Old 07-24-2011, 05:43 PM   #9406
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,249
'sell it'
No blasphemy here pleeze![/QUOTE]
Lots of low hr. XRRs out there because the owner couldn't man up enough. That includes being "skeerd" of the power
I got mine from just such a person. He actually half attempted to talk me out of buying it.
I told him I'd take my chances
Chris
"Life's journey is not to arrive at the grave safely in a well preserved body, but to rather skid in sideways, totally worn out, shouting ... Holy Shit, what a ride!"
CL Adventure Ride 2013 /CL Revisited 2014 / 700 Miles of Scenic Utah Backcountry / MY VIDEOS / RIDEFREAK TV
RideFreak is offline   Reply With Quote
Old 07-25-2011, 06:59 AM   #9407
slogger
Oddometer: 654
Originally Posted by aaronp1264 View Post
OK I killed my bike going up a road construction side hill (the road is being done going up a hill and there was a steep-as-shit dozer path going up the hill) for the second time, made it just fine the first. Washed out right towards the crest of the hill and I couldn't keep it running as I laid it over. So I had to back my bike down the hill and almost died of exhaustion. I'm 150 lbs and have owned this XR for a month and half.
So at the bottom I kick it over and I read the other night that the best way to start a flooded 650 was to turn the gas off and hold the throttle open.
BAM.
Loud noise and fire.
I look down and there's a small flame at the end of one of the vent tubes on the underside of my bike. I kick the flame out.
At this point I wonder if I just ruined the bike. Next kick over it starts right up and I quickly put my helmet on and pull away. Rides perfectly normal the 30 minute ride home.
Has anyone experienced this before and was this the sonic boom of flooded xr650s?
fucking awesome construction site though, seriously it felt like finding a level from excite bike 64
Pull your airfilter out and take alook at the back side of it. Pretty likely it was melted. Might want to replace it.
slogger is offline   Reply With Quote
Old 07-25-2011, 07:29 AM   #9408
crypto666
Oddometer: 1,388
Originally Posted by RideFreak View Post
'sell it'
I got mine from a guy who's wife was pregnent and needed to sell it (he bought it from a kid who was scared). So I bought it, then my girlfriend got pregnent. Luckily it didn't work out and I still got the bike. I told the guy what happened, he said it is because the bike gives us big balls.
crypto666 is offline   Reply With Quote
Old 07-25-2011, 07:34 AM   #9409
crypto666
Oddometer: 1,388
Beware of strange noises.
Well I had never held an ear up to my xrr motor while revving it until I rebuilt it. So I just thought I would share my experience with my newly rebuilt motor, the used Edelbrock pumper I put on it and what happens when you listen too closely.
During the first couple break-in runs I found the carb to be on the lean side, so I turned the fuel up. Then it went rich, very rich. The plug was coming out covered with soot. I wondered WTF; I didn’t turn it more than half a turn rich. So I turn the screw to lean it, and I turned it again, and again, and it still rich. Plus the only way to get it to start is to do the hot-start procedure, which I don’t care for on a new engine. So I sat there doing what I felt like was damage to my new engine for about two hours or more. I also notice some chatter coming from the motor when I revved it up; it wasn’t bad but made me very concerned. So I thought maybe my valves need adjusting and perhaps I should check the timing chain. I pulled the valve cover and everything looked fine; re-torqued the head and put it back together. I tried to run it and the still the same thing. So I pulled the top off the carb and found my problem; the adjuster body backed out of the slide; it was at full rich. So I fixed that and set the adjuster screw to the mid-point. After a couple runs I had the carb dialed in. However I still had this random clanging sound when I revved it. I pulled the magnetic drain plug and found a few chips. I thought “oh great, a new motor and now my tranny is screwed.” I was so pissed I said to hell with it, threw my ratchet across the shop, and took it for a test ride and rechecked for metal chips and found nothing new. Then I decided to lube the drive chain and take it for a longer ride. While doing so I noticed a clunking sound while I turned the rear wheel by hand. After scratching my head for 5 minutes or so, I realized what the sound was. It was the damn dogs on the gears bumping against their engagement holes. Because the bike was sitting slightly tilted on the kick-stand the gears were sliding to one side and making that noise; perfectly normal, unlike my mental state.
I took it for its first high power test ride and this thing pulls like no other. The response is awesome, no flat spots. I was only on gravel road and couldn’t get any traction, so I can’t wait to get some new rubber and get it in some good dirt, or even pavement to see what this thing will do. I am imagining the front wheel will spend more time off the ground than on. This thing rocks.
Old 07-25-2011, 10:04 AM   #9410
BuRPsa
Finally growing up..
BuRPsa's Avatar
Oddometer: 548
Rrrrrrrigth, so oot the window goes my patience now
I'm waiting for almost same parts to be sent, and normally I'm a patient chap
Good on you Crypto, have fun!
Got my bike off a trader who had put an open silencer on a new bike & had opened the intake rubber, I presume in an attempt to "de-cork" it. Yeah, a disappointing ride, so he sold it.... to me as it turned out. No, he can't buy it back if he wants to ;)
BuRPsa is offline   Reply With Quote
Old 07-25-2011, 12:40 PM   #9411
Johnny55
Oddometer: 401
Let's beat the Dead Horse "stator/lighting question" again.......
