Old 05-05-2012, 10:54 PM   #13081
Capt. Egregious
Capt. Egregious's Avatar
Oddometer: 376
What seat is best?
I'm sure this question has been asked before. What aftermarket seats are you guys using? What makes it great and what would you change?
Capt. Egregious is offline   Reply With Quote
Old 05-06-2012, 12:06 AM   #13082
FlyGuy
MachineHead
FlyGuy's Avatar
Oddometer: 170
Originally Posted by mazman808 View Post
I pulled my clutch apart to have a look.
Everything seems fine except for the very last steel plate thats just before the thinner fiber plate and those judder springs.
It has a groove in it all the way along the plate.
Ive read some threads where they mention they also have grooves in theyre plate but nothing about if this is normal, so can anyone tell me if this is just normal wear and tear?
Also, reading others threads, they mention theyre plates are alloy( and they upgrade to the aftermarket steel ones), well mine are steel and i bought my bike when it was almost new so i doubt anyone has changed a clutch kit when new, only thing i can think of is that the Australian model came with steel clutch plates or they upgraded along the way(mines 04 model).
Here is a picture of what im talking about, should i replace or not worry about it?
That clutch looks good
What type of oil are you running ?
A non Moly type oil is needed
and if that's not the case and you are running the correct oil then check the clutch stack height, when properly set up one extra steel added to the pack will cause the last fiber to run off the edge of the basket. if not add a extra steel plate and see if you can adjust the clutch
also a heavier spring is recommended (4 of)
I run the heavier springs and a extra steel plate in one bike, and in another bike only the springs the extra steel wont allow me to adjust the clutch.
That grove is not the cause of your problem it looks like a foreign object may have been the cause? it might be normal?
FlyGuy is offline   Reply With Quote
Old 05-06-2012, 12:27 AM   #13083
Noprogram
High Plains Drifter
Noprogram's Avatar
Oddometer: 167
Cold day down under so thought I'd put up some pics of the BRP. I've had this bike for awhile and was setting it up to be my adventure bike for an Australian tour but had some minor problems with earthquakes destroying our city so it was put on hold for a year to let the....ahem.....dust settle so to speak.
This is Australasian version 650R which has lights and switch gear for road compliance. Setup with Protapers, Barkbusters, Moose Racing plate, Givi screen, Ram GPS mount, Pro Moto Billet rack and the 25L Safari tank. Currently rigged with the original Giant Loop but I also have a Denali rack with the subframe reinforcement to be used with Andy Strapz expedition panniers and a Wolfman expedition roll bag. Although the original intention was to try and do an 'alpine style' approach (cut your tooth brush in half etc) with the bike setup so it would still handle in sand etc and the later was getting too heavy in rear IMO. Anyway, included a few pics of a ride through the upper South Island high country recently. The pig's such a great bike to ride out there.
XRV750, XR650R, XR600, XR650L, Moto Guzzi Le Mans, CT125.
"If you're going to be stupid you better be tough"
Noprogram is offline   Reply With Quote
Old 05-06-2012, 01:03 AM   #13084
mazman808
Oddometer: 100
Ive been using the Fuchs comp4 oil in it for a while, then recently tried the castrol power1 racing and after 2 rides thats when i noticed the slipping.
I checked the measurement of all my fibers and steel plates. found the specs that say 3mm for fibers and 0.30mm for steel, 2.69mm for the smaller fiber plate and mine come up within specs(a bit thicker then what those numbers say as im guessing those number are minimum specs).
What i find odd is that it only slipped for my one session, which goes for about 15min, after that all other sessions it was perfect.
mazman808 is offline   Reply With Quote
Old 05-06-2012, 07:49 AM   #13085
Craiger
Oddometer: 309
Capt. Egregious, I have a XPC suede seat and I still am VERY HAPPY with it. The seat has gotten even more comfortable with time. Below is a link to my review of the seat a short time after I received it. 200 plus mile days are comfortable on the seat and I figure roughly I have 6000 miles on the seat. IMHO it was money well spent...
http://www.advrider.com/forums/showp...postcount=5442
I am not a ADV profile stalker, but a fat fingered Galaxy Tab user.
