Old 07-07-2013, 10:57 PM   #17521
stuntheavy
Oddometer: 146
Can anyone produce a picture of the balancer gear and how it is timed to the crankshaft? Particularly interested in whrre the notch is and where the hole is, along with orientation (one side has a larger shoulder).
They did a good job on the rod replacement and everything appears as it should. They had a couple tools they built for the job that he showed me. Just that damn gear...
Sent from my SCH-I535 using Tapatalk 2
stuntheavy is offline   Reply With Quote
Old 07-08-2013, 10:09 AM   #17522
cognugget
cognugget's Avatar
Oddometer: 243
Cool2
Plated XR650R
cognugget is offline   Reply With Quote
Old 07-08-2013, 10:46 AM   #17523
Shibby!
Oddometer: 1,657
Originally Posted by 1bigrn View Post
I was going to install a fan on my xr. It runs pretty good but when the mud gets thick it can really run hot.
Most have installed the KTM fan at a price of $125 or a 4" SPAL fan. Is there any reason why the SPAL 6.5" fan wouldnt fit?
Its overall width is 7". Only an inch more than the 4" fan. It also moves twice the cfm.
http://www.summitracing.com/parts/sp...0402/overview/
What are your thoughts?
There is a guy on E-bay that sells SPAL fans for about 45$. These are the same fans as the KTM's, just no shroud. Still work great and provide enough airflow to keep the 650 cool in stalled traffic, etc.
If he doesn't have the "pull" ones, send him an email. He'll let you know when he will have more.
Small brackets have to be made from there. This thread has examples of many different ways of doing that.
Tour of Idaho T1 Challenge - https://spotwalla.com/tripViewer.php...551f1642711d75
Eat. Sleep. Ride - The Great Divide: http://advrider.com/forums/showthrea...4#post19193704
Go, Get Lost - Heading South: http://advrider.com/forums/showthread.php?t=735690
Dirt Donkeys Do Baja: http://advrider.com/forums/showthread.php?t=671095
Shibby! is offline   Reply With Quote
Old 07-08-2013, 10:48 AM   #17524
Shibby!
Oddometer: 1,657
Originally Posted by Oddfellow View Post
Tried to pick up one of these:
From Motorcyclegear.com , they had them on closeout at $89.95 but were on a wait. Got the notice in the middle of the night and logged on in the morning and they were already gone. They are back in stock now but twice the price. I have aftermarket bars and was willing to tke a chance at $90 but at $200, I'll pass.
National Cycle has one that fits pretty good. Deflector is the model I have. You can see my ride report for the sample. It would fit a big headlight a bit better, but I think it was quite a bit cheaper. Not the best looking, but functional.
Alternately, lots of people use custom fitted 990 windscreens for about 60$
Old 07-08-2013, 11:46 AM   #17525
stevh0
Super Retard.
stevh0's Avatar
Oddometer: 1,427
Originally Posted by cognugget View Post
That is cool.
More info?
06 950S
Yamaha YZ250WR
Ex 1150GS, 650R, Ex 950SE, Ex 950ADV
Ex SM610, FS570, WR450, Africa Twin(s)
stevh0 is offline   Reply With Quote
Old 07-08-2013, 02:33 PM   #17526
cognugget
cognugget's Avatar
Oddometer: 243
Originally Posted by stevh0 View Post
That is cool.
More info?
ADV Monster M62 1800 lumens
ADV Monster rotary dimmer
EDS Tuff Lites
Baja Designs regulator/rectifier
This will be a bit tricky to mount but here is a quick mock up
Plated XR650R
Old 07-09-2013, 11:57 AM   #17527
cognugget
cognugget's Avatar
Oddometer: 243
anybody make a custom aluminum dash yet? Trying o come up with ideas
Plated XR650R
Old 07-09-2013, 12:38 PM   #17528
XFanMan
XFanMan's Avatar
Oddometer: 335
HighwayDirtbikes does a great one for not much $$. Have you looked at these? -->
http://www.highwaydirtbikes.com/HDB_...ref=top_clamps
SCOTT---BIG DREAMS - small wallet
KTM Superduke R, Honda XR650R, Triumph Trophy
XFanMan is offline   Reply With Quote
Old 07-09-2013, 12:40 PM   #17529
PeteN95
PeteN95's Avatar
Oddometer: 2,680
It looks like they make nice stuff, but weird that the wireless dimmer is cheaper and has more capacity than the rotary?
"If you ain't slidin', you ain't ridin'"
SVN/XRR/XC-W
PeteN95 is offline   Reply With Quote
Old 07-09-2013, 10:10 PM   #17530
Shibby!
Oddometer: 1,657
Quick question that I should know. Just rather check with you guys before making a mess. Tried searching but our vast basis of knowledge here almost makes it more difficult to search out.
Can you check / remove, change clutch by tipping the bike on it's side and not drain the oil?
Doing the Tour of Idaho T1 in a few weeks and want to make sure my clutch is in good working order. No signs of it not being, but rather check then have issues on the trail when I'm somewhat in the back country. My squirrel hunting skills are lacking these days...
Old 07-09-2013, 10:35 PM   #17531
Trl Rdr
Big Red Bird
Trl Rdr's Avatar
Oddometer: 2,057
Yes.
Changed the bushing and clutch plates that way.
Sent from my DROID RAZR HD using Tapatalk 2
2 XR650r(s) 2001 & 2002 Plated
GL18HPM9 Titanium (Gold Wing)
CRF230F for the tight shit!
Baja Mexico Trail Ride Report
Big Bend Ranch Drive and Ride Report
Trl Rdr is online now   Reply With Quote
Old 07-09-2013, 10:40 PM   #17532
FlyGuy
MachineHead
FlyGuy's Avatar
Oddometer: 165
yep tipit on over(bar end on ground) and work off the ground for a few minutes so easy to work on the clutch
FlyGuy is online now   Reply With Quote
Old 07-09-2013, 11:37 PM   #17533
cognugget
cognugget's Avatar
Oddometer: 243
the rotary looks much more simplistic and functional. This is why I picked it up. much easier to mount too.
Plated XR650R
Old 07-10-2013, 12:20 AM   #17534
Fingers
Oddometer: 32
Roller shift pawl mod ( new Farkle)
Anyone know about this part?
http://www.factorypro.com/prod_pages...650,gb500.html
Apparently it's the same for all XR 650 motors. I bought one last week and hope to install in my R in Aug when I get home, am hoping it helps the shifting with the Rekluse on power off downhill glides which can be a tad notchy. I'm replacing the plates anyway so I figured while I have the case opened I should give it a try. I'll report back if I'm the first.
Fingers is offline   Reply With Quote
Old 07-10-2013, 12:26 AM   #17535
jm-2008
jm-2008's Avatar
Oddometer: 507
Headlight surround
[QUOTE=cognugget;21818242]ADV Monster M62 1800 lumens
EDS Tuff Lites
That looks like the XR600L series headlight surround/numberplate combo.
Gather that is held in place with OEM rubber straps?
Can you supply info re cutout size for the headlight and possibly part number?
Many thanks,
JM-2008
jm-2008 is online now   Reply With Quote
Times are GMT -7.   It's 05:07 AM.
