Old 06-08-2011, 08:27 PM   #8956
cdogg44
Oddometer: 217
Originally Posted by RideFreak View Post
Which fuel tank are you running? I found the big tank tends to shroud the the cyl head and it cuts down flow some through the rads. It def runs warmer with the 25L tank.
Also I wouldn't put allot of stock into the comparison, it's not really apples to apples. It's not uncommon for two identical senders from the same manu to vary 5 to 10%, the exception being milspec thermistors and even then the system needs calibrated to get real accuracy.
Clarke 4.3
It is the same sender. I took the Vapor off my other bike when I sold it and instead of butchering the coolant hose I drilled and tapped the thermostat housing. Same sender.
Although, with it being on the backside of the thermostat housing that does place it awfully close to the headers. Maybe it's a few degrees warmer there and it's heating up the sensor from the outside and conducting it through to the pickup. Who knows...I just seem to remember the stock bike always wanting to run ~90* above ambient which would've put me at ~185* Saturday and I'm just chasing a few degrees because I'm curious.
cdogg44 is offline   Reply With Quote
Old 06-08-2011, 08:34 PM   #8957
Capt. Egregious
Capt. Egregious's Avatar
Oddometer: 376
What sort of coolant hoses are you guy's running on your piggy's? O.E.M? Silicone? My XR finally needs coolant hoses after 11 years. Any info appreciated.
Capt. Egregious is offline   Reply With Quote
Old 06-08-2011, 08:39 PM   #8958
crypto666
Oddometer: 1,329
Originally Posted by cdogg44 View Post
Clarke 4.3
Different bike and different temp source? Maybe your head gasket is blown.
I also ride a WR450, and that thing gets hot quick and stays there, but is aparently normal. I don't have any coolent readings, just qualitative data.
crypto666 is offline   Reply With Quote
Old 06-08-2011, 10:44 PM   #8959
RallyMoto
RallyMoto's Avatar
Oddometer: 147
Crypto, I spoke with Diane at Precision Concepts when I did my rebuild, hoping to do the same thing you're planning. HRC/Honda has no plans to make the timing chain kit anymore. You can get the actual HRC cam still, but it's $500+ now in non-kit form.
After thorough research, I elected to go with a new Honda chain. I could find no info stating any aftermarket timing chains were better.
RallyMoto is offline   Reply With Quote
Old 06-09-2011, 12:03 AM   #8960
JIPPERR
JIPPERR's Avatar
Oddometer: 67
hey! how does the shifting feel when your bike heats up? i've been noticing some notchy-ness for a few shifts after idling at lights, stuck in traffic etc. Is this normal? Also running Devol rad guards, put them on over the winter and it seems to me that things have heated up a bit but nothing conclusive as i'm procrastinating on getting the TT vapour unit.
Obviously in the mud they are an asset but will taking off the plastic rad 'louvers' help keep cool in day to day street riding?
JIPPERR is offline   Reply With Quote
Old 06-09-2011, 03:49 AM   #8961
rocketmanphil
rocketmanphil's Avatar
Oddometer: 187
[QUOTE=nella;16105384]The only frame of reference I have is a FMF Q4 on a XR650L and the R4 is way louder than that. I may try to find something a little more tame so as not to completely alienate all my neighbors.
I run a full Arrow system, although, I have had it rebuilt, re-packed and the muffler shortened about 20mm. I have found that it is mmmm bit loud but I just am bit more carefull on the throttle
A man may smile and bid you hail
Yet wish you to the devil;
But when a good dog wags his tail,
You know he's on the level.
rocketmanphil is offline   Reply With Quote
Old 06-09-2011, 08:12 AM   #8962
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,177
Clarke 4.3
The 4.3 tank shouldn't be an issue. Running the TM40 on the lean side might be some of what your seeing with the temp difference. Personally I'll trade a little extra heat for the extra mpg. Is it boiling over on you? Most folks use that as the bar since they don't have any coolant temp readout. In summer, mid 90s ambient in traffic or soon after I stopped on a technical trail with it idling mine would boil the coolant which is why I added a fan. Not sure how well the fluidynes rads work in that situation, I've heard they are a big improvement over the OE stuff. This time of year the OT has been running about 200 (moving) and spiking to 225 when stopped or in traffic, previous to the fan it'd spike up around 250~260 which is the upper limit I'm comfortable with. Why don't you pull the guards and take it for a run, see if that's the prob.
Chris
"Life's journey is not to arrive at the grave safely in a well preserved body, but to rather skid in sideways, totally worn out, shouting ... Holy Shit, what a ride!"
CL Adventure Ride 2013 /CL Revisited 2014 / 700 Miles of Scenic Utah Backcountry / MY VIDEOS / RIDEFREAK TV
RideFreak is offline   Reply With Quote
Old 06-09-2011, 08:52 AM   #8963
AJ..
