Old 08-27-2013, 02:34 PM   #17926
medisyn
Oddometer: 149
So I just ordered a chain and now I am confused on how many links I need with my SM wheel setup.
I have 15/44t sprockets ordered from XR's only. They called me today and said that I need a 120 link chain.
I am pretty sure 110 or 108 links is how many I need. I know I can cut it down, but now I am unsure what I need. Anybody with a similar setup?
medisyn is offline   Reply With Quote
Old 08-27-2013, 03:17 PM   #17927
PineyMountainRacing
Oops....
PineyMountainRacing's Avatar
Oddometer: 2,428
I just put a set of 17's on mine, with 15/44 gearing. I took 2 links out of the stock chain, and that put the axle about half way in the adjustment range. It's pouring outside or I'd walk out to the shop and count how many links are in the chain now. But I know it's the chain tht came on the bike with the stock gearing.
PineyMountainRacing is online now   Reply With Quote
Old 08-27-2013, 03:29 PM   #17928
PeteN95
PeteN95's Avatar
Oddometer: 2,805
Originally Posted by Sniper X View Post
I stuck a washer about 3mm thick on the side that was closer and it worked perfectly.
That is going to tweak your forks a bit, why not just adjust the lacing to even the rim out?
"If you ain't slidin', you ain't ridin'"
SVN/XRR/XC-W
PeteN95 is offline   Reply With Quote
Old 08-27-2013, 03:44 PM   #17929
PineyMountainRacing
Oops....
Oddometer: 2,428
Yeah, I could add 2.5 mm on one side and take 2.5 off the other spacer, but that will move the rotor. Is there supposed to be an offset on the hub? I was told by W9 that the hubs are CRF hubs. I put the wheel in the truing stand and it looks like there is 0 offset now. I can move the rim over in relation to the hub, that's the only way without moving the rotor and / or increasing the distance between the forks.
Old 08-27-2013, 07:14 PM   #17930
dsilver1007
dsilver1007's Avatar
Oddometer: 322
carb
Originally Posted by FlyGuy View Post
Stock carb if your not willing to spend the money for the TM40
Or someone might chime in with some eddy parts for you (possible wishful thinking?) most people liked them when they were right.
Thank you for the help, i may end up going with the stock carb for the time being.
What would be some good starting points with jetting considering i just have an aftermarket exhaust.
The part that could have potentially kicked my eddy to the curb is the umbrella seal that i cant find a replacement for.
If you cant ride it on one, ride it on two
dsilver1007 is online now   Reply With Quote
Old 08-27-2013, 08:46 PM   #17931
zoro
Oddometer: 399
I have a FMF pipe, power bomb header and stock carb.
Main is a 175
Pilot is the 68S
Needle is B53E and set at middle (3rd) clip groove
Idle mixture is 1.25 turns out
I'm at sea level and will most likely move the needle to the next lean clip position (move needle down another clip position) just to try.
zoro is offline   Reply With Quote
Old 08-27-2013, 11:25 PM   #17932
medisyn
Oddometer: 149
Well as I took the chain off my bike I counted the pins 108. So I am guessing thats the lenght I need?
Also I am getting really annoyed with everything I take off this bike I see the shoddy work of the last owner.
The front sprocket had like 1/8th inch of play on it forward and back. This is what the sprocket holder looked like.
http://i.imgur.com/pd3SaXN.jpg
This is what the shaft looks like.
http://i.imgur.com/MxJ4YEk.jpg
The reason I am replacing the chain is because I noticed a link was stiff/damaged. Part of the metal from one of the side plates was completely gone. Really lucky it never broke!
I think it's a result of the play in the CS sprocket. Guessing it hit the case saver which looked like it had almost no clearance for a 15t sprocket.
What could have caused this? Over tight chain? Using the wrong sprocket? I know the xr650l sprocket is thiner.
The question is when I get the new parts (I ordered a new sprocket, the plate to hold it and bolts) is if there will be play in it as well....
Old 08-28-2013, 12:51 AM   #17933
bigkuri
bigkuri's Avatar
Oddometer: 814
Yikes you really need a new crankshaft seal... that is nicely rusty/dirty!
Your splines are not the worse I've seen (loads of XR600's), but they are starting to get worn.
Will be interested to see what some of the guru's say here, but my take is just make sure you buy the best fitting sprocket you can, with a nice wide footprint, and forget about it. They all have some play, and there is not much you can do...
Current Bikes: 2006 Honda XR650R & 2015 KTM 1190 Adventure R
bigkuri is offline   Reply With Quote
Old 08-28-2013, 05:08 AM   #17934
1bigrn
Oddometer: 212
[QUOTE=zoro;22198165]I have a FMF pipe, power bomb header and stock carb.
Main is a 175
Pilot is the 68S
I ran the exact same set-up on my carb and it was perfect. In many ways I like it better than my Mikuni pumper.
1bigrn is offline   Reply With Quote
Old 08-28-2013, 07:04 AM   #17935
OBD
Other Brother
OBD's Avatar
Oddometer: 151
[QUOTE=1bigrn;22199492]
Main is a 175
Pilot is the 68S
Was that with side panel and/or air filter mods or stock?
OBD is offline   Reply With Quote
Old 08-28-2013, 11:27 AM   #17936
medisyn
Oddometer: 149
Yeah clearly the guy did not put a drop of grease on the splines. Like literally everything the former owner did was a hack job. I have learned my lesson. I will not buy a modified bike again. You cant trust the former owners to do the work right.
I ordered a pbi sprocket. It seems to be what the XR650L guys do when their splines get chewed up. I cant wait to get the sprocket to compare it to the one that was on there depth wise.
Yeah I should probably replace that seal too!
EDIT: Looks like that seal was improved and has a new version. Parts ordered!
medisyn screwed with this post 08-28-2013 at 01:28 PM
Old 08-28-2013, 12:46 PM   #17937
mitchn06
mitchn06's Avatar
Oddometer: 542
what is everybody running for a backfire screen?
2000 Honda XR650R (Sold) LINK
2014.5 Kawasaki KLR650 NE
mitchn06 is online now   Reply With Quote
Old 08-28-2013, 01:42 PM   #17938
Shibby!
Oddometer: 1,661
The stock one....
Tour of Idaho T1 Challenge - https://spotwalla.com/tripViewer.php...551f1642711d75
Eat. Sleep. Ride - The Great Divide: http://advrider.com/forums/showthrea...4#post19193704
Go, Get Lost - Heading South: http://advrider.com/forums/showthread.php?t=735690
Dirt Donkeys Do Baja: http://advrider.com/forums/showthread.php?t=671095
Shibby! is offline   Reply With Quote
Old 08-28-2013, 03:03 PM   #17939
Cpt. Ron
Advrider #128
Cpt. Ron's Avatar
Oddometer: 3,301
I've never needed one until I went back to the stock carb and the bike was flooded badly on a steep hillside (and sitting for quite a few minutes on it's side). The Uni air filter got a little singed when it backfired.
I've never seen another bike that can piss so much fuel. The Edlebrock never did that to me. I can't wait to get a new pumper carb.
Cpt. Ron
"I don't know what you do, but I know what I do, and I don't do that." --Uncle Doug, R.I.P.
"Without the possibility of death, adventure is not possible"--Reinhold Messner
Cpt. Ron is offline   Reply With Quote
Old 08-28-2013, 03:59 PM   #17940
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,440
They dont leak fuel when pinned in
5th
Sean-0 is offline   Reply With Quote
Times are GMT -7.   It's 11:02 AM.
