Old 05-21-2013, 05:16 PM   #17071
graygoat657
Oddometer: 308
Originally Posted by Rydah View Post
Ok, need a better headlight, but can't afford most of the aftermarket stuff. Would like to find a decent stock headlight from some other model bike that puts out good amount of light, with a good light pattern. I'll find a way to mount it up. Thinking something like the KTM 950 would be perfect, with the vertical mounted arrangement, but any ol' light will do. Anyone done this, or any suggestions?
What's your budget?
graygoat657 is offline   Reply With Quote
Old 05-21-2013, 06:09 PM   #17072
Jayrod1318
Poster
Jayrod1318's Avatar
Oddometer: 1,622
I run the dual filament hi/lo 55w bulb? in the stock housing with the stock stator. works pretty good when aimed correctly. And WAAy brighter than the stock bulb. I forget the number but it is the Yamaha Banshee bulb. this is a bright white version http://www.rockymountainatvmc.com/p/...per-White-Bulb
It was the cost of the bulb, some solder to solder the 2 contacts together on the base of the bulb. $9.00
There also is a honda part number for a glass version of the stock lense assembly, I think I priced it and it was around $40 bucks or so. Forgot the cross reference on it but I think its form another XR.... I would imagine its a slight improvement over the plastic version.
so if you haven't already.............. try the bigger bulb trick for ultimate low cost improvement!
Jayrod1318 screwed with this post 05-21-2013 at 06:15 PM
Jayrod1318 is offline   Reply With Quote
Old 05-22-2013, 09:21 PM   #17073
FlyGuy
MachineHead
FlyGuy's Avatar
Oddometer: 168
FlyGuy goes with wossner pistons
I had previously used the ROSS piston I purchased from XRs only.
I had accumulated approximately 14,000 mi or (22,500 kmi) of adventure fun with the ross piston and was surprised of how well it made the bike run.
I knew my luck would run out on this engine some day and it finally did
The ross piston cracked and the XR turned into a oil pumping smoking train.
The bike still ran so I tried to limp it home some 120 miles away
I added oil at he first notice of the problem (unaware of the actual problem), and kept adding oil till I went through one quart in 6 miles where I threw in the towel due to a hard start (leg failure) some 60 miles later
I made it the additional 60 miles running high oil temp 250f and no higher than 210f on the coolant
(I was happy to have a add on fan as it was running constantly) It was a long day.
Back at home the XR got disassembled to reveal the the problems.
Some may say detonation killed the ross piston, but I won't say it never detonated. but there is no heat signature I can find that would indicate a detonation issue..
The burned look is from trying to get home with a crack through the piston crown, as well it yellowed the entire inside of the engine with burnt oil.
When a single cylinder engine detonates its usually noted with a power loss and jerkie operation.
It is my opinion the Ross piston died of cyclical flexing from high cylinder pressures
Now I compare the two pistons to decide what to do
the wossner piston is more than ⅓ thicker through the crown measuring .280 thousands (top of piston to underside)
the ross piston measured .180 thousands and this is not where the valve reliefs are the ross is very thin where the reliefs are. ross uses a unibrow?
the wossner measures .980 across the inside pin bosses
the ross measures 1.175
I am pointing to the difference.
the wossner pin is a tapered wall with a main wall thickness of .165
the ross is .147
These three things will help the flex issue,the crown thickness is a big one
In addition the wossner is Teflon coated and uses a thinner ring pack
So what does it weigh with pin rings and clips
that's 12 grams more than the ross but 60 grams lighter than stock
there are more things i like about this piston but i don't want to bore ya
i might comment on the rod as mine is due and i plan to keep track of the weights here too
FlyGuy is offline   Reply With Quote
Old 05-22-2013, 10:21 PM   #17074
tijuana
Farkling Around
tijuana's Avatar
Oddometer: 204
Call me
See signature and keep R alive!
Carry Parts and Gear...
2000 XR650R Dualsport
www.bajastarz.com
http://www.bikebandit.com Need parts or gear? Call me at 1-888-339-3888 ext 343
tijuana is offline   Reply With Quote
Old 05-23-2013, 04:22 AM   #17075
ZXRaziel
ZXRaziel's Avatar
Location: Grey skyes and rain of Good old England ( NEast)
Oddometer: 501
the ross is .147
Thanx for the good information
good things them hondas
ZXRaziel screwed with this post 05-23-2013 at 12:48 PM
ZXRaziel is offline   Reply With Quote
Old 05-23-2013, 07:33 AM   #17076
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,127
It's definately not detonation, it's very obvious when you take apart a motor that suffers from premature ignition (det.) it will appear sandblasted around the outer edges getting worse the further out on the crown and I doubt you'd see that much carbon buildup ether.
I suspect it started off as a casting imperfection in the piston alloy. The scenerio your painting says the design isn't up to the job. I sorta doubt that, there's plenty of race bikes using Ross pistons without this problem or piston failures.
