Old 06-23-2013, 09:54 AM   #17386
slabm7
Oddometer: 317
Originally Posted by Chris_W_65 View Post
You should take it off - give it to me
I would but you're in Souf Efrica, shipping you be a bitch.
03 Honda XR650R dual sported
1999 Honda VTR1000
Nobody EVER lies on their death bed and says "I should have worked more".
slabm7 screwed with this post 06-23-2013 at 10:00 AM
slabm7 is offline   Reply With Quote
Old 06-23-2013, 10:03 AM   #17387
stevh0
Super Retard.
stevh0's Avatar
Oddometer: 1,443
whats the easiest way to fit a keyed ignition? Bike needs to go for road worthy and I doubt they will pass it without.
06 950S, YZ250WR, 300 TXT Pro
Ex 1150GS, 650R, Ex 950SE, Ex 950ADV,Ex SM610, FS570, WR450, Africa Twin(s)
stevh0 is offline   Reply With Quote
Old 06-23-2013, 01:26 PM   #17388
Chris_W_65
XR KILLER
Oddometer: 51
I have one on my bike - I can take pics but everything is in pieces right now
Chris_W_65 is offline   Reply With Quote
Old 06-23-2013, 04:56 PM   #17389
smoothride
smoothride's Avatar
Oddometer: 231
Originally Posted by slabm7 View Post
I need some carb help guys, I recently installed a Mikuni TM40 and am having problems tuning it, the bike won't idle below 1800 rpm, as soon as it drops below that it sputters and quickly dies, the idle also hangs when I let off throttle, it will hand around 3000 and then very slowly drop. I have played with the idle adjustment and the pilot screw, also put in a larger pilot jet but I am not having much luck. Anyone have any ideas on where to look next?
Try putting a bigger pilot jet in I run a 27.5 pilot and a 140 main jet. Your bike sounds like it is leak on the pilot. Check the throttle cables for slack.
00 XR650R plated
08 DR650
smoothride is offline   Reply With Quote
Old 06-23-2013, 06:52 PM   #17390
ride4fun562
ride4fun562's Avatar
Oddometer: 207
Hey guys , this has probably been asked before but i just installed bar risers, i tried to re route the cables but it only worked for the clutch, the decomp cable is getting caught when i turn my bars to the right. Does anyone know if theres an oem decomp cable.from another bike thats an inch or two longer. I dont want to buy custom cables . Thanks in advance
ride4fun562 is offline   Reply With Quote
Old 06-23-2013, 07:05 PM   #17391
Adamco2
Part time adventurer
Adamco2's Avatar
Oddometer: 127
I rerouted mine like this
Adamco2 is offline   Reply With Quote
Old 06-23-2013, 07:24 PM   #17392
ride4fun562
Oddometer: 207
Honestly that will probably work but i have ocd about dumb stuff like that, itll annoy the heck outta me but if nobody knows of another cable that will work ill do that
Old 06-23-2013, 08:51 PM   #17393
Adamco2
Adamco2's Avatar
Oddometer: 127
I understand. That was a middle of nowhere fix that I have been to lazy/cheap to rectify.
Old 06-24-2013, 03:11 AM   #17394
BuRPsa
Finally growing up..
BuRPsa's Avatar
Oddometer: 548
... I doubt they will pass it without.
I don't, an ignition key's not mandatory - only a kill button which I presume you have.
BuRPsa is offline   Reply With Quote
Old 06-24-2013, 05:00 PM   #17395
bill pierce
I don't wana pickle
bill pierce's Avatar
Oddometer: 741
[QUOTE=stevh0;21707660]whats the easiest way to fit a keyed ignition? Bike needs to go for road worthy and I doubt they will pass it without.[/QUOTE
I used a Honda switch and a relay so it would be a little harder to steal. But just a switch that is open in the on position parallel to the kill button will work
bikes
BMW R1100s,destroyed by deer strike.
Yamaha FZR 1000 (sold)
Honda Cr 500 sold
bill pierce is offline   Reply With Quote
Old 06-25-2013, 08:14 AM   #17396
crypto666
Oddometer: 1,276
Dried blood on the tank and handle bars will keep people from stealing it too, maybe scatter some spent shell casing around the scene, a little yellow crime scene tape, the bike isn't going anywhere.
crypto666 is offline   Reply With Quote
Old 06-25-2013, 11:21 AM   #17397
stevh0
Super Retard.
stevh0's Avatar
Oddometer: 1,443
meh,my indicators on the pig is dead. I've got a broken rear turn signal too. Could this be the reason that none are working?
Old 06-25-2013, 11:22 AM   #17398
stevh0
Super Retard.
stevh0's Avatar
Oddometer: 1,443
[QUOTE=bill pierce;21717666]
Thanks bud!
Old 06-25-2013, 12:06 PM   #17399
crypto666
Oddometer: 1,276
Yes, most likely,
Old 06-25-2013, 09:49 PM   #17400
Gunga Galunga
Gunga Galunga's Avatar
Oddometer: 230
Bill Pierce
Since I'm a simpleton, do I understand to add the switch before the kill button?
Thanks.
2001 Honda XR650R (Plated)
1992 Yamaha WR500ZD
Gunga Galunga is offline   Reply With Quote
Times are GMT -7.   It's 02:04 AM.
