclutch doesn't work, its not a real bike with out a clutch, its for girls who cant ride, bla bla bla. I would like to hear real world experience with the EXP in a BRP. I rode a DR450 with an EXP and the shifting was very hard. I dont know if that's due to the autoclutch, set up on that bike or just inherent in the DR trany. is the shifting any harder with the EXP than without(stock set up using the clutch)? It was tough to idle it to allow it to shift. Have you noticed any issues with hard riding like in deep sand all?
walkergreenlabel is offline   Reply With Quote
Old 04-29-2013, 01:11 PM   #16944
Burnszilla
BurnsMoto.com
Burnszilla's Avatar
Oddometer: 1,345
Good times in Kernville at WARPED IX.
Jawbone Canyon!
Burnszilla is offline   Reply With Quote
Old 04-29-2013, 02:50 PM   #16945
PeteN95
PeteN95's Avatar
Oddometer: 2,780
I have no affection for automatic transmissions, I like to decide when to shift, but I do think the auto clutch is great! It reduces the work load on the rider and allows him to concentrate on riding. It virtually eliminates stalling and I've had an AMA roadrace and flat track champ stall right in front of me, so it has nothing to do with skill. It also helps with holeshots, reduces tire wear, and is like cheating on steep complex hills.
As far as shifting goes, it really shouldn't make any difference. If you are shifting without using the lever, then it is just like shifting a regular bike without using the clutch. You have to roll off the power or "blip" to unload the gears, then shift and roll back into it. It is fairly easy to do on dirt, as most MX racers do when upshifting with a normal clutch. But on pavement or downshifting, it requires some finesse to be smooth. You do not have to let off so much that it goes all the way to idle and releases.
It also will work fine in deep sand, but it is critical to keep track of what gear you are in, as you can wear the clutch plates by riding in the wrong gear. I personally like to ride with no clutch lever at all, so the EXP did not work for me, as it does not slip enough at idle. It is meant to be used with a clutch lever for shifting into neutral and very slow speed riding. I prefer the Z-start, which will slip more off idle, release completely at idle, and does not reduce the number of clutch plates.
"If you ain't slidin', you ain't ridin'"
SVN/XRR/XC-W
PeteN95 is offline   Reply With Quote
Old 04-29-2013, 06:28 PM   #16946
Oddfellow
Beasty Rider
Oddfellow's Avatar
Oddometer: 490
I have the Z start and love it. I also have the LH Brake and added the clutch perch shift when I first got the bike. I rarely ever touch it now.
Oddfellow
'06 Suzuki DR200SE
'05 Honda XR650R
'14 KTM 690 Enduro R
Oddfellow is offline   Reply With Quote
Old 04-29-2013, 08:50 PM   #16947
FlyGuy
MachineHead
FlyGuy's Avatar
Oddometer: 169
[QUOTE=Burnszilla;21294199]Good times in Kernville at WARPED IX.
Jawbone Canyon!
Yo Burnszilla you ride that setup from redwood city?
Not a lot of gear there in that picture you might be hotelling it ?
Looking like a good time
Keep at it.
FG
FlyGuy is online now   Reply With Quote
Old 04-30-2013, 06:38 AM   #16948
bigtrailie
Rough idle
bigtrailie's Avatar
Oddometer: 670
Thanks FlyGuy
Originally Posted by FlyGuy View Post
If you go the JB route cook your cover to 250 degrees after around 15 minutes remove from oven then upon cooling through the 140 range apply epoxy it will get very runny but re apply to fill after it cools more
magnesium will hold moisture and you need to cook it out or you will get weak adhesion
Hope that helps
I went the JB weld route using the "cooking" instructions you provided. It worked like a charm.
Need my knees in the breeze through the trees.
'04 KTM 950 ADVENTURE (black) - '05 Honda XR650R (plated) - '97 Honda XR600R (plated) - '99 Honda Valkyrie Interstate (joy rides with my wife and kids)
bigtrailie is offline   Reply With Quote
Old 04-30-2013, 12:24 PM   #16949
walkergreenlabel
Oddometer: 213
Laugh rekluse
thats great info Pete and oddfellow! thanks
walkergreenlabel screwed with this post 04-30-2013 at 01:03 PM
Old 04-30-2013, 03:04 PM   #16950
ZXRaziel
ZXRaziel's Avatar
Location: Grey skyes and rain of Good old England ( NEast)
Oddometer: 509
Originally Posted by BigToad View Post
Unfortunately I just posted my XR for sale in the flea market. Its in Vancouver BC (thus the price)....bummed about selling it......
http://www.advrider.com/forums/showthread.php?t=881850
[IMG][/IMG]
You have acces to riding location like that and you are selling the piggy ?
WHY ?
good things them hondas
ZXRaziel is offline   Reply With Quote
Times are GMT -7.   It's 03:45 AM.
