Old 03-28-2011, 07:51 AM   #7861
Shibby!
Oddometer: 1,665
Originally Posted by El Traxo View Post
Shibby, you were right! I have inspected the fork damper more carefylly and - yes! The spring was there. Thank you for a tip!
No problem.
I know because I've been there. Had to do a little research myself to find out that on most forks the springs just stick up top. No point removing them as long as you confirm they're in there on rebuild.
Good luck with the servicing. XRR suspension definitely needs work from factory. With Borynack's suspension mods/valving/oil it completely changes it.
Tour of Idaho T1 Challenge - https://spotwalla.com/tripViewer.php...551f1642711d75
Eat. Sleep. Ride - The Great Divide: http://advrider.com/forums/showthrea...4#post19193704
Go, Get Lost - Heading South: http://advrider.com/forums/showthread.php?t=735690
Dirt Donkeys Do Baja: http://advrider.com/forums/showthread.php?t=671095
Shibby! is offline   Reply With Quote
Old 03-28-2011, 10:56 AM   #7862
Coastie3202
King of the Mountain
Coastie3202's Avatar
Oddometer: 861
Seat Concepts
After 140 miles of single track and fire roads yesterday my ass is begging that I find a better platform to rest it on. So the stock seat has got to go.
Has anyone heard of or tried Seat Concepts?
http://seatconcepts.art.officelive.com/Honda.aspx
http://seatconcepts.com/web_images/x...talled_001.jpg
http://www.seatconcepts.com/web_images/img_1536.jpg
I want to live in a world where common sense and courtesy trump entitlement...a world where chickens can cross the road without having their motivation questioned.
Coastie3202 is offline   Reply With Quote
Old 03-28-2011, 11:29 AM   #7863
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,463
yes mate i hve 1 on my pig , best rider mod i have done , spent 11 hrs on it a few weeksago and got off with a smile
Sean-0 is offline   Reply With Quote
Old 03-28-2011, 11:31 AM   #7864
Purcell69
Mors ex Tenebris
Purcell69's Avatar
Location: Moving forward...at the speed of rust in mid-OK
Oddometer: 3,833
I have not heard of Seat Concepts. I had the same complaint on the stock seat. It was like a prostate exam in the form of a vinyl covered 2X4. I went with Guts Racing Tall/Soft foam and cover. Less than $100 for comfort. If I had the time and money, I would have waited for a Renazzco, but the Guts seat is comfortable enough that I am not considering any more upgrades.
-Joe
The Marines...When it absolutely, positively has to be destroyed overnight.
Trust and Respect take years to earn, but can be lost in a moment.
Life's too short to hold a grudge. -Joe
Purcell69 is offline   Reply With Quote
Old 03-28-2011, 11:37 AM   #7865
Coastie3202
Oddometer: 861
Hey Sean. Throw up a pic of your pig with the Seat Concepts installed. Thanks mate.
Old 03-28-2011, 12:19 PM   #7866
pixelcodex
Oddometer: 70
I have a seat concepts as well, and have seen a big improvement, though I have not ridden for extended trips. It is somewhat similar to stock in looks, but has a wider back and it is flat, which makes for a better posture. I will snap a picture tonight as well.
pixelcodex is offline   Reply With Quote
Old 03-28-2011, 01:35 PM   #7867
Coastie3202
Oddometer: 861
You guys are great. Thanks.
Old 03-28-2011, 03:16 PM   #7868
RdrMtn
RdrMtn's Avatar
Oddometer: 159
Originally Posted by Buddy_Holly View Post
Before I start beating the crap out of my swing arm bolt I want to make sure I have got it right.
1. remove rear wheel
2. remove bolts from rear shock
3. remove rear brake line hose guides and secure brake caliper
4. remove pivot nut and washer from the stand side of the bike
5. pound the crap out of the pivot bolt to remove it.
Am I doin' it right? Thanks!
Turn the bolt with a wrench a few rotations to break it loose. My bolt was very rusty but I was able to punch it out fairly easily.
RdrMtn is offline   Reply With Quote
Old 03-28-2011, 05:15 PM   #7869
Porter79
Ranger
Porter79's Avatar
Oddometer: 104
New proud owner needs help:
I just bought a 2005 XR650R and need some help/input on getting it registered in Nevada. If anyone has recently got their pig registered in Nevada or if you know of any information available on the forum I could definitely use a little assistance.
I also need help finding a dealer that is willing to do the inspection and sign the VP-254 form.
Any BRP owners that live in the Las Vegas area and want to help a guy out on learning more about my new XR give me a shout.
You teach and I buy beer!
Porter79 is offline   Reply With Quote
Old 03-28-2011, 05:32 PM   #7870
opcocrg
opcocrg's Avatar
Oddometer: 145
I got my carb issues sorted out finally. found another chunk of rubber stuck in the float valve seat. the rubber backing behind the petcock selector was dry rotted and was sending bits of rubber into the carb every time the selector was rotated. replaced the stock petcock with a new Clarke unit and cleaned the carb out and now it runs good and doesn't sit there leaking fuel everywhere. I feel so much better now
opcocrg is offline   Reply With Quote
Old 03-28-2011, 05:56 PM   #7871
Buddy_Holly
Imminent Train Wreck
Buddy_Holly's Avatar
Oddometer: 1,139
Rally and Rdr,
Thanks. I have a brass drift and am soaking the blt in penetrating solvent. The bolt will not spin at all....so I pound on it, and then pound on it again.
I will let you know how it goes- thanks guys.
Buddy_Holly is offline   Reply With Quote
Old 03-28-2011, 06:27 PM   #7872
lstzephyr
Solo con rambo
lstzephyr's Avatar
Oddometer: 1,781
I'm trying to choose between the seat concepts and the guts seat right now as well.
I just road the thing 1000km across mexico in 13 hours non-stop 3 days ago coming back from a copper canyon trip and I can tell you with absolute certainty the seat is not good enough!
lstzephyr is offline   Reply With Quote
Old 03-28-2011, 09:00 PM   #7873
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,463
here ya go china , i fitted the cover and foam myself took me 30 mins
mine is carbonfiber sides with gripper top , cant recomend them enough , great product great service great price ,
like i said i can now sit on my bike all day and get off with a smile , not that i didnt b4 the seat but now my bum smiles as well
heres there threaD i dont think theres a bad word said about them ,
best o luck , btw fits perfect on safari tank , clark tank , and stock tank , as i have those tanks here
http://www.advrider.com/forums/showthread.php?t=621311
Old 03-28-2011, 11:02 PM   #7874
GSXR
Trail Rider
Oddometer: 944
freight costs
How much did it cost to get this seat sent over Sean0
GSXR is offline   Reply With Quote
Old 03-28-2011, 11:07 PM   #7875
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,463
was under 200 deliverd , if i recall
got it in under 2 weeks i think was no longer than that tho , for the price its a bang up foam and cover IMO
Times are GMT -7.   It's 03:28 PM.
