Old 02-08-2009, 06:10 AM   #361
HOT DAMN!
HOT DAMN!'s Avatar
Oddometer: 7,633
Originally Posted by pavemike
Just wanted to rub it in to all of you who are snowed in
Snowed in?
No such thing.
Once in a while you get shown the light in the strangest of places if you look at it right
HOT DAMN! is offline   Reply With Quote
Old 02-08-2009, 06:30 AM   #362
alfaris
MOTERO TORERO
alfaris's Avatar
Oddometer: 1,154
CRF450R 06 FMFQ4 silencer on XR650R.
I have the possibility to rescue the FMFQ4 silencer from my former CRF450R 2006, and i would like to know if it would fit on the XR650R. Any info? thanks.
09 KTM 530 EXC
07 XR650R
alfaris is offline   Reply With Quote
Old 02-08-2009, 09:00 AM   #363
red pig rider
adventurer
red pig rider's Avatar
Oddometer: 78
Thumb
Originally Posted by jm-2008
Sounds like you may be 360 degrees out of phase.
Remember the crank runs at half cam speed hence four strokes between ignition.
The 'T' mark must be lined up with valves closed (in the up position) not with the valves opened (in the down position)
Try the following method to avoid confusion as it has allways worked for me -
Assuming you have the valve covers off -
Ensure kills switch is set to off
With your hand 'Slowly' push down the kick starter until you see the inlet valve open (go down)
Continue pushing the kick starter slowly until the inlet valve begins to close (come up)
At this point look through the inspection cover on the left crank case and continue turning the crank 'anti clockwise' until the 'T' mark lines up.
This must place the engine at TDC on the compression stroke with valves shut (in the up position)
Set clearances at this point.
Good luck
thanks for the help. got it figured out friday night. they were a bit tight. gonna check em every oil change now.
#uc% the dumb sh*+
red pig rider is offline   Reply With Quote
Old 02-08-2009, 09:31 AM   #364
DOSCERVASAS
neck
DOSCERVASAS's Avatar
Oddometer: 220
Eh? Damb
Originally Posted by HOT DAMN!
Snowed in?
No such thing.
BRRRRRRRRRRR
"Just some ass hole trying to ice skate up hill"
"Another Day, Another poor soul left in my Dust"
DT-100
XR-650R
VTX-1800
DOSCERVASAS is offline   Reply With Quote
Old 02-08-2009, 01:36 PM   #365
KTM265
KTM265's Avatar
Oddometer: 940
Looks like my XR...snow and all.
Mark Twain: "Twenty years from now you will be more disappointed by the things you didn't do than by the ones you did do. So throw off the bowlines, sail away from the safe harbor. Catch the trade winds in your sails. Explore, dream and discover"....
Life's journey is not to arrive at the grave safely and in a well preserved body, but rather to skid in sideways totally worn out, shouting "Holy Crap, What a Ride!"
KTM265 is offline   Reply With Quote
Old 02-08-2009, 01:55 PM   #366
KTM265
KTM265's Avatar
Oddometer: 940
Originally Posted by SVMango
I can't stop myself from posting this everytime someone mentions
e-start on an XR-R.
I'm just too old and have too much money to have any desire to kick it anymore..
Old 02-08-2009, 03:10 PM   #367
Hodakaguy
NorthWest Adventure Rider
Hodakaguy's Avatar
Oddometer: 2,108
Rad Guards - And Custom Acerbis Sahara Mounts
Just finished installing the Unabiker radiator guards on my XRR, Great Product!!!!
Also I had to fabricate some lower Acerbis Sahara tank mounts to use with the Unabiker's. They also work as a brace.
You can see the full write up on the XR650RForum here: CLICK HERE
Here's a shot of the home brew lower tank mount/guard. More pics on the link above.
