Old 05-15-2013, 04:09 PM   #17026
FlyGuy
MachineHead
FlyGuy's Avatar
Oddometer: 168
Originally Posted by BuRPsa View Post
FlyGuy,
I think 11:1 is too high to expect infinite reliability, and 14KMi is a lot already.
I got same piston (not installed yet) but a 10.5:1, ceramic coated too, in all better and more reliable I think.
The hotspot sits in-line with the sparkplug it seems - not a too hot grade used? And, what coolant do you use?
Using one step cooler spark plug than recomended, I have been using pre mixed honda (automotive blue) coolant. The tempature stayed below 210f But my cooling fan was fairly running constantly (might have been a help)
I will post a different picture showing a crack on the other side of the wrist pin boss to crown area
I believe the design could easly be improved and still be light, but the XR is not popular enough for ross to get involved?
Additional fillet size is in order at the pin boss to crown
I am now going to contact wossner I like there design alot, take a look at the rotatable picture in the link below of there xr 650 piston
http://www.wossnerpistons.com/images...WOS-8575DA.swf
I am not complaining, as for miles I live in a different neighborhood than you. In KMI there was 22,500 kmi of fun filled riding on the ross piston
FlyGuy is offline   Reply With Quote
Old 05-15-2013, 04:31 PM   #17027
FlyGuy
MachineHead
FlyGuy's Avatar
Oddometer: 168
Originally Posted by ZXRaziel View Post
Flyguy , that looks like a metal casting fault , its rare but it does happpen sometimes , i have seen this before ( wiseco if i remember correctly ) . Just a bad luck really , i bet if you buy another one it would be fine , but then of course heavyer piston ( with more material /alloy ) should be stronger more reliable . Reliability its good .
But i think the JE and wiseco are way too heavy , more than the stocker ,
i think i will give the Ross piston a try at my next rebuild , i want to know what is the difference when running light high comp piston
Well Id bet its a cyclical load issue due to flex
I am also familyer of the weisco issues where the metal on the inside looked marbled indicating impurities and what you indicate happens as a cause.
but look at the picture in my post above and it becomes more clear.
And Hell ya go for the light weight and you wont go back.
but check out worrsner pistons too. I am going to try to find out there piston weights
Old 05-15-2013, 07:49 PM   #17028
rpmwfo
Oddometer: 134
Based on Flyguy's info, I am going to pass on the Ross piston. I like the lighter weight, but it appears to be just too light for longevity. I agree with the cyclic fatigue from the pics.
I do like the looks of the Wossner piston. I too would be curious about the weight of the piston relative to stock.
2007 XR650R Plated/2004 KX500 Plated/2007 KTM 450 EXC with 540 kit/2012 R6/2013 KTM RC8R
rpmwfo is offline   Reply With Quote
Old 05-15-2013, 09:32 PM   #17029
rpmwfo
Oddometer: 134
http://www.wossnerpistons.com/images...WOS-8718DA.swf
This is the Wossner link for their 11:1 piston. Different design than their 10:1.
Old 05-16-2013, 03:59 AM   #17030
ZXRaziel
ZXRaziel's Avatar
Location: Grey skyes and rain of Good old England ( NEast)
Oddometer: 504
I have looked at the pictures again , and you are right . there is not enough material in the critical areas and the flexing eventualy crack the piston . I like Woesner a lot and they are not overpriced , do you know how much is the weight ? ( i cannot find it nowhere to compare to the others ) .
good things them hondas
ZXRaziel is offline   Reply With Quote
Old 05-16-2013, 07:22 AM   #17031
crypto666
Oddometer: 1,282
Originally Posted by rpmwfo View Post
I'm looking to get more power out of the bike(I ride from 5000' - 10000'). The elevation takes a toll on power output. I would like to turn the bike into a lightweight adv/dual sport bike. I'd like to run 15/45 gears. Maybe a rekluse to help the tall first gear. I don't plan to be riding too much single track with it, but might be nice to if I fun across a great trail somewhere.
Currently planning to build up the motor on my BRP. Thinking about doing the following:
-XRsonly 11:1 coated piston
-HRC Cam- found one, hopefully it gets here soon, if not I guess I will go with the first Web cam listed on their site
-Kibblewhite black diamond valves and springs- Going stock size
-New cam chain
-Changing from Big Gun full system to XRsonly LE race system with the reverse megaphone design.
