Old 07-13-2011, 12:30 AM   #9271
opcocrg
opcocrg's Avatar
Oddometer: 145
Well.......the pig finally kicked me in the balls tonight. I needed to go pick up some $$$ from a guy who didn't pay me for a side job I did a few weeks ago so I called up a buddy to see if he wanted to take his new DRZ out for some gravel road hooliganism on the way out there but he couldn't go so I went off on my own. I left the house and started my 15 mile all gravel road ride without any problems. I was having a good time until I got to the last stop sign about 2 miles from this guys house when the pig died and I coasted to a stop. The 2 or 3 times this has happened in the past the bike always re-started on the first kick and didn't give me any other problems. Tonight....that wasn't the case. I kicked that thing for 5 min until I was good and pissed off and thoroughly soaked in sweat (leather jacket, full face helmet and the Missouri mid summer humidity ). I guess I fiddled with the choke and the idle adjustment screw enough that it finally started and idled so I rode the rest of the way to this guys house. As I got to the beginning of his driveway the bike died again. I tried once again to get it started but this time it just wouldn't start so I left it sitting by the road and I made the 150 meter walk up the guys gravel driveway to get my $$$. By now I've lost about a liter of sweat and I'm in a shitty mood. I politely collect my $$$ and make my way back down the driveway (in the dark now) to the 300 pound paper weight I'm going to have to push home. The guy offered to let me put it in his barn till tomorrow but I didn't want to hassle with that and told him I wanted to try and get it running and I would just call a friend to come get me if I couldn't. I got back to the bike and kicked on it for a few minutes and got nothing. I cranked the idle adjustment screw up damn near all the way and it finally fired up and idled. I took off and started down the road and it sounded like I had the throttle pinned wide open so I reached down and turned the adjustment screw back down and it died. I pulled over and tried starting it again with no luck. Now it starts to rain, it's muggy as hell and I'm sitting on the side of a gravel road in the dark, in the country with no lights and a dead bike and I'm really getting angry. I cranked the idle adjuster way up and again it finally starts and i take off. But just like before, every time I pulled the clutch in to shift it sounded like the throttle was wide open but I wasn't going to stop this time till I got home. I rode the rest of the way home on the blacktop instead of the backroads and when I got into town I never stopped for a single traffic light or sign. I've been having an issue with a "hanging throttle" lately so the carb has been off and cleaned and it's been tinkered on a few times in the last week or so while trying to diagnose the problem but it's never not started like this and I've always been able to "blip" the throttle to make the "hanging" stop. Also, I've never had to crank the idle adjustment scew up so much. I'm not really sure where to go from here.
'10 WR300
opcocrg is offline   Reply With Quote
Old 07-13-2011, 02:07 AM   #9272
atreiou
XR 650R Rider
Oddometer: 61
a week end over 10.000ft in Italy
for who want, more pics here
http://www.xr-italia.com/forumxr/ind...?topic=39405.0
atreiou is offline   Reply With Quote
Old 07-13-2011, 07:56 AM   #9273
crypto666
Oddometer: 1,276
Don't buy the less expensive chain.
So I was excited to finally get the parts to start putting my motor back together after a chain break took out my crank case.
Everything went back together smoothly and without a problem, until I started turning the gears and noticed a wobble in my counter shaft. WTF!
How can a chain break screw up so much stuff?
crypto666 is offline   Reply With Quote
Old 07-13-2011, 11:26 AM   #9274
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 14,826
Dammit, that sucks!!!
larryboy is online now   Reply With Quote
Old 07-13-2011, 11:32 AM   #9275
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 14,826
Sounds a lot like what I did to my 2002. I'd been swapping main jets and checking against my butt dyno on the way to work. She started flaming out like that and I found that my emulsifier tube was loose from all my main jet changing, but it never fell out of the plug on the bottom because the baffle bell thing keeps it from falling out of the bowl when you take the plug out to swap the main.
Old 07-13-2011, 05:07 PM   #9276
KYLEISCOOL
Who
KYLEISCOOL's Avatar
Oddometer: 144
I had a hanging throttle every once in a while and I did a valve adjustment and now I havent had the hang up since. Not sure if this is your case but worth a try. My intake valves were on the tight side. exhaust was fine.
