Old 05-17-2013, 02:16 PM   #17041
BikePilot
BikePilot's Avatar
Oddometer: 11,251
Originally Posted by BuRPsa View Post
Come on BikePilot,
and nice car so btw, but that engine has a large part of the combustion chamber in the piston crown, a large indentation, plus it is a blown engine - hence it follows that those are hardly the lightweight piston type as the above Ross is, so that apple-pear comparison aint valid. Also, that engine's way better cooled than our pigs, marginal springs to mind.
FG,
nice pistons indeed - keep us updated if you buy one please?
I think Porsche made 14 blown 968s, which, sadly, mine is not. It's N/A. I wouldn't call the XR650Rs piston a lightweight type piston, but that's a relative thing I suppose. Anyway, just one datapoint.
US octane is roughly the same as ROW, it's just commonly measured differently.
'09 Buell XB12XT, TL1000S, H1F, M620, CR250R, KX100, XR650R, Cota 315R
Summer 2009 Ride Report http://advrider.com/forums/showthrea...1509c&t=507038
Summer 2008 RR. http://www.advrider.com/forums/showthread.php?t=367703
BikePilot is offline   Reply With Quote
Old 05-17-2013, 06:11 PM   #17042
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,043
The problem with the XRs bottom end isn't the rod, Honda had a run of poorly built cranks that caused a failure of the Big end thrust washers. Plenty of SM guys run them much harder than we do. Once the washers start going bad it's a very short time before the bottom end follows. Results are the same though, once it happens the bottom end is toast.
Chris
"Life's journey is not to arrive at the grave safely in a well preserved body, but to rather skid in sideways, totally worn out, shouting ... Holy Shit, what a ride!"
CL Adventure Ride 2013 /CL Revisited 2014 / 700 Miles of Scenic Utah Backcountry / MY VIDEOS / RIDEFREAK TV
RideFreak is offline   Reply With Quote
Old 05-17-2013, 07:31 PM   #17043
Jayrod1318
Poster
Jayrod1318's Avatar
Oddometer: 1,618
I sure hope I don't have a bad one!
Jayrod1318 is offline   Reply With Quote
Old 05-18-2013, 08:12 AM   #17044
crypto666
Oddometer: 1,261
Remember the years?
Mine was failing at the small end, as have a number I have seen on here and elswhere.
Most likely a product of inexperience and lugging the motor too much, and opposite of what the sumo guys are doing to the engine.
So I guess it is prone to failure at high and low speeds, atleast on certain years?
crypto666 is offline   Reply With Quote
Old 05-18-2013, 08:50 AM   #17045
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,043
Originally Posted by crypto666 View Post
Remember the years?
It seems to be the earlier ones from what I can tell, but there's been a couple cases of it occurring on some newer ones too, even early enough to have a few fixed by the dlr but no recall. I heard it's a tolerance issue when the crank is pressed together at the factory. Seems that would be easy enough to check prior to assembly. If one is lucky enough, they notice flakes of babbet in the filter which is the thrust washer material. It doesn't take long for them to deteriorate once it starts, then the oil pressure drops. Sometimes this is followed by a big vent hole in the case if being run hard. I wouldn't call it a problem though, there was allot of XRRs sold and by far it's a very reliable motor. Luggin 'em isn't good but lets face it, you can't ride it fast all the time (at least I can't) and as far as I know, the problem isn't related to a type of riding. I think the lugging is hardest on the cam chain.
Chris
Old 05-18-2013, 09:54 AM   #17046
crypto666
Oddometer: 1,261
God damn, that makes me worried. I don't remember checking the side gap on my rod after getting it pressed together. I just remember the shop telling me the number and it being in between the specs, so I took their word for it, and I am pretty sure its good.
The reason I blame lugging on small end failures, and I am sure its bad for the cam chain as well, is because of oil jet that lubes the small end. I assume that at low speeds it has a hard time squirting oil all the way up to the wrist pin. I have no proof, but it was the only thing I could come up with for the failure, besides that it uses a bronze bushing instead of rollers. My motor was not even close to wore out in any other area, just the small end and a hole in the case.