Have you tried to get them (Ross) to replace it or shown them these pictures? I would, you might be surprised.
Chris
"Life's journey is not to arrive at the grave safely in a well preserved body, but to rather skid in sideways, totally worn out, shouting ... Holy Shit, what a ride!"
CL Adventure Ride 2013 /CL Revisited 2014 / 700 Miles of Scenic Utah Backcountry / MY VIDEOS / RIDEFREAK TV
RideFreak is offline   Reply With Quote
Old 05-23-2013, 08:13 AM   #17077
ZXRaziel
ZXRaziel's Avatar
Oddometer: 501
To be fair , the piston did fair amount of work ( miles ) , especialy considering that its a light weight high compression ( call it racing if you like ) , that is respectable result and certainly not a bad quality part , i have seen parts failing much quicker than that . And light weight piston puts less stress on other parts - they last longer , its easy and cheap to replace piston
Old 05-23-2013, 08:41 AM   #17078
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,127
You def caught it at the right time, could have been ugly
Chris
Old 05-23-2013, 10:43 AM   #17079
galland1
galland1's Avatar
Oddometer: 112
Anyone use a 70s pilot jet?
Sent from my SPH-L720 using Tapatalk 2
galland1 is offline   Reply With Quote
Old 05-23-2013, 11:59 AM   #17080
ThereisnoSpoon
High Enough
ThereisnoSpoon's Avatar
Oddometer: 1,805
Yes
German Wall of Death Certified
ThereisnoSpoon is offline   Reply With Quote
Old 05-23-2013, 05:49 PM   #17081
Adamco2
Part time adventurer
Adamco2's Avatar
Oddometer: 127
I run a 72 and am going to try a 75.
Adamco2 is offline   Reply With Quote
Old 05-23-2013, 07:20 PM   #17082
jm-2008
jm-2008's Avatar
Oddometer: 512
Piston Weights - Balance?
[QUOTE=FlyGuy;21471823]FlyGuy goes with wossner pistons
the ross is .147
What effect, has the change in weight had on balance factor?
Appreciate the benefits of minimising reciprocating masses however am interested in changes to the balance factor, or have all the inmates that have changed pistons had the crank and associated parts re-balanced?
Just curious
jm-2008 is offline   Reply With Quote
Old 05-23-2013, 10:00 PM   #17083
Cpt. Ron
Advrider #128
Cpt. Ron's Avatar
Oddometer: 3,296
Maybe the bigger question is, has anyone who HASN'T done a piston change (from OEM) had this happen? Which then leads to, why change to a lighter piston? Being an engineer, I appreciate the idea for reducing the reciprocating mass: quicker acceleration, less stress on attached members etc....For stuff like supermoto I get it. The littlest advantage can make a big difference.
But I haven't been spanked by a modified BRP nor a stock one (stock meaning un-corked here) in the type of riding I do. Within the confines of the OEM covers on my bike, it's all stock. I've ridden with plenty of other BRP riders, and we all have our strengths and weaknesses. None of us have ever thought that the power of the bike held us back (suspension not withstanding....). The stock power plant leaves most mortals going "Holyyyyy Shittttttt" when they twist the throttle. The big differences seem to come in the tuning and rideability of the bike. If it doesn't work, no amount of power will save you. In my mind, it's the total package that matters.
For my dual sport riding and occasional cross-country race, as well as the Kings of the West Rally, the stock internals of the motor work for me. They get me to the beginning AND the end of the event. About the only thing I'd consider changing from OEM is the intake valves for more longevity.
But hey, that's just me.
Cpt. Ron
"I don't know what you do, but I know what I do, and I don't do that." --Uncle Doug, R.I.P.
"Without the possibility of death, adventure is not possible"--Reinhold Messner
Cpt. Ron is offline   Reply With Quote
Old 05-24-2013, 09:32 AM   #17084
KYLEISCOOL
Who
KYLEISCOOL's Avatar
Oddometer: 144
^^^ +10 with you Ron. I totally concur and the thoughts of having to push my bike from places I go... No thanks. Longevity & Reliability is my main key in a bike. Hence why im sticking with the piggy not going to the more modern "race" type bikes. I can adjust my valves in the middle of BFE in a half hour and be on my way again if need be.
Gotta ride something! 02' XR650R slightly personalized
KYLEISCOOL is offline   Reply With Quote
Old 05-24-2013, 10:46 AM   #17085
bill pierce
I don't wana pickle
bill pierce's Avatar
Oddometer: 741
What. Kind of life span are you guys getting out of a set of valves??
bikes
BMW R1100s,destroyed by deer strike.
Yamaha FZR 1000 (sold)
Honda Cr 500 sold
bill pierce is offline   Reply With Quote
Times are GMT -7.   It's 02:13 AM.
