Old 08-13-2013, 03:21 PM   #17821
PeteN95
PeteN95's Avatar
Oddometer: 2,934
Originally Posted by BuRPsa View Post
JThanks, and we know you are a diehard supporter of these auto clutches. Is this what you've got or got the full kit (name escapes me), rear brake instead of clutch etc?
I'm running the Z-start version, which is no longer available for the XRR. I prefer it because I like to not run a clutch lever, just the rear brake. The EXP doesn't work without the clutch lever, doesn't really release as much as the Z-start, I tried on my Christini. You also lose a certain amount of clutch surface with the EXP, so it isn't recommended for hot motors or Supermoto, which seems strange they would even offer it for the XRR?
"If you ain't slidin', you ain't ridin'"
SVN/XRR/XC-W
PeteN95 is offline   Reply With Quote
Old 08-13-2013, 05:04 PM   #17822
jimmyx
jimmyx's Avatar
Oddometer: 166
Great vid Sean-O !
Looks killer...... Makes me want to quit work and head out.
"I'd rather have a bottle in front of me than a frontal lobotomy"
Dorothy Parker
jimmyx is offline   Reply With Quote
Old 08-14-2013, 06:03 AM   #17823
zoro
Oddometer: 427
Can I remove the push cable from the carby and just run with the pull cable and use the huge spring on the carby to return the throttle instead?
Is there any real need for the second cable?
zoro is offline   Reply With Quote
Old 08-14-2013, 07:27 AM   #17824
Cpt. Ron
Advrider #128
Cpt. Ron's Avatar
Oddometer: 3,341
I wouldn't do that if I were you. That push cable is a nice safety feature:
http://advrider.com/forums/showthrea...=118025&page=2
Cpt. Ron
"I don't know what you do, but I know what I do, and I don't do that." --Uncle Doug, R.I.P.
"Without the possibility of death, adventure is not possible"--Reinhold Messner
Cpt. Ron is offline   Reply With Quote
Old 08-14-2013, 09:35 AM   #17825
pigpen
Gone Riding
pigpen's Avatar
Oddometer: 765
Ouch!
Keep the two two cables in there, they were put there for a reason!
Not being mean, and I do it also, but why do us as armchair mechanics always want to change what 30 or so engineers designed for a reason.....
There are a bunch of things we do to our XR's to make them work for a D/S vs. a racing machine.....
Have a good day
PIGPEN
Ride more, write less, work when !!!
Having fun is not a sport! It's a full time job for some of us!
pigpen is offline   Reply With Quote
Old 08-14-2013, 11:51 AM   #17826
sintax
Oddometer: 495
I've thought about pulling a lot of things off of my bike, but the return cable is not one of them.
I've had my throttle cable hang up on my harley, lucky it was on the freeway, but its not something i'd want to have happen on the XR. I could easily reach down and close the butterfly manually on the harley, no chance of that happening on the XR.
sintax is offline   Reply With Quote
Old 08-14-2013, 12:41 PM   #17827
spawn_x
Oddometer: 193
Hey guys. Selling xr650r supermoto setup - RAD hex interchangeable hubs, excel wheels, ebc big brake
see craigslist ad:
http://losangeles.craigslist.org/sfv...998449401.html
if interested PM me!
http://www.stuckatwork.com
spawn_x is offline   Reply With Quote
Old 08-14-2013, 07:33 PM   #17828
zoro
Oddometer: 427
Have a good day
I understand what you are saying completely, however I have seen lots of things that "30 or so engineers" have designed and still could not get it right...
Guessing I'll just leave it in there although it does seem redundant due to the large return spring on the carb itself.
(1) Worst case scenario is If the spring breaks and jams the throttle open, well there's no chance i'm going to close it with the second push cable, I'd be better off shutting off the ignition and or pulling in the clutch.
(2) If the spring breaks and does not jam the throttle open I'm still going for the clutch and ignition before I try and close the throttle.
I can reach both without having to remove my hands from the bars so control is not an issue, it would be more the split second fright it would cause.
Only benefit I can see by having it is if the pull cable breaks I might be able to use the push cable as the spare and get me home or to safety somewhere.
This is the first bike I have owned with the two cables setup, both risks described above were both present during the riding off those bikes also.
I'd be more concerned riding a bike with the "fly by wire" technology with no mechanical interface with the throttle assembly. Electrical glitch within the step motor and you're in the same boat as not using a "push" cable..
Risk calculated, its no different to how I have been riding for the last 23 years to be honest.
Interested in hearing any other opinions on this also....
Please, take what I have said as constructive criticism, I'm not saying you or anyone else are wrong but all things considered, does the second cable really have a place on a motorbike?
P.S. I'm also a qualified motor mechanic....
Old 08-14-2013, 08:29 PM   #17829
Cpt. Ron
Advrider #128
Cpt. Ron's Avatar
Oddometer: 3,341
In my situation, things happened very quickly. Split second decisions when things didn't go normally. It takes time for the brain to process the error and respond accordingly. You should really think about your ability to handle the situation when it catches you off-guard.
