Old 06-26-2013, 07:02 AM   #17401
crypto666
Oddometer: 1,449
[QUOTE=Gunga Galunga;21728140]
Originally Posted by bill pierce View Post
Since I'm a simpleton, do I understand to add the switch before the kill button?
Thanks.
It is before, but electrically its at the same time. Imagine instead of using the kill switch, which sends the coil power to ground, you stripped the wire and ground it before it gets to the handle bars.
Hello Kitty stickers also make your bike less likely to be stolen, and increase the chance of passing inspections.
crypto666 is offline   Reply With Quote
Old 06-26-2013, 08:49 AM   #17402
bill pierce
I don't wana pickle
bill pierce's Avatar
Oddometer: 741
[QUOTE=crypto666;21730057Since I'm a simpleton, do I understand to add the switch before the kill button?]
I have been a industrial control electrician for 35 years. I do understand series and parallel circuits.
Because the circuit grounds the ignition it would be a parallel circuit. Putting the switch before the kill button would be a series circuit. Therefore it would not kill the bike.
If you don't feel foolish you should.
bikes
BMW R1100s,destroyed by deer strike.
Yamaha FZR 1000 (sold)
Honda Cr 500 sold
bill pierce is offline   Reply With Quote
Old 06-26-2013, 09:05 AM   #17403
crypto666
Oddometer: 1,449
[QUOTE=bill pierce;21730923]
Originally Posted by crypto666;21730057Since I'm a simpleton, do I understand to add the switch before the kill button?
A switch in series with the kill switch won't do anything but disable your kill switch. Switches in parallel share common nodes and are redundent performing the same function.
No, I do not feel foolish, but you should since this is not the XRR electrical thread.
Old 06-26-2013, 09:23 AM   #17404
Chris_W_65
XR KILLER
Oddometer: 51
[QUOTE=crypto666;21730057]
I won't put any kitty stickers on my bike or BuRPsa's dogs might attack me
Come to think of it BuRPsa might attack me himself because my BRP is a motard
Chris_W_65 is offline   Reply With Quote
Old 06-26-2013, 09:40 AM   #17405
Chris_W_65
XR KILLER
Oddometer: 51
Decompressor
Is it rocket science to take the auto decompressor apart and assemble it again?
Old 06-26-2013, 10:50 AM   #17406
DocAxeYarYar
RideDualSport.com
DocAxeYarYar's Avatar
Oddometer: 788
2060 Mile Trip - Oil and Gas Consumption
Dudes, just go back from 2060 mile Gunslinger's Divide Ride up and down the length of New Mexico. My XRR was flawless the whole time. 1-3 kicks to start it, never missed a beat!
Wondering how my oil consumption and MPG compares to others?
Oil - Every 700-750 I added 1/4 quart. It was about mid-way on the dipstick and 1/4 quart brought it right up to full. Sound about right? My buddy's KTM was using about double that.
Down side: Was not able to change my oil, so ran it way past the 1,000 mile point, but the oil still looks quite clean. Oh well....
Gas - About 35-40 MPG depending on riding conditions. The bike does run a tad rich, but I dont mind that since its better than too lean. Plug never fouled and was never hard to start.
Gearing - STOCK 14/48. Worked well, while I considered a 45 tooth rear, I did not seem to really need it. The stock gearing was great in some tricky situations (see pic) where the extra grunt was welcome. Generally on the road and straight fire roads we cruised at 60 MPH.
Valves: Checked before the trip only adjusted one, so will check and see if they have tightend up.
This was my first major trip on the bike, and I loved it. Super reliable, great handling, rock solid!
My XR650R Build:
http://ridedualsport.com/forum/index.php?topic=2748.0
DocAxeYarYar is offline   Reply With Quote
Old 06-26-2013, 11:34 AM   #17407
Gunga Galunga
Gunga Galunga's Avatar
Oddometer: 228
Thanks for the info, hope the ride was good, I need to read your dualsport writeup as I am in the process as well.
2001 Honda XR650R (Plated)
1992 Yamaha WR500ZD
Gunga Galunga is offline   Reply With Quote
Old 06-26-2013, 11:40 AM   #17408
Gunga Galunga
Oddometer: 228
Thanks, I like electrical it just makes my slow breathing head hurt.
I was thinking of using it as a power down so nothing drained the
battery but I think I should just stick to putting stickers on stuff. Seriously.
