Old 04-20-2011, 09:37 AM   #8281
JIPPERR
JIPPERR's Avatar
Oddometer: 67
Originally Posted by Big_John View Post
244.0 - 230.5 = 13.5 mm ...... Or 1.35 cm
Or...... 0.53 inches
Half an inch. ???????
Doesn't seem right.
Sorry to hit you with more 'book' information, but... each full rotation of the adjustment collar is said to use 1.5mm of the 13.5mm's worth of adjustment room and accounts for 14.3 kilos (30 pounds) of rider weight. When you think of it that way it does seem to provide for a pretty wide range of adjustment. Its all in the owners guide I swear! I'll admit the 14.3 kilos per turn bit does seem a little crazy, if only i had a 14.3 kilo weight and way too much time on my hands....
Maybe your shock spring has slacked out?
JIPPERR screwed with this post 04-20-2011 at 10:16 AM
JIPPERR is offline   Reply With Quote
Old 04-20-2011, 09:44 AM   #8282
Garthe
ROCKS ARE YOUR FRIENDS...
Garthe's Avatar
Oddometer: 4,360
Originally Posted by onlead View Post
XR
1 1/8" bars
100x38/40mm
Yes.
2007 XR650R
2001 Montessa 315R
Garthe is offline   Reply With Quote
Old 04-20-2011, 10:21 AM   #8283
onlead
Oddometer: 156
Originally Posted by Garthe View Post
Yes.
Thanks, Garth!
onlead is offline   Reply With Quote
Old 04-20-2011, 01:40 PM   #8284
Shibby!
Oddometer: 1,656
Doesn't seem right.
Originally Posted by EnDreamin View Post
The owners manual gives three numbers for the shock setting:
Maximum spring length 244.0mm
Standard position 236.5mm
Minimum spring length 230.5mm
Of course the sag at the standard position will vary by rider weight and need to be adjusted within the min and max spring length numbers to get about 95-100mm. That number comes off the pig pen website, I've found it to work well.
Just confirming these are spring preload adjustments?
There are also measurements of max and min length of the spring. They do sag over time and have a "wear" limit.
I didn't get around to looking at my eibach spring installation page. I'll see if i can do that tonight.
Tour of Idaho T1 Challenge - https://spotwalla.com/tripViewer.php...551f1642711d75
Eat. Sleep. Ride - The Great Divide: http://advrider.com/forums/showthrea...4#post19193704
Go, Get Lost - Heading South: http://advrider.com/forums/showthread.php?t=735690
Dirt Donkeys Do Baja: http://advrider.com/forums/showthread.php?t=671095
Shibby! is offline   Reply With Quote
Old 04-20-2011, 02:01 PM   #8285
onlead
Oddometer: 156
Hey guys,
I am interested in the deal that Highway Dirt Bikes is offering:
I am not able to verify the stock 650r top clamp (it's a long story ), so I am hoping that one of you either has one or can verify that this one would work:
XR
1 1/8" bars
100x38/40mm
from this posting:
http://www.advrider.com/forums/showp...59&postcount=7
I guess I didn't think this posting out to well...
I have the 7/8" bars now but want to move to 1 1/8". What would I need from HDB or someone else to do this?
Old 04-20-2011, 02:05 PM   #8286
slogger
Oddometer: 647
Anyone have a 11kg shock spring they'd like to get rid of?
If so, shoot me a PM. I"m in the market for one.
slogger is offline   Reply With Quote
Old 04-20-2011, 03:11 PM   #8287
Mackan
Player 1
Oddometer: 9
Lights out!
I was out riding the other day and all of a sudden, the lights went out. The bike still runs like a dream but with no lights or turn signals. Where should i start troubleshooting?
Had a go (almost) at it today but as you can see, something else required all my attention :)
http://a1.sphotos.ak.fbcdn.net/hphot..._4341382_n.jpg
Mackan is offline   Reply With Quote
Old 04-20-2011, 03:21 PM   #8288
Garthe
Garthe's Avatar
Oddometer: 4,360
Do you want to run a steering stabilizer?
A direct answer to your above question is: from HDB, lower handle bar clamps and their top clamp (below is the top part of this set up)...If you run a S/S then it's different.
2007 XR650R
2001 Montessa 315R
Old 04-20-2011, 03:22 PM   #8289
JIPPERR
JIPPERR's Avatar
Oddometer: 67
check these out, not such a wiz with inserting pics yet but this should get the job done.
https://picasaweb.google.com/1058672...77471179616354
https://picasaweb.google.com/1058672...76430037998082
(i figured it out)
JIPPERR screwed with this post 04-20-2011 at 04:32 PM
Old 04-20-2011, 07:31 PM   #8290
JIPPERR
JIPPERR's Avatar
Oddometer: 67
Since we've got posting pitures figured out
took this only a year ago....so much has been changed on it since! i'll try to get a current picture together of 'the beast' lol
Old 04-20-2011, 08:34 PM   #8291
SwampFox89
Old Skool
SwampFox89's Avatar
Oddometer: 47
Looking at getting a set of Shinko 700's for my piggy. Was wonderin what size you guys recommend for a rear. I will be running tubes either way.
4.60-18
or
5.10-18
or
130/80-18 TL
The way that you wander is the way that you choose.
SwampFox89 is offline   Reply With Quote
Old 04-21-2011, 09:06 AM   #8292
Shibby!
Oddometer: 1,656
(i figured it out)
Nice looking ride.
So yea, it's confirmed that they don't suggest or recommend shortening the spring much more then .54in. Longest (preload is required) is 244mm and if you spring measures less than 240 free length it should be replaced.
Good work. That's why I called caution on the one posted before when it's clamped down the threads to the degree it was. I know from installing mine that I was no where near the end of the threads.
The other alternative is simply to add spacers. Tusk makes a cheap solution ($24), or you can get something like ROX which are around $90. I have the Rox 1 and 1.5 and like them. Being 6'4" I wouldn't mind them a little higher, so I bought some CR Highbends yet to install. Just make sure to get the standard (7/8) to 1 1/8" risers.
Old 04-21-2011, 09:33 AM   #8293
onlead
Oddometer: 156
[sweet pics deleted]
Sweet setup, Jim! Currently I'm not using a steering stabilizer (though apparently everyone else does - I'm not too bright). So one last question: For the HDB lower clamps do I need the 10mm or 12mm bolt?
I guess by now you are wondering why don't I just go and look? I broke my leg Jan 29th, bought my XRR without being able to test ride it and it is sitting in a van that I can't get into or unload for a while. I'm just trying to get some parts lined up for when I can start my build. I'm also in process of procuring a TM40, stator rebuild, and 7" race light.
I do appreciate your help.
Old 04-21-2011, 09:52 AM   #8294
Garthe
Garthe's Avatar
Oddometer: 4,360
I don't know bolt size. I'd think they would reuse the stock one? I have BRP triple clamps and lower risers...with HDB as the cherry on top.
You have a broken leg...and you bought a XRR...I like your style.
2007 XR650R
2001 Montessa 315R
Old 04-21-2011, 10:08 AM   #8295
JIPPERR
JIPPERR's Avatar
Oddometer: 67
Nice looking ride.
Good work. That's why I called caution on the one posted before when it's clamped down the threads to the degree it was. I know from installing mine that I was no where near the end of the threads..
case closed
i had the 2" ROX risers, they're pretty nice. I managed to bend them in a wee spill. That said they probably kept my bars from getting mangled since they can rotate they absorb that sort of thing to a degree.
Times are GMT -7.   It's 03:23 AM.
