Old 05-08-2013, 08:48 AM   #16981
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,179
Originally Posted by BuRPsa View Post
Ah, my bad. Then add 1mm ie 17mm and rid yourself of leaking fuel when lent over on the sidestand.
Reducing it 1mm helps with a tough starting bike also.
Chris
"Life's journey is not to arrive at the grave safely in a well preserved body, but to rather skid in sideways, totally worn out, shouting ... Holy Shit, what a ride!"
CL Adventure Ride 2013 /CL Revisited 2014 / 700 Miles of Scenic Utah Backcountry / MY VIDEOS / RIDEFREAK TV
RideFreak is offline   Reply With Quote
Old 05-08-2013, 09:21 AM   #16982
crypto666
Oddometer: 1,342
Originally Posted by Shibby! View Post
How's that suspension working out for you?
I love XRR's with black wheels. I know that's pretty petty, but they make the bike look so gnarly. The grey forks with black wheel and gators set it off.
I have strange tastes...
Actually having thought about it, using Borynack's mid-agressive shim stacks, I would add one face shim to the conpression stack in the forks and one or two face shims to the rebound in the shock if you want your clickers set close to the middle. Mine are turned in about 3/4 closed, which isn't an issue for me.
I really like using the thinner oils (3w) and have since started using 3w in my truck shocks. It requires more shims, but I think it works better.
crypto666 is offline   Reply With Quote
Old 05-08-2013, 10:51 AM   #16983
Shibby!
Oddometer: 1,658
Mine's a little soft too but for dual sport use with slow, often very technical trails it can sometimes be nice.
I wish my KTM had 3w. I notice it changes quite a bit while it warms up. I have to stop and release the air multiple times too. Only then does it come into it's own.
Tour of Idaho T1 Challenge - https://spotwalla.com/tripViewer.php...551f1642711d75
Eat. Sleep. Ride - The Great Divide: http://advrider.com/forums/showthrea...4#post19193704
Go, Get Lost - Heading South: http://advrider.com/forums/showthread.php?t=735690
Dirt Donkeys Do Baja: http://advrider.com/forums/showthread.php?t=671095
Shibby! is offline   Reply With Quote
Old 05-08-2013, 09:22 PM   #16984
jwalters
Farkle Proliferator
jwalters's Avatar
Oddometer: 2,311
Hi Guys,
Just wanted to say thanks for the help with my jetting. The bike was running lean last December, but I over compensated. After double checking the float height (right at 16mm) I downsized to 70 idle jets and 175 mains. Still was spuddering so I pulled the air filter, lo and behold it ran great! So at that point, I knew I was too fat in the mid range. Long story short, I lowered the needle 2 clips and that put me right where I needed to be.
Thanks again.
Jesse
Minnesota North Shore Shindig 10-13 September 2015 -- Finland, MN
Proliferator of Farkles of Mass Percussion
jwalters is offline   Reply With Quote
Old 05-09-2013, 05:28 AM   #16985
galland1
galland1's Avatar
Oddometer: 113
Ready to ride.
Sent from my SPH-L720 using Tapatalk 2
galland1 is offline   Reply With Quote
Old 05-09-2013, 07:14 AM   #16986
crypto666
Oddometer: 1,342
OK, that is a first. A vanity plate on the XRR.
I like it.
Originally Posted by galland1 View Post
Ready to ride.
Old 05-09-2013, 09:19 AM   #16987
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 14,961
Originally Posted by jwalters View Post
Hi Guys,
Thanks again.
Jesse
Awesome!!!
Go for a ride.
Old 05-09-2013, 11:51 AM   #16988
Dual Badger
Dual Badger's Avatar
Oddometer: 72
What do you think?
I have a new to me 2002 xr650r that has a fmf pipe with the stock headers.
Will a fmf powerbomb header system make a big difference?
The bike runs great at this time !!! Thanks
Dual Badger is offline   Reply With Quote
Old 05-09-2013, 01:33 PM   #16989
crypto666
Oddometer: 1,342
You probably won't see much from a header until you;
open up the intake, carb and valves, open up exhaust valves, up the compression, and perhaps the bore, more agressive cam,
and then the you will probably only notice the difference in the upper end.
I would spend money on other things. The header was the last big item for my bike after rebuild everything else.
Motor mods are highly over rated, suspension is where its at.
Old 05-09-2013, 05:48 PM   #16990
Dual Badger
Oddometer: 72
Headers
Thank you !!! I will spend the money on other parts.
Old 05-09-2013, 08:44 PM   #16991
Shibby!
Oddometer: 1,658
I have the powerbomb header but cant' say for sure what it does by itself since I put the exhaust and header on at the same time. Really opened up the high end with those two additions though. Before it wouldn't labour at highway speeds, but felt more like torque than high HP. Now it feels like HP easily maintaining and enjoying that speed.
Not sure if that makes sense.
The downside to the Powerbomb is it shares the same diameter pipe as their standard header, just much thinner. This causes heat to radiate off the thing. It gets SUPER hot. With proper pants it's fine, but I've had the pleasure of riding it with shorts (yea yea, I know. It was on my trip where gearing up wasn't really an option) and it damn near cooks your leg. It does give you a mild burn even holding your leg out in the wind. In hot weather I do this even with boots/pants to keep my leg cool, although the heat is much less noticeable.
Old 05-10-2013, 01:20 AM   #16992
One Fat Roach
One Fat Roach's Avatar
Oddometer: 1,585
been hunting for a new bike and came across this one yesterday
http://yakima.craigslist.org/mcy/3793697795.html
curious what you xr vets think,??
Worth getting??
Originally Posted by Mr. Fisherman View Post
This is an adventure, not a field trip!!
One Fat Roach is online now   Reply With Quote
Old 05-10-2013, 06:14 AM   #16993
BuRPsa
Finally growing up..
BuRPsa's Avatar
Oddometer: 548
Hi Guys,
Thanks again.
Jesse
Jesse,
if an engine 'spudders' then it is running really rich, and the solution is to reduce a jet, not merely dropping the needle. It may feel fine now but I bet it still runs rich, your exhaust telling telltales.
I'd put in (with clean filter, set valves etc) the 68S, set the needle to 'mid' and drop the main size-by-size until you feel it is too small - then use the averaged size with your current one which should put you in the ballpark. Only then finetune the needle.
Of course this is a rough way of jetting, the best is to hook up an analyser on a dyno, however it will work.
BuRPsa is offline   Reply With Quote
Old 05-10-2013, 06:33 AM   #16994
babuja
babuja's Avatar
Oddometer: 353
That's the way to go...best mod i've done was usd fork conversion.2nd best was vision x led light
Cheers guys
Babuja
________
KTM 950 ADV
www.babuja.smugmug.com
http://www.nomadstrail.net/site/
babuja is offline   Reply With Quote
Old 05-10-2013, 06:42 AM   #16995
8lives
Dharma Bum
8lives's Avatar
Oddometer: 2,018
Worth getting??
The price is good,the accessories rock,it's a XR looks like a good bike.
What would you do if you weren't afraid?
Bobcat Goldthwait is my mentor.
8lives is offline   Reply With Quote
Times are GMT -7.   It's 05:22 PM.