1992 Yamaha WR500ZD
Old 06-26-2013, 12:14 PM   #17409
BuRPsa
Finally growing up..
BuRPsa's Avatar
Oddometer: 548
Originally Posted by crypto666 View Post
Dried blood on the tank and handle bars will keep people from stealing it too, maybe scatter some spent shell casing around the scene, a little yellow crime scene tape, the bike isn't going anywhere.
Ah yea, those living in a properly working society.... have probably never heard of places where police vehicles are stolen from the parking lot at police stations in broad daylight. As we say here, Only in Africa...
BuRPsa is offline   Reply With Quote
Old 06-26-2013, 03:02 PM   #17410
crypto666
Oddometer: 1,449
[QUOTE=Gunga Galunga;21732272]
Don't worry about the hurting head, I have a bit of electrical experience doing car and home audio, pool and spa electrical, some aircraft work, boats, etc. An none of those have caused headaches like the electrical on these bikes. There is just some weird stuff going on at times that I cannot explain.
Old 06-26-2013, 05:47 PM   #17411
Shibby!
Oddometer: 1,666
Looks like a fun ride. How does it differ from the CDT? I've done that. NM surprised me. Beautiful state.
My oil consumption is usually a bit less than that. It only starts to burn it towards the end of the interval too (I do 2000km (1250mile) changes). I've had once where it dropped super fast for some reason. I've never been able to replicate it though...
Currently at around 1250km and it hasn't burned a drop yet.
For MPG, I'd get around mid 35's until I got my TM-40. Now I get 50-53MPG. A welcome return at the pump and extra range on the tank! I know it doesn't add to much at the pump, but when I've filled countless times I swear my TM has paid for itself.
Tour of Idaho T1 Challenge - https://spotwalla.com/tripViewer.php...551f1642711d75
Eat. Sleep. Ride - The Great Divide: http://advrider.com/forums/showthrea...4#post19193704
Go, Get Lost - Heading South: http://advrider.com/forums/showthread.php?t=735690
Dirt Donkeys Do Baja: http://advrider.com/forums/showthread.php?t=671095
Shibby! is offline   Reply With Quote
Old 06-26-2013, 10:00 PM   #17412
DocAxeYarYar
RideDualSport.com
Oddometer: 788
XRR Oil and Gas
Thanks for the info on oil and gas consumption....having your MPG bump up so much is great!
The route I put together is pretty much CDT from just south of Pie Town, up into CO. After that we head south again, down the Rio Grande River Gorge over Dunn Bridge, then to Taos and Whites Peak. From there, head south to Capitan and we hook up on the Guadalupe Rim.
Lots of challenges along the way, some locked gates to contend with....Parts of the route had to be left off as we adjusted on the fly.
Glad to see my XRR is about where it should be on oil consumption.
My XR650R Build:
Old 06-27-2013, 07:25 AM   #17413
crypto666
Oddometer: 1,449
Hey, it sounds like I might fit in there.
I guess in your case you would need to replace the dried blood with the entire corpse, maybe one that is already a bit smelly.
Seriously though, I think 90% of theives would not be able to get away on a xrr that has no auto-decomp. They would think it is broken.
Old 06-27-2013, 07:50 AM   #17414
Shibby!
Oddometer: 1,666
Haha. We had pie in pie town. They were kind enough to fill our camel backs with their spigot out back. You don't hear the word spigot much so it caught me off guard. haha.
Sounds like a fun ride. I'd ride in NM again. Fun times!
Old 06-27-2013, 09:04 AM   #17415
BuRPsa
BuRPsa's Avatar
Oddometer: 548
Erm, I'm absolutely sure you will, no hair's doubt. H2!
This is where a Sangoma (witch doctor) comes in handy. Consult him (for a fee, of course) and he'll give you something to lay or drape on the bike. That will be effective - or a live snake, does not even have to be poisonous
Offroads are simply lifted on a pickup and sent to Mozambique, flogged there for peanuts. Only once there they'll sort out if it runs or not. I've stayed in a guesthouse, somewhat decent even, where the once-majestic lounge was littered with (near)identical scooters, all not running and some robbed for parts. Outside seemed to be a scrapyard for airconditioners, also a popular item stolen from cellular phone sites. Actually all quite normal, one sortof gets used to it.
Times are GMT -7.   It's 08:45 AM.