Cpt. Ron
Old 08-14-2013, 10:40 PM   #17830
jm-2008
jm-2008's Avatar
Oddometer: 517
Two cable or not two cable - the eternal question!
[QUOTE=zoro;22104068]I understand what you are saying completely, however I have seen lots of things that "30 or so engineers" have designed and still could not get it right...
Suggest likelyhood or probability for the spring breaking is lower than the cable breaking.
Either way its cheap insurance against an awkward situation, unless you like excitement and have an adrenalin dependancy
Had the pull cable break on a CB750 years ago miles from home and managed to rig the push cable to get home (that was awkward to say the least) but without it I was stranded so having it there paid off.
The XR's are not generally known to have sticking throttle issues more likely hangin throttle due to cable adjustment or worn linkages.
For mine I'll stick with the twin cable setup to avoid any chance of a Darwin Award
JM-2008
jm-2008 is offline   Reply With Quote
Old 08-14-2013, 10:55 PM   #17831
zoro
Oddometer: 427
[QUOTE=jm-2008;22105074]
JM-2008
I think I will stick with the dual setup, though as mentioned above the cable is most likely to break as opposed to the spring. In which case the throttle returns to idle thus making the "push" cable a redundant feature.
Had the return spring been mounted within the throttle hand piece (twist tube) on the bars then this would of course necessitate the need for the "push" cable.
Only reason I will keep the second cable is for a spare in case the '"pull" cable does break one day and I can maybe use it to get me going again. Better to have something that "might" work as opposed to nothing at all.
As far as not using the "push" cable being unsafe, I cant really think of a reason why it would be "less safe" to not use it?
Just makes me wonder what its real purpose is, as mentioned previously, its been put on/ engineered for a reason...reason being?
Old 08-15-2013, 03:08 AM   #17832
pontyboy
Oddometer: 36
Zoro,i've had my xr for just over four years.in that time i've covered tens of thousands of miles in all sorts of conditions.since day one i've run one cable only,namely the pull.when i bought the bike both throttle cables were in poor condition,the return especially so.to try to get a smooth throttle (my other bike is a ktm exc with a beautiful throttle action) i decided to run with the pull only until my new cables arrived.when they did i fitted the pull only as by then i had covered a few hundred miles and liked the feel.the new pull cable made it even smoother so i sold the new return on and carry the old,slightly ropey pull as backup.
of course,like everyone else i ensure my airfilters are clean and are sealing well.
pontyboy is offline   Reply With Quote
Old 08-15-2013, 09:02 AM   #17833
Cpt. Ron
Advrider #128
Cpt. Ron's Avatar
Oddometer: 3,341
[QUOTE=zoro;22105125]
If everything is in good working order you are correct, you don't need the push cable. Go back and read the story I linked above. Dodgy cables (but only at or near full throttle) got stuck. Bike and I crashed, broken wrist. If the bike had a push/pull cable system, that would not have happened. Another instance is a buddy of mine had a minor tip-over on his GS (like my old one, only a pull cable). The throttle housing got tweeked, causing the cables to have a lot of friction. He had a hard time riding out of there because the throttle would stick....but only sometimes.
Think of it like a seatbelt or helmet. Nobody ever PLANS to use them. But they're sure nice to have when you need them.
Cpt. Ron
Old 08-15-2013, 10:22 AM   #17834
pigpen
Gone Riding
pigpen's Avatar
Oddometer: 765
two vs one
In the old two stroke days and now, one cable worked/works fine, big spring in the carb!
Now I like the extra cable like you said for a spare just in case!
On the technical end It might not matter going down the highway, enough time to react, but if you were in tight situation or technical area and it stuck open the penalty box could be huge!
Mine is and edelbrock, not sure if it needs the push pull or not, tank has not been off for awhile, and I can't remember if the spring is very strong or not, I seems to me I ran an extra exterior spring for return... or updated an external spring for return...
I'm a fairly good mechanic on a bike also but I sometimes leave well enough alone....
On the other hand I have anew clutch cable zipyted to the existing cable to change out in the field...
Fly by wire is not my cup of tea either, neither is fuel injection on a dual sport, now on a road bike or track bike I'd run it, just like to be able to take apart in the field and fix things, which I have done in the middle of Hells Canyon miles from any help, cell coverage, etc.....
Just my opinion, yours may differ, probably will, and that's what makes this so much fun!
PIGPEN
Old 08-15-2013, 10:29 AM   #17835
pigpen
Gone Riding
pigpen's Avatar
Oddometer: 765
accelerator pump
Capt. Ron,
BTW Thanks for the pump! I have it squirreled away in the tank bag for use some time. I cured the last problem I had with it, but It is very comforting to have a back up for the Eddy!
You rock!
On a side note that wrist injury report "sucked"! That must have been before we met in Death Valley!
Keep riding!
PIGPEN
Times are GMT -7.   It's 10:08 AM.
