Old 12-28-2013, 02:45 PM   #19051
mitchn06
mitchn06's Avatar
Oddometer: 541
ok, i'm pissed, i broke my outer clutch basket trying to torque the nut on the inner. anybody got a spare basket, or know of a clutch tool so this doesn't happen again.
2000 Honda XR650R (Sold) LINK
2014.5 Kawasaki KLR650 NE
mitchn06 is offline   Reply With Quote
Old 12-28-2013, 05:01 PM   #19052
Toaliosis
Toaliosis's Avatar
Oddometer: 56
I have the one I just removed from my XR, it's being replaced with a Hinson. It's got some grooves worn in it and was the reason for the upgrade. Let me know if your interested. I can send some pics.
Sent from my HTCONE using Tapatalk
Toaliosis is offline   Reply With Quote
Old 12-28-2013, 05:13 PM   #19053
mitchn06
mitchn06's Avatar
Oddometer: 541
Well I don't want to replace it with a crap one if I can get a new one for 160, but if it isn't too bad and the price is right. I'll pm u.
Old 12-28-2013, 05:30 PM   #19054
Trl Rdr
Big Red Bird
Trl Rdr's Avatar
Oddometer: 2,059
Put a penny in the gear teeth. Somewhere I have a tool. Used a battery impact last time on the nut.
Sent from my DROID RAZR HD using Tapatalk
2 XR650r(s) 2001 & 2002 Plated
GL18HPM9 Titanium (Gold Wing)
CRF230F for the tight shit!
Baja Mexico Trail Ride Report
Big Bend Ranch Drive and Ride Report
Trl Rdr is offline   Reply With Quote
Old 12-28-2013, 06:26 PM   #19055
mitchn06
mitchn06's Avatar
Oddometer: 541
The inner clutch hub is independent of the outer basket. I was trying to torque down the clutch hub nut, which is connected to the primary transmission shaft. Basically you need to mate a friction plate with a steel plate and then do the penny thing. I did it with a screwdriver and two vise grips instead. Thus my $160 mistake. I was wondering though how close the 650r and 650l baskets are. Ebc makes a nice looking clutch tool, but they forgot to make one for the 650r.
Old 12-28-2013, 06:47 PM   #19056
slickwill
Exhiled
Oddometer: 209
Has anyone measured various head gaskets or base gaskets and found one that's thicker than stock? I need to gain a couple thousandths extra clearance between the piston and head due to my engine being rebuilt one too many times.
slickwill is offline   Reply With Quote
Old 12-28-2013, 06:54 PM   #19057
Trl Rdr
Big Red Bird
Trl Rdr's Avatar
Oddometer: 2,059
I know the 650R has rubber cushions in the gear on the back of the clutch whereas the 650L as cush drive in the rear hub.
Old 12-28-2013, 06:54 PM   #19058
Kai Ju
Kai Ju's Avatar
Oddometer: 1,869
If you have an old worn out clutch just pop rivet two friction plates to a steel plate and you have a free clutch holding tool. Start out by drilling three holes, 120 deg. apart into one friction plate. Slide into place in the clutch and mark the holes you drilled on the steel plate already installed. Remove and drill. Repeat with the second friction plate. Rivet the three plates together. Done.
Kai Ju is offline   Reply With Quote
Old 12-28-2013, 06:57 PM   #19059
mitchn06
mitchn06's Avatar
Oddometer: 541
That's what I will be doing once I get my new basket more than likely.
Old 12-28-2013, 07:51 PM   #19060
lemanster
lemanster's Avatar
Oddometer: 87
Originally Posted by cognugget View Post
Check the rubber seal in the petcock. They like to rot and clog up the float needle.
Sent from my SCH-I545 using Tapatalk
i'll have to check that out. when I replaced the tank a few months ago the seal looked ok, but I'll have to look again.
00 XR650R Cali plated motard/trail pig
04 CR250R
lemanster is offline   Reply With Quote
Old 12-29-2013, 09:56 AM   #19061
brayjay
Oddometer: 227
650R head bolt torque
Hey guys, almost ready to start installing piston an head on my 650R and question is when torqueing down the head should I torque down the head in 10 FT pound increments or go half way as I work up to the 49 ft lbs it states in the manual. Do I need to go all the way to 49 ft lbs? Seems like a lot of torque. One more thing, does anyone know of a muffler other than stock that does not require having to repack the thing every so often? Thanks in advance.
brayjay is online now   Reply With Quote
Old 12-29-2013, 11:08 AM   #19062
ZXRaziel
ZXRaziel's Avatar
Location: Grey skyes and rain of Good old England ( NEast)
Oddometer: 501
Some people never repack the exhaust , it gets louder and you might loose some power but nothing major will happen , i like to repack mine now and again just to keep it as quiet as possible .
good things them hondas
ZXRaziel is offline   Reply With Quote
Old 12-29-2013, 12:00 PM   #19063
brayjay
Oddometer: 227
I had read somewhere that it needed the back pressure to run properly is all.
Old 12-29-2013, 12:50 PM   #19064
Cpt. Ron
Advrider #128
Cpt. Ron's Avatar
Oddometer: 3,296
Originally Posted by crypto666 View Post
I assume you mean you added rebound damping to Borynack et al's stack,
Correct.
Cpt. Ron
"I don't know what you do, but I know what I do, and I don't do that." --Uncle Doug, R.I.P.
"Without the possibility of death, adventure is not possible"--Reinhold Messner
Cpt. Ron is offline   Reply With Quote
Old 12-29-2013, 12:54 PM   #19065
Oddfellow
Beasty Rider
Oddfellow's Avatar
Oddometer: 471
Does anyone know if a R&D Flex Jet Fuel Mixture Screw will work on a Mikuni TM40? I'm assuming it will but I figured one of y'all would know for sure.
Oddfellow
'06 Suzuki DR200SE
'05 Honda XR650R
'14 KTM 690 Enduro R
Oddfellow is offline   Reply With Quote
Times are GMT -7.   It's 10:33 AM.
