Old 02-02-2009, 02:29 PM   #301
alfaris
MOTERO TORERO
alfaris's Avatar
Oddometer: 1,154
Thumb
Originally Posted by badcooky
Alfaris if you want it to LOOK like the race bike get the white 3.2 IMS.
If you need the fuel range go bigger.
Nice point of view........... racing 3.2 / adv 4.6. I did not figure it out that way.
thank you.
The SOTO setup (talking about just the look not the components) is one of my favourites.
as well as the precision concepts one
On the other hand, talking about range, this natural colour Clarke setup is nice.
as well as the IMS 4.6 on natural
09ī KTM 530 EXC
07ī XR650R
alfaris screwed with this post 02-02-2009 at 02:42 PM
alfaris is offline   Reply With Quote
Old 02-02-2009, 04:46 PM   #302
DOSCERVASAS
neck
DOSCERVASAS's Avatar
Oddometer: 220
Eek Damb
thank you.
That Precision Consepts is FINE
I got some work to do
"Just some ass hole trying to ice skate up hill"
"Another Day, Another poor soul left in my Dust"
DT-100
XR-650R
VTX-1800
DOSCERVASAS is offline   Reply With Quote
Old 02-02-2009, 04:59 PM   #303
bump
COLOR ME GONE
bump's Avatar
Oddometer: 713
I wouldn't know how to begin to describe it.
There's a new member who is absolutely nuts!
Originally Posted by husky123
Nice job Focker!
AND what's going on at Yahoo? Anyone?
bump is offline   Reply With Quote
Old 02-03-2009, 03:32 AM   #304
pRICK
Oddometer: 330
thank you.
Please stop posting pics of porn pigs. You are costing me a fortune.
pRICK is offline   Reply With Quote
Old 02-03-2009, 04:52 AM   #305
alfaris
MOTERO TORERO
alfaris's Avatar
Oddometer: 1,154
Indeed, they are beautiful arenīt they?
Looks quite simple to have one, yo need XRsonly air filter plastic cover, Procircuit T4, that little headlight and the IMS tank.......
around 85+350+290 $........?
I am now negotiating the price on the XR650R iīve found. hope to close the deal this week. By the way, i already have the front light. hope to order the tank and the T4 soon.......
meanwhile i keep watching porn XRīs Pictures
09ī KTM 530 EXC
07ī XR650R
Old 02-03-2009, 05:34 AM   #306
JustinT OP
I will ride my whole life
JustinT's Avatar
Oddometer: 952
Could that be a fellow beginning with G and ending with -ene?
I love the Pics Everyone!!!!
Full Throttle - it either solves the problem or ends the suspense
JustinT is offline   Reply With Quote
Old 02-03-2009, 09:01 AM   #307
bongodave
Join my cult!
bongodave's Avatar
Oddometer: 41,245
My XR is a dirty little thang! Soooo sexy!
Freedom without regulations that protect the general good is nothing more than anarchy by the rich. -R-1150-RS
Corporatism walking hand in hand with patriotism .... just as deadly as religion. - Icewalker
if you depend on lies and misinformation to support your belief system, you need a better belief system. - Dances With Roads
bongodave is online now   Reply With Quote
Old 02-03-2009, 12:27 PM   #308
red pig rider
adventurer
red pig rider's Avatar
Oddometer: 78
need more valve help please
got back to the bike today to finish the valve adjustment and am running into trouble. the valves seemed really tight with no play at tdc. so i loosened all lock nuts and began to loosen adjusting screws. and the valves are just following the set screw upward. only giving the correct clearance when set screw is at end of threads. this doesnt seem correct. i am at tdc. any help will be greatly appreciated. and i am a carpenter so longwinded answers are preferred.
#uc% the dumb sh*+
red pig rider is offline   Reply With Quote
Old 02-03-2009, 01:53 PM   #309
zaptoad
just a guy
zaptoad's Avatar
Oddometer: 301
maybe!!!
or 360 degrees off..........
zaptoad is offline   Reply With Quote
Old 02-04-2009, 02:18 PM   #310
jm-2008
jm-2008's Avatar
Oddometer: 512
Re need more help with the valve clearance problem
Sounds like you may be 360 degrees out of phase.
Remember the crank runs at half cam speed hence four strokes between ignition.
The 'T' mark must be lined up with valves closed (in the up position) not with the valves opened (in the down position)
Try the following method to avoid confusion as it has allways worked for me -
Assuming you have the valve covers off -
Ensure kills switch is set to off
With your hand 'Slowly' push down the kick starter until you see the inlet valve open (go down)
Continue pushing the kick starter slowly until the inlet valve begins to close (come up)
At this point look through the inspection cover on the left crank case and continue turning the crank 'anti clockwise' until the 'T' mark lines up.
This must place the engine at TDC on the compression stroke with valves shut (in the up position)
Set clearances at this point.
Good luck
jm-2008 is offline   Reply With Quote
Old 02-04-2009, 03:38 PM   #311
Crit Rat
Crit Rat's Avatar
Oddometer: 241
Good luck
I read it was better to rotate backwards via the crank to ensure the auto decompression mechanism not engaging and so affecting the measurements.
2001 CR250R
2001 XR650R
Crit Rat is offline   Reply With Quote
Old 02-04-2009, 03:44 PM   #312
HOT DAMN!
HOT DAMN!'s Avatar
Oddometer: 7,633
Once in a while you get shown the light in the strangest of places if you look at it right
HOT DAMN! is offline   Reply With Quote
Old 02-04-2009, 03:51 PM   #313
alfaris
MOTERO TORERO
alfaris's Avatar
Oddometer: 1,154
Talking Iīve got it again
Itīs been 5 years since i sold my former 2000 XR650R. Iīve had other bikes since then but i couldnīt forget the BRP.
An opportunity showed up last week so iīve taken it today.
Well, i still have to do some mods, but this is the 2000 XR650R as iīve bought it today. I didnīt realize the grafitti on the back wall until i saw the pic at home.........
Has 11.000km on it and looks in good shape. former owner didnīt use it too much.
Mods will be:
Rear plate holder .
Front USA headlight.
Clarke 4.3 natural tank.
IMS pro pegs.
ad maybe.........the pro circuit T4, maybe.
09ī KTM 530 EXC
07ī XR650R
alfaris screwed with this post 02-04-2009 at 04:01 PM
Old 02-04-2009, 03:53 PM   #314
header
Chris
header's Avatar
Oddometer: 1,746
Couldn't help myself haha.
KTM 530exc
525exc refresh
header is offline   Reply With Quote
Old 02-04-2009, 05:40 PM   #315
DOSCERVASAS
neck
Oddometer: 220
Pissed Stop It
Originally Posted by HOT DAMN!
Your making my Check card thin.
DT-100
XR-650R
VTX-1800
Times are GMT -7.   It's 08:09 AM.