Old 05-18-2013, 10:31 AM   #17047
Cpt. Ron
Advrider #128
Cpt. Ron's Avatar
Oddometer: 3,295
Engine Lugging/Engine Damage
Lugging is a relative term, obviously. It's different for different engine configurations. Generally it's running an engine at low rpms while under a load. To go a given speed, a certain amount of energy-per-time (work) needs to put through the motor through the transmission to the ground. When 'lugging", you're causing that amount of work to be done on few cycles (rotations) of the piston/crankshaft assembly. Think of riding a bicycle. It's easier to pull shorter gears (higher rpms) than taller ones. With tall gears, you have to really push on the pedals to go slow. Now think of your piston and crank assembly doing the same thing while you're lugging your motor. All that pressure on the piston crown, piston pin and big end on the connecting rod is just like your quads trying to push the pedal down. The oil film can only handle so much pressure before collapsing and causing metal-to-metal contact. Plus, at lower rpms the oil film will have more time to collapse than at higher rpms.
Cpt. Ron
"I don't know what you do, but I know what I do, and I don't do that." --Uncle Doug, R.I.P.
"Without the possibility of death, adventure is not possible"--Reinhold Messner
Cpt. Ron is offline   Reply With Quote
Old 05-18-2013, 12:04 PM   #17048
Jayrod1318
Poster
Jayrod1318's Avatar
Oddometer: 1,618
And I'm the guy with a low mileage 2001 that has high Iron, copper and silver content in the oil.
I'm remembering my first oil change where I cleaned the strainer in the frame. It had a bunch of of metal bits, did'nt pay much attention to it. I'm almost certain it was the first time it had ever been cleaned so i just figured it was production shavings left behind. (the frame oil reservoir is after the oil filter correct?) No way bottom end bits would end up in the frame unless there was a filter failure.
Next change I'm going to cut apart my filter to inspect and clean the strainer in the frame......
Old 05-18-2013, 05:52 PM   #17049
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,043
Like I said, it's not what I'd call a common failure, I'm not trying to scare anyone, the XR motor is uber relaible compared to many others.
Ron, that's a great explanation of lubrication's characteristics and I think you're right on the money with it's effects. It sounds like a plausable cause for crypto's prob. The plain brg in the small end is a proven design but there is allot of mass in the crank/rod/piston assy on a 650. Lugging definately taxes the brg areas.
Chris
Old 05-19-2013, 06:50 AM   #17050
BuRPsa
Finally growing up..
BuRPsa's Avatar
Oddometer: 548
Oh yes there is. The scavenging pump will pump unfiltered oil in the frame, the only protection - sortof - is the secondary screen.
The frame's strainer you should inspect on every oilchange, quick & easy. But I gather you've never had a look at the secondary one, in the motor behind the clutch? If not doing that is a good idea
BuRPsa is offline   Reply With Quote
Old 05-19-2013, 07:06 AM   #17051
mazman808
Oddometer: 100
Hey guys.
Got a question, anyone have or is using a rekluse EXP 2.0 auto clutch on they're xrr?
I had it adjusted per instructions, and even adjusted it at the very end scale of being in auto mode(clutch almost grabbing to a point you have to almost apply the brakes so it doesnt creep forward, but im not liking it.
Its great for uphills/tight single tracks but thats about it, because to me the clutch slips too much for anything else.
In the dirt, you almost think its just the tyres spinning from having no grip, but i then went on pavement to double check and sure enough it slips a fair bit.
Here is how i would explain it.
Say im cruising in 3rd gear ( but this happens in any gear) and i go to give it (wide open throttle), immidiatly the revs sky rocket high but bike goes nowhere(slipping), this takes a good 2seconds at least and then slowly you can feel the clucth catching up(starting to grip), but that catching up also takes a good few seconds.
