Old 06-14-2013, 03:10 PM   #17281
Woundflatout
Woundflatout's Avatar
Oddometer: 499
Originally Posted by sintax View Post
I've been running Rotella T6 in my bike for a couple of years now. I always have it on hand because thats what I run in my Chevy Duramax.
I do seem to burn a bit of oil? Maybe its in my head?
It's also the oil of choice for KTM factory riders...quality stuff for the fragile orange motors! ;)
Jason Slutsky
PROUD TO BE RIFF RAFF
'09 Husaberg FE570
Rallymoto #159
Woundflatout is offline   Reply With Quote
Old 06-14-2013, 04:57 PM   #17282
sintax
Oddometer: 495
I posted a few odds and ends for sale in the Parts section if anyone is interested...
devol rad guards and Xr's only case saver
sintax is offline   Reply With Quote
Old 06-15-2013, 04:24 AM   #17283
slickwill
Exhiled
Oddometer: 209
That's also what I run. I did A LOT of oil research a few years back and started digging into all of the spec sheets and when you look at the numbers it really is impressive stuff. Then to prove it I thrashed a sample in my CBR600 for 3k miles and included a couple track days. Then I sent it to Blackstone for analysis and it still came back with better numbers than some of the competitors have when new.
The thumper is hard on oil in some different ways but I have no doubt that the Rotella is working based on what I saw in the other bike.
slickwill is offline   Reply With Quote
Old 06-15-2013, 08:40 AM   #17284
cognugget
cognugget's Avatar
Oddometer: 243
I run rotella T3 in everything! 2 stroke gear boxes, my xr650r, any other bike I work on, My old toyota 22r...... It just does everything
Plated XR650R
cognugget is offline   Reply With Quote
Old 06-15-2013, 08:51 AM   #17285
Jayrod1318
Poster
Jayrod1318's Avatar
Oddometer: 1,642
The regular dino Rotella T has worked fine and still had life left in it after 1000 miles but its was getting out of spec viscosity wise. Nothing that would damage anything, but my shifting and clutch feel go to shit when the oil gets about 800-1000 miles on it. The T6 is supposed to be more shear stable. If i can get it to hold viscocity wise for 1,500-2k I'm going to be a happy camper because I have other things to do besides having to change the oil because i don't like how my clutch and shifting feel.
Jayrod1318 is offline   Reply With Quote
Old 06-15-2013, 12:05 PM   #17286
dogsslober
No neck tie, Ti neck
dogsslober's Avatar
Oddometer: 953
Battery box
Been toying with the idea of a better battery for my 650R than the nicad that came with a BD duel sport kit. Here the first try, will refine it a little more but I think I'm on the right track. Have to add small strap and a wire harness
dogsslober is offline   Reply With Quote
Old 06-15-2013, 12:36 PM   #17287
bill pierce
I don't wana pickle
bill pierce's Avatar
Oddometer: 741
I have the same battery. I ended up installing it under the rear fender.
bikes
BMW R1100s,destroyed by deer strike.
Yamaha FZR 1000 (sold)
Honda Cr 500 sold
bill pierce is offline   Reply With Quote
Old 06-15-2013, 11:42 PM   #17288
Chris_W_65
XR KILLER
Oddometer: 51
Do you have a rear hugger on there?
Chris_W_65 is offline   Reply With Quote
Old 06-16-2013, 12:08 AM   #17289
sintax
Oddometer: 495
whats the story on the battery?
any links to a spec sheet?
Old 06-16-2013, 01:01 AM   #17290
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,437
i went with this option
My bike was rewound to 200 watt ...running up to a reg/rec ..then all pwr to battery then everything runs of from there ...KISS
has been flawless ..I recommend these anit grav batts super light weight very small
reg/rec from a kwaka 1000
located behind the front fairing
Sean-0 is offline   Reply With Quote
Old 06-16-2013, 08:01 AM   #17291
bill pierce
I don't wana pickle
Oddometer: 741
Yup, works out great with the 17" wheels. I made it out of the old front fender.
bikes
Honda Cr 500 sold
Old 06-16-2013, 08:06 AM   #17292
bill pierce
I don't wana pickle
Oddometer: 741
Ballistic Batteries
Copied from the e-bay ad
Technical Information
  • Dimensions (Metric): 52MM(L) x 52MM(W) x 84MM(H)
  • Dimensions (Standard): 2" (L) x 2" (W) x 3.25" (H)
  • Negative Terminal Location: Right
  • Weight: 246 grams (.543 lb.)
  • Voltage (Charged): 13.6V
  • Amperage: 4Pb-eq/Ah
  • Pulse Cranking Amps: 80 CCA
  • Operating Environment: -18C (0F) to 60C (140F)
bikes
Honda Cr 500 sold
Old 06-16-2013, 08:07 AM   #17293
Chris_W_65
XR KILLER
Oddometer: 51
Great - I have been thinking of making something up for my SM
Old 06-16-2013, 08:26 AM   #17294
dogsslober
dogsslober's Avatar
Oddometer: 953
clearance
I would think your tire could hit that even with 17. I know it would get wiped out with the stock 18 off road
Old 06-16-2013, 08:36 AM   #17295
Chris_W_65
XR KILLER
Oddometer: 51
But maybe better than on the motor - I would think the heat would be bad for batteries.
I doubt my 17" would ever touch the fender, not with the riding I do.
Times are GMT -7.   It's 12:12 AM.