AJ..'s Avatar
Oddometer: 1,596
Hey fellas,
I am back with my 2nd BRP after sold the 1st 1 late last year.
This time,I got something with little milege over the last 1.The last one already gone over 120,000km....now the 2nd one,has only 25k km on it.
Hope it will bring more riding episods like the last 1.
So I am putting back my ol wallpaper back on.
Cheers,
AJsgp
HONDA XRV750-02,(woot-woot)BMW R1100GS-'98()BMW F650GS-01
Suzuki XF650Freewind-01
Husqvarna TE510centennial Rallye-04
KTM640ADV,KTM620DUKE projected()[COLOR=red]VF750C-96(project tracker)
http://www.facebook.com/pages/AJs-friends/158711187491373?v=wall[/URL]
AJ.. screwed with this post 06-09-2011 at 08:58 AM
AJ.. is online now   Reply With Quote
Old 06-09-2011, 09:26 AM   #8964
crypto666
Oddometer: 1,329
I hear ya, I ordered the HRC timing chain/sprockets/guide by part number and it was painful. Should be in the mail now though. Like you said, I donít know that it is necessary, but I am/was in panic mode trying to get my bike back together and want it done right. It has been very reliable and I want to keep it that way, but I havenít heard of a lot of timing chain failures, if any. So I probably should have spent that money on a new carb, but I guess this way I can tell people how much better person I am since I have the HRC timing components.
XRís Only also said that the OEM chain was as good as it gets (in reference to the unavailability of the HRC kit).
I think the weakest link in this motor is the connecting rod. That is the only part out of spec on my motor, not including the gaping hole in the case. The lubrication for the rod has a minor flaw. There is only a single oil jet spraying the bottom of the piston and the wrist pin/ which then flows down to the crank. Because it is a single jet spraying from the side it creates a shadow on the flywheel side of the crank/rod/piston. If you look at the pic of my wrist pin you can see one side is like new, the other is like trashed.
Old 06-09-2011, 09:39 AM   #8965
cdogg44
Oddometer: 217
Those are my exact same numbers. And like I've said all along, I don't think I have a problem at all I just wanted to confirm that in 95* weather a water temp of 200* at 55mph was normal.
Last June was a looooooooong time ago! Ha I remember a year ago right now when I had just brought my first BRP home I boiled it over in the driveway letting it idle (trying to sort through the PO's wiring nightmare).
Old 06-09-2011, 11:29 AM   #8966
crypto666
Oddometer: 1,329
so you bought a used xrr?
Getting a replacement crankcase is proving to be nightmare. I got a call today about my crankcase order a they won't sell me one because according to Honda's data base I am not the owner. As if honda's data base has any clue. So now I have to go through a dealer to get the info changed in Honda's data base, which wouldn't be a big deal other than I live in the middle of no where. The closest dealer is 2 hours away, half of which is torn up dirt road. Luckily my honda dealer since childhood is allowing me to email them my stuff and they will change it.
So if you bought your bike used, you might want to let honda know because according to them, you don't own the bike.
Old 06-09-2011, 12:10 PM   #8967
PeteN95
PeteN95's Avatar
Oddometer: 2,780
Red silicone hoses from Ebay, "ASI" brand I think? About $60 shipped and very happy with them.
"If you ain't slidin', you ain't ridin'"
SVN/XRR/XC-W
PeteN95 is offline   Reply With Quote
Old 06-09-2011, 12:49 PM   #8968
crypto666
Oddometer: 1,329
balancing cranks
I see a few folks are building motors right now. How many of you are changing pistons etc. And are balancing the crank?
This is getting really expensive really fast, so I am looking to avoid paying for luxury items. From what I gather my new piston is 14g lighter than oem, differences in the falicon rod weight isn't known yet. According to Falicon I do need to balance, XR's Only says it is a luxury and isn't necessary, and I am waiting to hear from Crank Works.
I am wondering if the Falicon rod will be slightly heavier with roller bearings and with a slightly lighter piston all things will be close enough?
Old 06-09-2011, 04:12 PM   #8969
dirtard
Oddometer: 228
got my supermoto kit on today
need to clean her up and paint some stuff, but put on 150miles of tight twisties before work and its great.
dirtard screwed with this post 06-09-2011 at 06:08 PM
dirtard is offline   Reply With Quote
Old 06-09-2011, 05:35 PM   #8970
crypto666
Oddometer: 1,329
I found my answer: http://www.advrider.com/forums/showt...=251589&page=2
This was the best explaination I have seen for us thumpers. Saved me some cash, now I can eat.
Times are GMT -7.   It's 03:31 AM.
