Old 06-16-2009, 02:17 AM   #1021
AdventureXR650
Esquire
AdventureXR650's Avatar
Oddometer: 147
Originally Posted by XR650Rking
My old BRP...may have become a donor-cycle
Looks like a clean 2000 model.
The inlet valves look like they stuck open at speed and ate the piston. Messy. Rest of the bits should be good. I wouldn't mind your old frame if you giving it way? Oh hang on you live over there....oh well tel est la vie.
AdventureXR650 is offline   Reply With Quote
Old 06-16-2009, 05:26 AM   #1022
flatwins
Is that your motorsickle?
flatwins's Avatar
Oddometer: 25
I gotta get "edumacated". What does BRP stand for?
08 KLR
89 KX250 +1 in tubs
78 R100RS
77 R100/7 track\cafe project
71 R50/5
63 R60/2
Hunting for a legal XR650R
flatwins is offline   Reply With Quote
Old 06-16-2009, 05:33 AM   #1023
dustfilter
Oddometer: 54
It's love man
Big Red Pig!
dustfilter is offline   Reply With Quote
Old 06-16-2009, 06:51 AM   #1024
RdrMtn
RdrMtn's Avatar
Oddometer: 158
Originally Posted by cello
wow.....how the eck did that happen, and i thought the brp was indestructable!!
a silly but infuriating problem, my oil filler/dip stick seems to be impossible to scre back in without taking the seat/tank off and cussing the bugger for twenty minutes!!!! Seems to cross thread unless you can line up the bugger and press hard into the filler neck and then she needs a pair of pliers to screw her in for the last half of thread length. Checked thread on dipstick and all looks fine and also thread in frame looks clean.
Does anyone else have this problem or is it just me??
It's a known pain in the rear. The advice I took was too snip off the bottom inch of the dipstick. Problem solved.
You don't need that bottom inch since there is so much distance between the low and high oil marks.
RdrMtn is offline   Reply With Quote
Old 06-16-2009, 07:43 AM   #1025
JustinT OP
I will ride my whole life
JustinT's Avatar
Oddometer: 955
Its common...the trick is to run the tip down the right side of the frame...(or at least point it in that direction....It makes it easier but if its already been cross threaded you may need to get it right a few times to clean up the plastic threads.
Full Throttle - it either solves the problem or ends the suspense
JustinT is offline   Reply With Quote
Old 06-17-2009, 05:04 AM   #1026
cello
Oddometer: 80
out at the weekend and then time for a oil change, so will try both methods of dealing with the stick.
cheers guys
cello is offline   Reply With Quote
Old 06-19-2009, 11:26 AM   #1027
SuperMurdo
slick
SuperMurdo's Avatar
Oddometer: 5
XR Jetting
Hey guys, this is my first post on advrider. Just picked up my first BRP last month, it's an '03 that I bought from a guy who couldn't handle the bike. So it's got about 300 miles on it (original tires and all) and I just got it cali plated last week! I went through the uncorking process yesterday and once everything was put back together, I flipped on the choke and kicked, and kicked, and kicked... for about 5 minutes or so, with no results. I understand that you have to refill the carb, but this was rediculous. so I took a break, turned off the choke, kicked twice and had a little burp came out. flipped to half choke and it started right up. i turned the choke off and it tore ass: no sputtering, no popping on deceleration, it felt really good. anyone have any idea why it won't start with the choke on? should this bother me? here are the specs:
bikes about 40' ASL
temperature is 75 deg.
HRC exhaust tip
HRC carb insulator
UNI filter
B53E Jet needle (3rd clip)
#175 Main Jet
68S slow jet
I've also removed the snorkel and clip out of the air box.
I'm going to take off the smog kit today, I'll let you know if that makes any difference.
thanks for your advice!