I cant do wheelies anymore with just powering it like i use to, doing jumps is harder, taking off quickly is bad and the worst part is, i also use it as a motard( i have both setups that i change to) and use it at race tracks and it sucks exiting corners or overtaking someone etc...
Ive double checked my adjsutment and cant see anything wrong, ive put the strongest springs that come with it and i dont have this issue when i remove the Rekluse EXP out of the system.
Is this normal for a rekluse auto clutch? or can it simply not handle the torque of the xrr?
Its modded with full exhaust, tm40 carby, stage 1 cam, air box modded.
cheers
mazman808 is offline   Reply With Quote
Old 05-19-2013, 07:09 AM   #17052
ZXRaziel
ZXRaziel's Avatar
Location: Grey skyes and rain of Good old England ( NEast)
Oddometer: 477
Originally Posted by mazman808 View Post
Hey guys.
cheers
That sounds like something is wrong , make sure that you have assembed it correctly .
good things them hondas
ZXRaziel is offline   Reply With Quote
Old 05-19-2013, 08:45 AM   #17053
FlyGuy
MachineHead
FlyGuy's Avatar
Oddometer: 165
You may have a problem there?
If residual machine bits from initial assembly they would most likely be of aluminum.
you would be looking for gold color in in your screens or in the bottom of the case.
From the top on the picture above
Scavenge (square filter guessing 120 micron) filter this the first line of defense it filters before the scavenge pump this is where to look if the debris is fairly large and if there was debris in filter #2 (like you)
the center down tube filter (#2) is additional scavenge filtering(suspect 80 micron)
and in addition it prevents crap that can enter the fill point.
your case may be just that? (poor dip stick hygiene?)
The third filter is after the main oil pump and in the picture is a 35 micron filter it it what supply's the engine it catches all the small stuff (usually the first filter to check)
Hope that helps, I noted on your oil analyses that it had elevated copper?
you are suspect
FlyGuy is offline   Reply With Quote
Old 05-19-2013, 06:20 PM   #17054
slickwill
Exhiled
Oddometer: 209
I should have clarified when I agreed with "rod issues" that it is the big end bearing in the rod that I and my friend have both had issues with. As noted we are both "sumo guys." My bike started its life as Johnny Campbell's BITD bike but it has made an excellent supermoto. I lost the big end bearing at a track day at Grattan. My friend lost his big end bearing on the same track two years earlier. Both of us rebuilt with full Falicon Supercrank mod with Falicon rod. He's got hundreds of track day miles and thousands of street miles since then. I've got 20ish supermoto sprint races and 1500ish street miles since then on a pretty hot engine build. I don't know how much use the engine had before I bought it but I put 5k+ street miles on it and did a few track days before it popped. Hopefully I get a bit more life out of it this time.
slickwill is offline   Reply With Quote
Old 05-19-2013, 08:35 PM   #17055
jwalters
Farkle Proliferator
jwalters's Avatar
Oddometer: 2,289
Well, it's been a few weeks since I got my carb sorted and I had a chance to put some miles on the bike and make a few more changes. Burpsa, you sir, were correct. Dropping the needle cured most of the studdering, but I ended up going from a 175 to a 165. It's still a bit on the the rich side, but that's just fine! Running great now. Thanks again. -JW
Jesse,
if an engine 'spudders' then it is running really rich, and the solution is to reduce a jet, not merely dropping the needle. It may feel fine now but I bet it still runs rich, your exhaust telling telltales.
I'd put in (with clean filter, set valves etc) the 68S, set the needle to 'mid' and drop the main size-by-size until you feel it is too small - then use the averaged size with your current one which should put you in the ballpark. Only then finetune the needle.
Of course this is a rough way of jetting, the best is to hook up an analyser on a dyno, however it will work.
Minnesota North Shore Shindig 10-13 September 2015 -- Finland, MN
Proliferator of Farkles of Mass Percussion
jwalters is offline   Reply With Quote
Times are GMT -7.   It's 10:40 AM.