What are the real wattage numbers on the output of a stock stator? I am seeing estimations from 65 to 95 watts on a stock stator. I ask because after the other night's single track thru the trees in the dark with a candle for a headlight, I am adding 2 35w HID lights and a battery.
I think I can get away with running the stock stator to charge the battery and run the HID's for several hours without losing too much power from the battery. Basically The power from the stator should run the lights and the battery will take the excess voltage. In the worst case, the HID's will be discharging the battery at about 3 amps, maybe less. Each HID draws 35w and 3.2 amps when warmed up(more at start up) but more then likely I will only be using 1 HID at a time. This is why I am trying to use the stock stator instead of a rewound stator since I am only drawing around 85-100 watts with ALL my lights going.
Input anyone? Rewind or stock? I will be using a Ricky Stator reg/rec. Thanks guys
Johnny55 is offline   Reply With Quote
Old 07-25-2011, 12:49 PM   #9412
crypto666
Oddometer: 1,388
I would rewind my stator using high quality wire from gobrushless.com. I would then use the 55w HID bulbs and digital ballasts ($25/set) from ddmtuing.com in a housing of my choice, preferably something cheap. I converted one of my 100w PIAA halogens to HID and it works well because the glass lens is what controls the light pattern, not the reflector.
I would also be posting this in the xrr electrical thread,
You could do all this for not much more than $100-$150 and a few hours time.
Old 07-25-2011, 05:13 PM   #9413
Johnny55
Oddometer: 401
Shit, I thought this was the thread that had all the XRR electics info. Thanks for the heads up and the advice.
Old 07-25-2011, 08:14 PM   #9414
SpeedoJosh
SpeedoJosh's Avatar
Oddometer: 832
Anyone here happen to be driving from Colorado towards North Carolina anytime soon? Looking on getting an XR this way so I can join in and stop lurking this thread.
SpeedoJosh is offline   Reply With Quote
Old 07-25-2011, 09:23 PM   #9415
Shibby!
Oddometer: 1,666
I would also rewind the stator. Not much work, or cost and the outcome is 100% better. Remember you'll need a regulator / rectifier to handle the higher wattage and AC-DC conversion.
I run a 35 HID in my Trailtech 8" light and it's BRIGHT. I'm tempted to try the 55w.... I use a cap instead of a battery, and the only "issues" I have is if my turn my fan on at idle the HID dims for a second. Not great on the HID, but at 25$ treating them harshly isn't a huge issue. I carry the 50W halogen bulb just in case.
Tour of Idaho T1 Challenge - https://spotwalla.com/tripViewer.php...551f1642711d75
Eat. Sleep. Ride - The Great Divide: http://advrider.com/forums/showthrea...4#post19193704
Go, Get Lost - Heading South: http://advrider.com/forums/showthread.php?t=735690
Dirt Donkeys Do Baja: http://advrider.com/forums/showthread.php?t=671095
Shibby! is offline   Reply With Quote
Old 07-26-2011, 07:33 PM   #9416
AtomicGeo
Chile Eater
AtomicGeo's Avatar
Oddometer: 4,283
WTF? Page 3? Had to actually scroll to find thread.
2003 KX250 - plated
2014 WR450F - plated
AtomicGeo Videos
AtomicGeo is offline   Reply With Quote
Old 07-26-2011, 08:00 PM   #9417
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,469
Originally Posted by basalt View Post
After a weekend at Stonyford, CA I decided it was time to install a fan. $140 for the KTM fan wasn't looking good to me until I found just the SPAL fan on ebay for $40. I am running the Clarke 4.3 gal tank.
I hacked up some 1/8" alum. plate I had lying around for the bracket and mounted it up. Will wire up the switch when my sealed connectors get in. I do plan to "lighten" the bracket for better flow. I removed one of the bolt holes on the fan as it interfered with the radiator support/bolt
Parts:
VA32-A101-64A - SPAL 4" Puller - $40
Left over 1/8" Alum. Plate - $0
RC car axle bearings - 5mm spacers (between bracket and fan) - $0
3x #10 SS pan head screws - $0.99
Sumitomo Waterproof MT Connector - $3.95
Switch - $9.99
thanks for the heads up on this idea , i have just had my fan turn up and am iching to install it , and my vapour and my pivot pegs and my fairing and my HID lights and my lots of stuff
but cant do any of it till my knee heals after i rotated it on sunday on a 2 day ride
heres a link to my youtube channel if you like to see my attempt at vids
http://www.youtube.com/user/xXsnitchyXx?feature=mhum
Sean-0 is offline   Reply With Quote
Old 07-26-2011, 10:14 PM   #9418
Shibby!
Oddometer: 1,666
That's a pretty sweet vid. Fun trails, good group of riding buddies. How can't that be a good time?
Love the part with you guys ripping up that back road all following each other. Days without dust are great! Just watch for the roost.
Old 07-27-2011, 07:27 PM   #9419
dirtard
Oddometer: 228
alright guys what is the small hole just below the sparkplug thats kinda hidden by the coolant line? im leakin oil out of there
dirtard is offline   Reply With Quote
Old 07-27-2011, 08:08 PM   #9420
crypto666
Oddometer: 1,388
That is a drain hole for the spark plug, so the oil that is probably leaking from your valve cover can drain out. The oil is probably leaking from your valve cover at the cam bearing. The question is why? Hopefully you don't have plugged cam oil holes.
Times are GMT -7.   It's 10:16 AM.
