Old 06-19-2013, 02:39 PM   #17326
crypto666
Oddometer: 1,329
Nothing like a $10 part destroying a $180 part. They have a way of doing that.
crypto666 is offline   Reply With Quote
Old 06-19-2013, 02:56 PM   #17327
Shibby!
Oddometer: 1,658
That 180$ part will likely cost triple that to replace, if not more.
Tour of Idaho T1 Challenge - https://spotwalla.com/tripViewer.php...551f1642711d75
Eat. Sleep. Ride - The Great Divide: http://advrider.com/forums/showthrea...4#post19193704
Go, Get Lost - Heading South: http://advrider.com/forums/showthread.php?t=735690
Dirt Donkeys Do Baja: http://advrider.com/forums/showthread.php?t=671095
Shibby! is offline   Reply With Quote
Old 06-19-2013, 03:03 PM   #17328
crypto666
Oddometer: 1,329
Oh yeh, thats right. You have to split the case. and as long as you are in there, notice the connecting rod bearings.........
Seriously, I would plan on replacing the c-rod while you are in there. Unless by some miracle it looks fantastic.
Old 06-19-2013, 03:18 PM   #17329
jm-2008
jm-2008's Avatar
Oddometer: 513
Cause of wear
Looks like it has had a lot of sprocket changes to cause that amount of wear.
Lots of rotation/mud or sand and long term worrying of the sprocket on the spline will likely cause the same result.
Does this tend to happen more regionally ie sandy or muddy areas, or from long term road miles.
Would be interested to know of any quantifiable data or feedback from inmates that have a lot of seat time on the XR in different areas.
Noting some wear would be expected but that does look significant
JM-2008
jm-2008 is offline   Reply With Quote
Old 06-19-2013, 07:48 PM   #17330
dohcfox
meh
dohcfox's Avatar
Oddometer: 150
I would submit that this damage is a result of high traction conditions, ie. asphalt or concrete. Sand, mud and dirt allow the rear wheel to absorb torque pulses from the motor because of how much slip there is between the tire and adjacent surface . When there is little or no slip, torque pulses are transmitted more harshly into things like sprockets and counter shafts.
JM-2008
Ser decente no cuesta un culo y queda uno putamente bien!
dohcfox is offline   Reply With Quote
Old 06-19-2013, 07:53 PM   #17331
Jayrod1318
Poster
Jayrod1318's Avatar
Oddometer: 1,640
Originally Posted by cognugget View Post
Oem will fit a 15t
I suck, I thought that's the reason they sold it as a "15t" case saver.
Jayrod1318 is offline   Reply With Quote
Old 06-19-2013, 10:17 PM   #17332
b45her
MotoJunkie
b45her's Avatar
Oddometer: 27
Yep the po has used this mainly for road riding. He had it from 2000 miles or so. It has had an easy life in terms of not been offroaded much but other things like the countershaft don't look too good. I plan on rebuilding and replacing this winter, would the road riding have done more internal damage do you think?
Sent from my GT-I9505 using Tapatalk 4 Beta
b45her is offline   Reply With Quote
Old 06-20-2013, 06:47 AM   #17333
crypto666
Oddometer: 1,329
For future reference, I would be careful buying motarded bikes. They may look clean, but the motor and drive has likely been put through the wringer, as we see above.
Old 06-20-2013, 07:03 AM   #17334
RdrMtn
RdrMtn's Avatar
Oddometer: 158
The OEM case saver, at least on US bikes, will not swallow a 15T without some grinding.
RdrMtn is offline   Reply With Quote
Old 06-20-2013, 10:11 AM   #17335
b45her
MotoJunkie
b45her's Avatar
Oddometer: 27
Definately, I got stung with this 1. My own fault for not checking really, but I have had 4 other xr's and none have ever had this issue.. oh well, its a good excuse for upgrades!
Old 06-20-2013, 10:27 AM   #17336
cognugget
cognugget's Avatar
Oddometer: 243
Not in my experience : I gave it some very very mild sanding...
Plated XR650R
cognugget is offline   Reply With Quote
Old 06-20-2013, 11:09 AM   #17337
spartanman
regret minimizer
spartanman's Avatar
Oddometer: 1,076
I didn't have the bog that everybody talks about with the stock carb. I changed mine because:
1) Softer transition from on/off throttle. Mine always liked to snap even when being very smooth.
2) Lighter throttle pull (Should I have gotten the "L" version??)
3) Gas mileage (30's jumped to 50's MPG)
4) Of course more precise jetting.
Mine still isn't jetted perfect, but it never is. Too much elevation change here and on my rides. It's worked from 0-10,000 ft. So I leave it =)
What carb did you switch to? What is your jetting now?
spartanman is offline   Reply With Quote
Old 06-20-2013, 12:27 PM   #17338
Shibby!
Oddometer: 1,658
TM-40.
I somewhat forget my jetting. I've been working on my dirt bike now so I'd probably get the two confused if I gave out recommendations. I have posted it here before though. I change elevation A LOT so jetting is never perfect. Everywhere from 2000-8000', and on my trips I've gone from 0-13,000.
Old 06-20-2013, 04:26 PM   #17339
sintax
Oddometer: 495
TM-40.
I've posted my TM-40 jetting on here as well. I dont recall Shibbys exactly, but I think I was in his ballpark.
I'm very happy with the TM-40 carb, with the exception of the last time I had it out in the desert I had some strange float / overflow deal. I went to fire it up and as soon as i took it off the the side stand it started puking fuel, and ended up doing it throughout the ride too.
I flogged it good though to show it who was boss. Beat 2 very good riders, one of which is a District 36 enduro rider to our first destination, and he was on a KTM 350exc.
sintax is offline   Reply With Quote
Old 06-20-2013, 04:28 PM   #17340
sintax
Oddometer: 495
Does anyone have a tanker brace they would willing to sell me? or rent? or something?
Mr Hodaka seems to be a ways out on getting them made and I really need one for my trip. I need to have my bike in a crate on a truck by end of July, so I dont think I can honestly wait for him.
I'll pay new price as long as its not all mangled
Times are GMT -7.   It's 01:15 AM.