Gotta ride something! 02' XR650R slightly personalized
KYLEISCOOL is offline   Reply With Quote
Old 07-13-2011, 05:23 PM   #9277
KYLEISCOOL
Who
KYLEISCOOL's Avatar
Oddometer: 144
xr650r rear spoke set
Im looking for a set of rear spokes for my 650r. If someone has a set that they dont need Pm me.
Old 07-13-2011, 06:20 PM   #9278
crypto666
Oddometer: 1,276
shoot me, now.
Edit 2: after eating some food and snugging a nut on the primary, I only get about .03mm run out.
crypto666 screwed with this post 07-13-2011 at 09:51 PM
Old 07-13-2011, 09:08 PM   #9279
RallyMoto
RallyMoto's Avatar
Oddometer: 147
Originally Posted by BuRPsa View Post
Ah!!
XRsO have not yet answered. If they won't then I'll take the trouble to stay up & phone them (my eve is your morning).
Meantime, would you mind to tell - try to - what precisely you mean with "the wrong moment"?
Here's why. The 'auto-decomp' is active when rotating forward, under a certain (low) rev-ceiling etc etc, and this bit I actually value zero. I know how to kick it, better still, that auto-system I sometimes curse because it does too much.
But - it also, crucially (according to me, and typically Honda-clever I'll admit), will immediately engage when it reverses direction, and lift a valve so as to 'bleed' any compression - a back-kicking powerstroke! Hence my tender bones will survive THIS bit I want to keep, and there can't be a 'wrong moment' like you say.
I've got a fair idea how it works, have seen some exploded views, but have not yet opened it up. Of course I will (have to), but if you're able to elaborate somewhat then such will be appreciated.
You got yer answer from XRO by now, but it just looked like it would engage "longer" in the cam rotation and blow everything out the exhaust instead of allowing "contained" combustion. I just mocked it up for a few seconds late at night, so I could have been way off. I didn't put too much effort into it since XRO had already told me it couldn't be fitted.
I wonder if you use the stock decomp mechanism on the real HRC cam since it still retains the feature, or if there is a new one?
RallyMoto is offline   Reply With Quote
Old 07-13-2011, 10:38 PM   #9280
opcocrg
opcocrg's Avatar
Oddometer: 145
I just did a check and adjust last week hoping it might clear it up but after I was done it rode the same, sounded the same and felt the same as it did before the adjust. I don't think we did it wrong but it was both mine and a buddies first time doing an adjustment so who knows. Due to the fact I rode it several times in the last few days without a problem I tend to believe we didn't mess anything up. What has me confused is when I went out there tonight to try and see if I could get it started............for some reason it started on the first kick and seemed to run fine in the garage. I didn't take it for a ride but sitting in the garage it seemed to be back to normal.
Here's a question for anyone who might know:
Could humidity have anything at all to do with how it runs from one day to the next? My girlfriends street bike is carbureted and it seems to runs fine whether it's humid or not so I wouldn't think it has an effect but I haven't got a clue.
'10 WR300
Old 07-13-2011, 11:23 PM   #9281
dirtard
Oddometer: 228
actually yes it can, but most the time things run better with a bit of humidity. my ninja 250 actually ran quite a bit different(better) when it was humid as hell
dirtard is offline   Reply With Quote
Old 07-13-2011, 11:42 PM   #9282
plane_ben
plane_ben's Avatar
Oddometer: 56
Back when I had my BRP, the hanging throttle was always a gummy carb slide right at the engine side of the carburator. When ever I would feel it start to hang, I would pull the inlet boot off the back of the carb, open the throttle all the way, and squirt the throat out with carb cleaner. It would hang worse with higher octane fuels, so I went to 87 octane only. I could see tight valves doing this to, but I always stayed on top of mine and adjusted pretty good.
plane_ben is offline   Reply With Quote
Old 07-14-2011, 03:33 AM   #9283
Riding Loose & livin
Oddometer: 56
Aus highcounrty
Finally stretch her legs again...
Riding Loose & livin is offline   Reply With Quote
Old 07-14-2011, 03:36 AM   #9284
Oddometer: 56
n
Old 07-14-2011, 03:39 AM   #9285
Oddometer: 56
h
Times are GMT -7.   It's 07:52 AM.
