Old 03-14-2012, 09:16 AM   #12541
Garthe
ROCKS ARE YOUR FRIENDS...
Garthe's Avatar
Oddometer: 4,356
Originally Posted by larryboy View Post
i never yell at an xrr, i beg and plead.
+1
2007 XR650R
2001 Montessa 315R
Garthe is offline   Reply With Quote
Old 03-14-2012, 09:23 AM   #12542
BuRPsa
Finally growing up..
BuRPsa's Avatar
Oddometer: 548
Rather than editing I add to my above post.
I hunch Fox's bike is set too rich, as this is always the easiest to do.
Even with correct jetting of the idle system it's very easy to adjust completely wrong, so in addition to the above, here's what you should do to get thing as correct as you're able to:
Idle the (already warm!) engine, and turn the slide-screw (the slide stopper) down until it almost dies.
Then turn the mixture screw in or out until it almost dies even more - the trick is of course to keep it alive.
Do this both ways (in & out), and determine what is the \middle' of these two settings.. and set it there.
Chances are that the revs will increase now, so re-adjust down (with the stopper-screw of course) until it almost dies again.
Repeat above.
If this gives you the magic 1.5 turns from closed then the idling circuit is OK.
If too far off you better change jets.
Ah yes, eventually you adjust the stopper-screw up a bit to obtain the correct idling rev's - which you determine by ear rather than revcounter. Know that plenty of owner's manuals prescribe ludicrously high idling revs, I assume to allow dorks to drive/ride off too.
BuRPsa is offline   Reply With Quote
Old 03-14-2012, 03:24 PM   #12543
tannerc
Pig Pilot
tannerc's Avatar
Oddometer: 310
Compression stack HELP
I have my comp stack all apart and was looking at the Borynack fork files, the part im having a question with is the two washers at the very bottom of the stack 18mm x .5mm. do these get reinstalled? if you look at the word document he photos them side by side not in line with the other shims.
http://www.borynack.com/xr650r/HondaXR650Rforks.doc
the first pic in that document after it says "brain surgery" in red.
https://picasaweb.google.com/1162935...81608594977282
Anyone have a clue on this? whether or not to reinstall the 2 18mm x .5mm washers or just start out with the 11mm x .10 mm washer?
tannerc is offline   Reply With Quote
Old 03-14-2012, 04:26 PM   #12544
Gildus
Gildus's Avatar
Oddometer: 247
I never yell at an XRR, I beg and plead.
Now that I'm adding farkles, my pig has gotten proud and takes offense when shouted at, particularly when addressed with the prefiix "m.f..ing," followed by any of the following: cob roller, hog, piggy, piglet, porker, porky, sow or swine. I've modified my starting sequence accordingly...
Gildus is offline   Reply With Quote
Old 03-14-2012, 07:40 PM   #12545
NMZens
NMZens's Avatar
Oddometer: 78
Originally Posted by SpeedoJosh View Post
NMZens, what kind of forks are on your XR?
'03 CR250 forks resprung for a fat piggy. Eming clamps. Prolly misspelt cause we're getting "salty" at he Salty Dog in Maggie NC after crossing over the Smokeys today. I'll prolly do a build write up but not tonight!!!
NMZens is offline   Reply With Quote
Old 03-14-2012, 07:52 PM   #12546
Shibby!
Oddometer: 1,665
Document for me doesn't show pictures and I forget what I did.
There is some removal of spacers on the forks or shock. Just can't remember. I believe it was the shock though to allow for threads on the damper rod.
Can you post a picture of your stack and point out the spacers?
Tour of Idaho T1 Challenge - https://spotwalla.com/tripViewer.php...551f1642711d75
Eat. Sleep. Ride - The Great Divide: http://advrider.com/forums/showthrea...4#post19193704
Go, Get Lost - Heading South: http://advrider.com/forums/showthread.php?t=735690
Dirt Donkeys Do Baja: http://advrider.com/forums/showthread.php?t=671095
Shibby! is offline   Reply With Quote
Old 03-14-2012, 08:02 PM   #12547
tannerc
Pig Pilot
tannerc's Avatar
Oddometer: 310
tannerc screwed with this post 03-15-2012 at 09:12 AM
Old 03-14-2012, 08:11 PM   #12548
lstzephyr
Solo con rambo
lstzephyr's Avatar
Oddometer: 1,781
Originally Posted by Jungle Man View Post
Interesting, I never thought to yell anything at the bike that wasn't a profanity. I'll have to try it sometime.
