Old 04-26-2011, 06:20 AM   #8356
KASUYAHO
Road Hog
Oddometer: 3,646
Originally Posted by Sean-0 View Post
gimble , a person who talks the talk but cant walk the walk
hey did ya get those pics??
Fag Button , elect start with a red button for faggots to push , if ya cant kick it, ya cant ride it
Squid ,goes with out saying
but tru tho , i recon if you got it running right it will start every time , dont stall it on a hill and dont drop it , both of which i do all the time , but makes me learn my lessons
ppl point and larf , but there smile soon changes when there behind the xrr
I like the one where the gimps say,
the BRP is old tech.
Whats old tech?
Is it that we don't have to throw a shit load of money at the pig to keep it going makes it old tech?
KASUYAHO is offline   Reply With Quote
Old 04-26-2011, 10:53 AM   #8357
brad21
Farting in a Fan
brad21's Avatar
Oddometer: 3,611
While my buddy N2moto and I were down pre-running the B1k last year we ran into a JCR Honda box van just outside of Gonzaga Bay with TJ (JCR right-hand man) and Colton Udall, (JCR B team). Colton told N2 that he wished he was riding an XRR cuz the 450x was beating him up too much!
2k4 Wee-Strom, black, farkled, smells like bacon.
Use this code when opening a Smugmug account and get $5 off! HkVR4XuSGKW46
brad21 is offline   Reply With Quote
Old 04-26-2011, 12:28 PM   #8358
chip
Follow Me
Oddometer: 1,763
Interesting.
I've raced the XRR and the 450X. The only reason, and I mean only, I switched from the xrr to the x is because I fell over on a hill and was passed twice before I could get the bike started again.
chip is offline   Reply With Quote
Old 04-26-2011, 02:54 PM   #8359
jm-2008
jm-2008's Avatar
Oddometer: 513
Laugh Winter on the Gold Coast!
[QUOTE=Sean-0;15756106]Why do you ppl have soo much trouble starting on the stock carb
Its getting on to winter here , i can pull my bike out of the shed , pull up the choke leaver , get it to tdc , and bang
Winter on the Gold Coast -
From my iPhone weather -
Wednesday 23C & sunshine
Melbourne - currently 7C
jm-2008 is offline   Reply With Quote
Old 04-26-2011, 03:07 PM   #8360
Crabenho
NOOBish
Crabenho's Avatar
Oddometer: 609
Puke
[QUOTE=jm-2008;15766394]
Pull it out of the shed, start it, get off, kick it over on its side and wait til it dies, pick it up and try to get it to start "bang" in one kick.
My buzz ain't a sammich.
Crabenho is offline   Reply With Quote
Old 04-26-2011, 03:17 PM   #8361
Crabenho
NOOBish
Crabenho's Avatar
Oddometer: 609
[QUOTE=Crabenho;15766465]
Sorry, quoted the wrong dude. FOOOKin' "smart" phone.
Old 04-26-2011, 03:45 PM   #8362
brad21
Farting in a Fan
brad21's Avatar
Oddometer: 3,611
Originally Posted by chip View Post
Interesting.
Bear in mind that Mr. Udall had done COUNTLESS miles pre-running on the X and I believe wanted something a little more "couch" like...
We ran a 450x in Baja last year. Not having spent much time on one prior to the race, and then not a race-prepped one, I was quite impressed with the power and flickability. BUT, there is nothing like the piggy.
Old 04-26-2011, 07:11 PM   #8363
KASUYAHO
Road Hog
Oddometer: 3,646
Talking to a guy who raced Baja for many years was talking to JC at a function.
JC said the same thing to him.
Old 04-27-2011, 08:58 AM   #8364
opcocrg
opcocrg's Avatar
Oddometer: 145
I've been looking at picking up the TM40 carb and noticed that they usually come with new throttle cables. Are the cables "different" than the stock cables or just new?
reason for the question is that I just bought a sub mount top triple and have some RC high bend bars so I want to get the 3 inch longer cables to eliminate binding. but I can't find TM40 specific cables. The longer cables from motion pro don't say they fit a specific carb. If they're different I'll wait to mount the new triple and bars till the carb shows up. I don't want to get the longer cables for the stock carb and then have to buy a different set when the TM40 carb shows up.
opcocrg is offline   Reply With Quote
Old 04-27-2011, 09:01 AM   #8365
HickOnACrick
Groovinator
HickOnACrick's Avatar
Oddometer: 2,520
Question gentlemen:
How do you know if a brake caliper is bad?
Last night, when I tried to put my front wheel back on, I couldn't get the brake pads apart using the usual method (sliding a tire iron between the pads).
Eventually I had to remove the caliper entirely, drain all the brake fluid, remove the pads, and use a C-clamp to depress the brake pistons.
After that, I replaced the caliper, put the wheel back on, bled the brakes, but now the piston won't depress again (hard to turn the front wheel).
Is it shot? Can I rebuild it?
KTM 500 XCW, BMW K1600GTL
950 SER 300 XC
Composites 101
Utarded in Baja
Circumcising Utah
HickOnACrick is offline   Reply With Quote
Old 04-27-2011, 09:04 AM   #8366
Garthe
ROCKS ARE YOUR FRIENDS...
Garthe's Avatar
Oddometer: 4,356
I just went through this, the cables are different.
2007 XR650R
2001 Montessa 315R
Garthe is offline   Reply With Quote
Old 04-27-2011, 09:52 AM   #8367
opcocrg
opcocrg's Avatar
Oddometer: 145
Since I'm basically copying your set up, what did or are you doing about the cable situation?
Old 04-27-2011, 10:07 AM   #8368
Garthe
Garthe's Avatar
Oddometer: 4,356
I had the company who provided me the carb supply the cables (Motion Pro cables). I did 5" over stock.
2007 XR650R
2001 Montessa 315R
Old 04-27-2011, 10:24 AM   #8369
Tim McKittrick
Oddometer: 1,744
Originally Posted by HickOnACrick View Post
Question gentlemen:
I suspect your pistons are sticking in their bores due to a buildup of corrosion and glop- you need to dismantle the caliper and carefully clean both the bores and pistons- or replace the pistons if they are showing obvious signs of pitting and corrosion. Also replace both the wiper and retraction seals of the pistons.
Piston (2) # 43107-MGB-006
Seal set (2) # 66431-MA3-405
The only difficult bit can be getting the stuck pistons out of the caliper- in most cases they can just be pumped out with brake fluid, but others on the forum have had to resort to forcing them out with grease, compressed air, etc.
The takeaway here is the real need to change and flush one's brake fluid every year or so- brake fluid gets darker as it absorbs water and other contaminants so it's a good idea to replace it with fresh fluid (from a sealed container- or else the stuff you are pouring in may have as much water and crap in it as what you are removing) once it begins to get noticeably dark.
Tim McKittrick is offline   Reply With Quote
Old 04-27-2011, 11:28 AM   #8370
HickOnACrick
Groovinator
Oddometer: 2,520
Thanks for the reply. Looks like I get to teach myself how to rebuild a brake. Hooray for youtube!
Oh, and by the way, say hello () to Sarah for me.
950 SER 300 XC
Composites 101
Utarded in Baja
Circumcising Utah
Times are GMT -7.   It's 07:16 AM.
