Old 08-30-2011, 08:24 PM   #9916
aiMhi
Now with Titanium
aiMhi's Avatar
Oddometer: 686
Originally Posted by Big_John View Post
Got some goodies for the Pig.... Will report back on the fit and the performance......
I thought I would never destroy my skidplate- and then I did about two months ago. I upgraded just before RMAR to the XR's only Ricochet that looks kinda like yours. It gives me alot more confidence on rough trails but man oh man, it adds noise, something unbelievable - I thought I needed to set my valves after I installed it. I am thinking of adding some Dynamat or something to cut the clatter.
I will wait to read your review on the Tusk bark busters, need those bad.
Since I know you are hopping up your XRR this might be of interest. I installed the 4" SPAL Fan ($38) last weekend. It works great and still no battery needed on the stock stator! Just installed a $5 Full-Wave Bridge Rectifier (RadioShack model 276-1185) to convert the AC to DC. The fan, my LED rear light, 12V charger, Vapor and light works just fine. Even at idle there is plenty juice to run the fan. I did install a waterproof switch for it so I can turn it on or off if I need.
Isnt this a great hobby
aiMhi - Honda XR650R - AMA- RMAR
aiMhi is offline   Reply With Quote
Old 08-30-2011, 08:42 PM   #9917
Johnny55
Oddometer: 401
I have been looking at the Tusk hand guards with the built in LED turn signals. they look like they are pretty good units What is the part number on that axle wrench?
Johnny55 is offline   Reply With Quote
Old 08-30-2011, 09:16 PM   #9918
Johnny55
Oddometer: 401
Originally Posted by jimmyx View Post
Anyone running 2" Rox Risers with stock cables.(renthal bars-low)
Thanks in advance,
Jimmy
I am running 1.5" Up and forward risers with stock cables. I have not had any trouble.
Old 08-30-2011, 09:27 PM   #9919
jimmyx
jimmyx's Avatar
Oddometer: 165
Thanks Johnny55,
Cable Reroute?
"I'd rather have a bottle in front of me than a frontal lobotomy"
Dorothy Parker
jimmyx screwed with this post 08-30-2011 at 10:27 PM
jimmyx is offline   Reply With Quote
Old 08-30-2011, 10:07 PM   #9920
Shibby!
Oddometer: 1,657
Just discovered I cross threaded my damper rod in my shock when I re-vavled it some 6-7000km's ago. Pretty peed to discover that, but at the same time I'm extremely excited it held the entire time! That could have been a hell of a ride depending on when it let go...
Sooo. Anybody have a used shock? Condition doesn't matter other then the rod is not pitted and not bent. I'll be replacing the damper assembly with my own and the piston/seal head and installing in my shock body. No need for a spring either.
Looking for as cheap as I can get. Sunk a few grand into this bike in the last month and hurting now
What not to do when re-valving suspension.... I feel like such an idiot.
Tour of Idaho T1 Challenge - https://spotwalla.com/tripViewer.php...551f1642711d75
Eat. Sleep. Ride - The Great Divide: http://advrider.com/forums/showthrea...4#post19193704
Go, Get Lost - Heading South: http://advrider.com/forums/showthread.php?t=735690
Dirt Donkeys Do Baja: http://advrider.com/forums/showthread.php?t=671095
Shibby! screwed with this post 08-30-2011 at 10:20 PM
Shibby! is offline   Reply With Quote
Old 08-31-2011, 12:20 AM   #9921
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 14,667
Thanks Johnny55,
Cable Reroute?
All of this and those are KX hi bends with stock cables:
Old 08-31-2011, 05:31 AM   #9922
jtworldwide2
Oddometer: 61
Looking to order up a stage 1 hotcams for my sumo BRP...
Anything else i should think about changing out while the motor is that far apart? I was thinking the rear cam chain guide, the CCT, and the cam itself of course. New cam bearings? (does the cam come with them?)
jtworldwide2 is offline   Reply With Quote
Old 08-31-2011, 06:35 AM   #9923
atreiou
XR 650R Rider
Oddometer: 61
I really don't understand how this system can help the rear subframe.
the fixing point are always the same.. the long bolt trough the frame.
where the iron cables turn around with rubber tubing..