My bike is nicknamed after a female dog because everytime it is hesitant to start I yell out "Start bitch!". At one point my friend was having a discussion about naming bikes and when I said I don't name my vehicles my friend told me that I already had a name for it because I am always yelling at it. I guess the name stuck.
Another question for the guy with starting issues. Are you sure you are turning the choke the right direction? They are a bit backwards from most bikes. Down is open, up is closed.
lstzephyr is offline   Reply With Quote
Old 03-14-2012, 08:13 PM   #12549
chrish4ku
chrish4ku's Avatar
Oddometer: 866
HAHAHA - I did that once and walked my bike home 2 miles...DUHHHHH!
_______________________
Chris
I don't normally ride on the street,,,but when I do,,I prefer lane splitting.
2011 KTM 990 Adventure / KTM 500 EXC
Chris' Sat Tracker
chrish4ku is online now   Reply With Quote
Old 03-14-2012, 08:56 PM   #12550
Ironwood
Friday Harbor, WA
Oddometer: 760
This might sound odd, but my understanding of Mikuni carbs is that the choke circuit does not function unless the slide is almost bottomed out in the barrel. I think the the stock Keihin carb works the same. If I am having trouble getting the bike to start when very cold I back the idle screw off and give it full choke. It usually starts within 4 or 5 kicks. If I don't do this it won't always start.
The reason they work this way has to do with creating a vacuum ahead of the slide and pulling fuel through the enrichening circuit. If the slide is set too high not enough vacuum is created and the mix stays too lean.
Someone correct me if I am wrong. I used to be a decent Mikuni tuner on 2-smokes and it seems to work on the XRR as well. Joe
Ironwood is offline   Reply With Quote
Old 03-14-2012, 09:33 PM   #12551
XRx
Broken Filter
XRx's Avatar
Oddometer: 505
Me, usually after yelling at it calling any generic bike a bitch for not starting, is followed by about ten minutes of kicking while apologetic begging, which ultimately saves me from pushing it home. Your results may vary!
"Get the hell out of my way." - John Galt
'78 KE100 - '09 K1300S - '09 CRF450X Tagged- '00 XR650R Tagged - '80s XR600/XL600 Project - Giant Trance X3 - PC: SSD-4.2ghzOC - Old mildly stinky hockey gear
XRx is offline   Reply With Quote
Old 03-14-2012, 10:06 PM   #12552
Shibby!
Oddometer: 1,665
I never touch my idle on the TM-40.
Choke only when quite cold. Normally two pumps of the pumper gets it fired up.
Old 03-15-2012, 02:08 AM   #12553
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,244
This might sound odd, but my understanding of Mikuni carbs is that the choke circuit does not function unless the slide is almost bottomed out in the barrel. I think the the stock Kehin carb works the same. If I am having trouble getting the bike to start when very cold I back the idle screw off and give it full choke. It usually starts within 4 or 5 kicks. If I don't do this it won't always start.
Mikunis have an enrichener whereas the stock Kehin has a real choke (obstructs the carb throat) They operate completely different. I can't comment on idle screw position, both my Kehin and the TM40 seems to react normally to being choked, when the motor is cold they both require the choke. I read some stuff on the xr400 forum about this (adj the idle for cold starts) but I have an xr400 also and it needs choked when cold. I have to think the mix is rich if no choke is required cold, ESP since my xr usally starts first kick choked cold. Many bikes are running around jetted fat on the pilot circuit and the owners don't realize it. Fuel mileage when doing an easy DS ride is a pretty good indicator, 45mpg is fairly typical and 50 isn't unheard of. Each machine is slightly different, results may vary
Chris
"Life's journey is not to arrive at the grave safely in a well preserved body, but to rather skid in sideways, totally worn out, shouting ... Holy Shit, what a ride!"
CL Adventure Ride 2013 /CL Revisited 2014 / 700 Miles of Scenic Utah Backcountry / MY VIDEOS / RIDEFREAK TV
RideFreak is offline   Reply With Quote
Old 03-15-2012, 08:08 AM   #12554
crypto666
Oddometer: 1,383
I can't remember and my notes are in my tool box, but try this http://www.thumpertalk.com/topic/809...to-share-info/
crypto666 is offline   Reply With Quote
Old 03-15-2012, 08:46 AM   #12555
dohcfox
meh
dohcfox's Avatar
Oddometer: 147
Yep, I keep the lever down, thus keeping the choke off. I even checked it out when I had the carb off while cleaning the bike up after I purchased it.
dohcfox is offline   Reply With Quote
Times are GMT -7.   It's 08:51 PM.