Hodakaguy
NV 2012 - In Memory of the Crewmen RR: CLICK HERE
Adventure Is Out There - NV RR: CLICK HERE
Riding Through History - NV RR: CLICK HERE
And Then There Were Four - OR RR: CLICK HERE
My VW Syncro Westy Build Thread: CLICK HERE
Hodakaguy screwed with this post 02-08-2009 at 03:17 PM
Hodakaguy is offline   Reply With Quote
Old 02-08-2009, 05:43 PM   #368
ADVJake
***** dweller
ADVJake's Avatar
Oddometer: 4,341
Well my XR was burning some oil after i did a wide open throttle run for about 30 minutes
i think i lost about 250ML on that ride, if im easy on the throttle she never burns oil.
Does anyone know what causes oil loss when the bike is revved out for long periods? Is there a fix or is it just the charastitic of a large power single?
"And some guy said, let there be filtering, and we filtered and we saw that it was good, and hours became minutes..."
ADVJake is offline   Reply With Quote
Old 02-08-2009, 06:03 PM   #369
pavemike
I fall down alot
pavemike's Avatar
Oddometer: 339
Quick questions for the experts here. I installed an Edelbrock carb on the bike awhile back (stock carb I had on there was beat to hell). I noticed on a few of my shorter rides that she drinks a little more fuel than normal. This weekend I went on a 110 mile jaunt with the Acerbis tank (6.3 gallons) installed. I put a gallon of fuel in the bike about 50 miles in that an ATV buddy didnt want to carry anymore. When I finished the ride I only had a little over a gallon left in the tank . So I figure 110 miles and 6 gallons of gas used....thats 18 mpg! No fuel leaks from the tanks or fuel lines, bike was running pretty rich, but other than that I have no clue. What is everyone else with this setup getting range wise? I'm tearing the bike down again this week to take care of some other things, so I'm willing to try out any ideas you guys have. Thanks from your resident MRS expert.
pavemike is offline   Reply With Quote
Old 02-08-2009, 07:33 PM   #370
RdrMtn
RdrMtn's Avatar
Oddometer: 158
mileage
I'm getting a steady 34 mpg with my Edlebrock. That's with 13/48 gearing road riding 50mph 15 miles one way to rocky 1st gear singletrack, 15 miles of that stuff then 15 miles back home on the road. Sounds like a mileage miscalculation? 18mpg just seems unreasonable.
That said, I am definitely not an expert on the carb. I bought the bike with the Eddie installed 5 years ago and it seems to run good after minor adjustment.
RdrMtn is offline   Reply With Quote
Old 02-08-2009, 07:40 PM   #371
4play
Next?
4play's Avatar
Oddometer: 2,560
The worst I've ever averaged for a ride was in the low 30's. My only complaint with the E-brock is I have to run the idle to low mid a little rich to get the WFO fuel rich enough.
Family isn't always about blood
4play is offline   Reply With Quote
Old 02-08-2009, 08:09 PM   #372
pavemike
I fall down alot
pavemike's Avatar
Oddometer: 339
I wish that were the case. GPS and odometer both showed 110 miles, and I used/lost 6 gallons of gas. Maybe its time for another valve check
Old 02-08-2009, 08:10 PM   #373
Off the grid
Chaotic Good
Off the grid's Avatar
Oddometer: 10,901
Stupid question #16423
Are pilon pegs available?
How much wt can a reinforced subframe handle?
(ie with this mod)
Wedding(s) = $30,000
Divorce(s) = $25,000
2009 Husky TE610 = Priceless
Off the grid is online now   Reply With Quote
Old 02-08-2009, 08:30 PM   #374
KTM265
KTM265's Avatar
Oddometer: 940
Seeing all the mileage from the aftermarket carbs... What about a stock set up? What sort of mileage should we be seeing?
Old 02-08-2009, 08:32 PM   #375
4play
Next?
4play's Avatar
Oddometer: 2,560
I didn't see any difference, IMHO a properly tuned bike is going to get very close to the same mileage reguardless of what carb is on it.
Times are GMT -7.   It's 12:19 PM.