Originally Posted by Johnny55 View Post
Did some KLR'ed farkles to the XRR today. Been thinking of an easy, affective way to help support the rear subframe. I got to looking and saw a solution:
It might work good. I will defintely help! I did have to mod the bottom of the seat alittle but nothing major
Parts list:
2' of 5/32" cable
4 - 1/8" to 3/16" cable clambs
2- 3/16" turn buckles
8" of left over nylon tubing
misc hardware
Attachment 285851
atreiou is offline   Reply With Quote
Old 08-31-2011, 07:11 AM   #9924
xr400r
xr400r's Avatar
Oddometer: 3,149
I have a 2003 xr650r for sale in the flea market if anyone is interested.
Riff Raff 2015!
xr400r is offline   Reply With Quote
Old 08-31-2011, 07:14 AM   #9925
BikePilot
BikePilot's Avatar
Oddometer: 11,251
I would do the chain itself for sure. Don't know about the bearings -- post up when you figure it out, I might do a stage 1 myself.
'09 Buell XB12XT, TL1000S, H1F, M620, CR250R, KX100, XR650R, Cota 315R
Summer 2009 Ride Report http://advrider.com/forums/showthrea...1509c&t=507038
Summer 2008 RR. http://www.advrider.com/forums/showthread.php?t=367703
BikePilot is offline   Reply With Quote
Old 08-31-2011, 08:36 AM   #9926
jimmyx
jimmyx's Avatar
Oddometer: 165
Thanks Larryboy
Cool, looks like I'm in with the Rox risers! I was checking out your RR's(Death Valley)-Awesome! great video and music.
Jimmy
Dorothy Parker
Old 08-31-2011, 09:38 AM   #9927
Big_John
Colorado Rider
Big_John's Avatar
Oddometer: 2,983
I thought about painting the outside of the skid plate black. My son has discovered a paint (ceramic for auto brake calipers) that is nearly indestructible.....far, far stronger and tougher than the bed liner stuff. Anyway, I thought that might give it a good look and cut down on the "dinging sounds" from rocks to the aluminum.
The Tusk handguards are very impressively built. I have them installed and am very pleased. (note that you have to purchase the $16.99 big bar adapter if you have a 1 1/4.) They are $72 with the adapter.....far less than the $125 I paid for the Acerbis gaurds I purchased last year for my NX. Install on these guards was identical to the Acerbis. You have to wrestle them a little, but once screwed down.....they are solid as an anvil.
I like the idea of a fan.....but even at RMAR and the Big Dog, I never over-heated. I suppose it will happen at some point and I will wish I had a fan. I am interested in the fan install (pics please!!!). Sounds like it might be a great winter project for the me and the BRP. Although.....I think I am going to add some windings to my stator over the winter and install a much, much brighter headlight solution....a rally type setup.
Hobby....?????.....My wife calls this a "Bank Account Drain"!!!!!
By the way, I gave my son the ProTaper (CR Bend) to put on his YZ426. I ordered and have installed a Tusk, Chub (Fat, Taper Bar, 1 1/4) that has the "ATV Bend" and raises the bar by another inch. At 6'4".....I am much happier with the riding position. (I also have 2" Rox Risers)
John
2004 KTM 950 Adventure S
2004 BMW R1150RT
2003 KTM 450 EXC
Pointing the Way http://www.gracemotoadv.com
Big_John screwed with this post 08-31-2011 at 09:43 AM
Big_John is offline   Reply With Quote
Old 08-31-2011, 09:47 AM   #9928
Big_John
Colorado Rider
Big_John's Avatar
Oddometer: 2,983
Thanks in advance,
Jimmy
I am running 2" ROX Risers with ATV High Bend Bars......with Stock cables. I had to reroute cables.....but it was a piece of cake. I figure my grips are about 3.5-4" taller than stock. Good thing since I am 6"4". I love the riding and standing position.
John
2004 BMW R1150RT
2003 KTM 450 EXC
Old 08-31-2011, 10:18 AM   #9929
jimmyx
jimmyx's Avatar
Oddometer: 165
Thanks Big_John,
Got any Photos of your set up?
Jimmy
Dorothy Parker
Old 08-31-2011, 10:40 AM   #9930
Big_John
Colorado Rider
Big_John's Avatar
Oddometer: 2,983
Thanks Big_John,
Jimmy
John
2004 BMW R1150RT
2003 KTM 450 EXC
Times are GMT -7.   It's 02:17 AM.