SuperMurdo is offline   Reply With Quote
Old 06-19-2009, 01:58 PM   #1028
JustinT OP
JustinT's Avatar
Oddometer: 955
bikes about 40' ASL
HRC exhaust tip
HRC carb insulator
UNI filter
#175 Main Jet
68S slow jet
Sounds proper to me.
Little to no choke on a warm day is a good thing, I'd think that means your jetting is proper and not too lean!
JustinT screwed with this post 06-19-2009 at 03:57 PM
Old 06-19-2009, 03:38 PM   #1029
Irnworker433
XR650RRRRRRRR
Irnworker433's Avatar
Oddometer: 98
Does it got gas?
Irnworker433 is offline   Reply With Quote
Old 06-19-2009, 05:43 PM   #1030
Seppo
Oddometer: 503
hey,
my starting routine for the brp is one kick with full choke, it wont start on full choke, but after this kick back to half joke and it fires up on the first kick, at least 90percent of the time.
if it is warm, no choke at all.
cheers
josef
Seppo is offline   Reply With Quote
Old 06-19-2009, 06:04 PM   #1031
4play
Next?
4play's Avatar
Oddometer: 2,596
Edelbrock, two twist of the throttle, kick once, ride
Family isn't always about blood
4play is offline   Reply With Quote
Old 06-19-2009, 08:38 PM   #1032
mphoppe
Hops
mphoppe's Avatar
Oddometer: 577
XR650R Right FootPeg Fix update
Since the last post on this thread, i think this info was relocated...here is the new link...
http://www.advrider.com/forums/showt...ghlight=xr650r
Still have a few sets left if you are new to the program...
Mike
2006 1150 GS Adventure
2006 CRF 250X
2010 KTM 690R
1995 R100GS (sold)
2007 XR650R as new, for sale
2001 XR650R Desert Bike
2006 KLR 650 Commuter (Sold)
2004 XR650R (sold)
2002 XR650R (sold)
Pro Racing Photos http://mikephotos.smugmug.com/
mphoppe is offline   Reply With Quote
Old 06-19-2009, 09:40 PM   #1033
Roostn
On the Throttle Stop
Roostn's Avatar
Oddometer: 299
XR650R seat upgrade
XR650R Adventure Seat Upgrade
I posted a separate thread but in case you missed it:
http://www.advrider.com/forums/showp...57&postcount=1
Sreaming Eagle Defense- Primary Instructor
WR450 Yamaha, R1150GS, XR650R- Plated and Ready to ROCK!, 1980 TT500- Pated and Ready to Roll!
US Army Airborne, Air Assault
Roostn is offline   Reply With Quote
Old 06-20-2009, 01:07 PM   #1034
SuperMurdo
slick
SuperMurdo's Avatar
Oddometer: 5
Thanks King and Seppo! took off the smog and did some riding yesterday. the bike's been starting on the first kick at half choke, so I guess that's my new starting routine... I do appreciate the advice, I was concerned that something was wrong.
So, next question is: What are the other must-have mods for this bike? My supermoto wheel set (sun rims, stock hubs, pirelli diablos) is coming in this week, and as soon as the funds are back up I'm planning on getting a new tank and seat, it's not uncommon for me to ride a few hundred miles a day and the fewer stops for gas and the less pain in my ass the better!
Murdo
2006 KLR w/ Happy Trails boxes
2003 XR650R Cali Plated, Supermoto, gettin' it murdered out.
where we're going, we don't need roads. -Doc Brown
Old 06-20-2009, 02:18 PM   #1035
JustinT OP
JustinT's Avatar
Oddometer: 955
No Prob...Sounds like it is running great!
What other mods have been already done to the bike? Everything greased? (swingarm and linkage are known to need extra from the factory if you don't know how much the previous owner did. As well as the steering stem bearings. Those are must...suspension need work if its stock and I'd assume certainly if going supermotard!
Tells us more about your bike...I'm sure we can fill your brain with mods!
Times are GMT -7.   It's 08:38 PM.