Any advice on the above?
Buy the best connecting rod you can find, that is the weak link in that motor. Falicon are nice.
crypto666 is offline   Reply With Quote
Old 05-16-2013, 09:55 AM   #17032
XFanMan
XFanMan's Avatar
Oddometer: 339
Stock Tank Thickness
Anyone ever cut a stock tank apart and happen to know roughly how thick the plastic is at the tank top? I'm thinking about sinking a couple of capture nuts into the top edge of the tank (right under the sides of the seat) for my Sumo project. It looks plenty thick enough in the center where the seat bolt goes in but I'm not certain about the edges. I don't really want to put daylight into it if I can avoid it
SCOTT---BIG DREAMS - small wallet
KTM Superduke R, Honda XR650R, Triumph Trophy
XFanMan is offline   Reply With Quote
Old 05-16-2013, 11:16 AM   #17033
crypto666
Oddometer: 1,282
I just checked and too have Ross 11:1 in my bike, for probably close to +5k miles, but its a 102mm. Hopefully that failure isn't common.
Old 05-16-2013, 11:49 AM   #17034
BikePilot
BikePilot's Avatar
Oddometer: 11,251
FWIW I don't think 11:1 compression, even on a bore/stroke combo this large, is necessarily problematic so long as there is no detonation problem or engineering weaknesses. As an example, my old porsche 968 has a 3.0L 4cyl motor with 11:1 CR, 104mm bores and 88mm strokes. Mine has 150k miles on it now and runs just dandy. Rev range is also fairly close to that of the XR. (there are of course lots of other examples, street bikes, etc. as well).
'09 Buell XB12XT, TL1000S, H1F, M620, CR250R, KX100, XR650R, Cota 315R
Summer 2009 Ride Report http://advrider.com/forums/showthrea...1509c&t=507038
Summer 2008 RR. http://www.advrider.com/forums/showthread.php?t=367703
BikePilot is offline   Reply With Quote
Old 05-16-2013, 12:00 PM   #17035
crypto666
Oddometer: 1,282
I agree, if it still runs on pump gas, its probably not wound too tight.
Old 05-16-2013, 01:40 PM   #17036
BuRPsa
Finally growing up..
BuRPsa's Avatar
Oddometer: 548
Come on BikePilot,
and nice car so btw, but that engine has a large part of the combustion chamber in the piston crown, a large indentation, plus it is a blown engine - hence it follows that those are hardly the lightweight piston type as the above Ross is, so that apple-pear comparison aint valid. Also, that engine's way better cooled than our pigs, marginal springs to mind.
FG,
nice pistons indeed - keep us updated if you buy one please?
BuRPsa is offline   Reply With Quote
Old 05-16-2013, 04:17 PM   #17037
slickwill
Exhiled
Oddometer: 209
Right on both points.
Sent from my DROIDX using Tapatalk 2
slickwill is offline   Reply With Quote
Old 05-16-2013, 06:42 PM   #17038
cragdweller
Oddometer: 30
Detonation causes cracked pistons. Overheating can contribute to this, but I would look at fueling (both mixture and grade) and timing first. That piston died from detonation.
cragdweller is offline   Reply With Quote
Old 05-17-2013, 08:34 AM   #17039
BuRPsa
BuRPsa's Avatar
Oddometer: 548
Actually that was my first thought too, hence my Q's.
I believe the octane rating in the US isn't too high, so was surprised to see 11:1 mentioned. Here we've got 95, and my CRF230 with a 11:1 piston in pings low down when hot and loaded. Being aircooled this may be expected, accepted even as long as you pay attention, but on the big one I'd stay away from it. This is why I bought a 10.5:1, after all I'm not racing it.
FlyGuy may want to look, with a timing light, at the ignition. Maybe it's out a little, a worn key maybe? Check anyway, if it pings the best piston will give way..
Old 05-17-2013, 09:18 AM   #17040
jules083
jules083's Avatar
Oddometer: 3,896
Installing new swingarm, shock, and linkage bearings tonight. Obviously fill the bearing with grease, but should I put anti-seize on the outside of the bearing or just more grease?
I have the honda shop manual so hopefully I don't have any surprises.
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
COBDR and UTBDR on my klx250:
http://advrider.com/forums/showthread.php?t=1003485
jules083 is online now   Reply With Quote
Times are GMT -7.   It's 12:38 AM.