Craiger is offline   Reply With Quote
Old 05-06-2012, 08:34 AM   #13086
woodsxr
Oddometer: 241
That seat looks pretty comfy.
I will be looking for a seat pretty soon and may have to look at XPC.
woodsxr is online now   Reply With Quote
Old 05-06-2012, 08:50 AM   #13087
gofargogo
Lurker, mostly
gofargogo's Avatar
Oddometer: 389
Renazco. I couldn't be happier with it. I had the stock seat on it before, and I'd get uncomfortable after 20 minutes. With the Renazco seat I have ridden for hours without any issue. It is the best mod I've done.
gofargogo is offline   Reply With Quote
Old 05-06-2012, 08:56 AM   #13088
gofargogo
Lurker, mostly
gofargogo's Avatar
Oddometer: 389
Here's how I celebrated Cinco de Mayo.
Old 05-06-2012, 09:27 AM   #13089
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 15,182
Did you bother checking what I mentioned?
larryboy is online now   Reply With Quote
Old 05-06-2012, 09:59 AM   #13090
XRx
Broken Filter
XRx's Avatar
Oddometer: 505
Yes, if your clutch basket looks like Flyguy's avatar, it will greatly degrade the clutch's ability to grab. If the basket is worn and If you're cheap and careful, you can repair a worn basket pretty good with a grinding wheel. I've done it with a right angle grinder with good results, better yet was did it on my dad's table saw with a grinding or cutting wheel, when I was a kid.
Though those Hinson baskets look real nice if you're into spending a few bucks on your bike.
"Get the hell out of my way." - John Galt
'78 KE100 - '09 K1300S - '09 CRF450X Tagged- '00 XR650R Tagged - '80s XR600/XL600 Project - Giant Trance X3 - PC: SSD-4.2ghzOC - Old mildly stinky hockey gear
XRx is offline   Reply With Quote
Old 05-06-2012, 10:44 AM   #13091
seabee1
we build, we fight
seabee1's Avatar
Oddometer: 2,478
Let me say first that I don't fully understand how clutches and baskets work, so let me ask you a stupid question. If a clutch basket is worn, meaning material removed, how can you fix it with a grinding wheel, or even more material removed?
"If guns cause crime, then all of mine are defective." Ted Nugent
www.dehmotorcycle.com
Motorcycle storage with a personal touch
seabee1 is offline   Reply With Quote
Old 05-06-2012, 10:57 AM   #13092
XRx
Broken Filter
XRx's Avatar
Oddometer: 505
This one is quite worn. See the teeth where the plates wore in. Now the plates want to ride in the valleys, restrictian their axial movement to engage and disengage, as they actually have to move apart and together axially.
So assuming you are very careful, you can grind away to a flat surface again with pretty good results I've found. But keep in mind you want the surfaces as flat, parallel, and consistent material removal off each row, as accurately is you possible can. Which is why the table saw was better than the angle grinder, more consistent material removal
Old 05-06-2012, 11:17 AM   #13093
seabee1
we build, we fight
seabee1's Avatar
Oddometer: 2,478
Ok, so it doesn't really matter if they can rotate a bit side to side, as long as they can slide up and down? relative to the orientation of your pic.
Old 05-06-2012, 11:59 AM   #13094
SpeedoJosh
SpeedoJosh's Avatar
Oddometer: 832
So I have a 250r for the really tight stuff, and the 650r for trips and all that stuff. Is there room for a 400r in there also, or is it to similar to the 650 to get?
Anyone own, or owned both or all three at the same time?
2000 XR250R - Tagged
1998 XR400R - To be tagged
2003 XR650R - Sold 2006 Ducati Monster -Sold
'Cause I like to party - Story of 2 XR650s conquering Florida
http://www.advrider.com/forums/showthread.php?t=754094
SpeedoJosh screwed with this post 05-06-2012 at 01:49 PM
SpeedoJosh is offline   Reply With Quote
Old 05-06-2012, 12:51 PM   #13095
XRx
Broken Filter
XRx's Avatar
Oddometer: 505
Exactly. Although there are other considerations too. Like if the sliding surfaces from the factory had the sliding surfaces finished special to reduce friction, you wouldn't have that. And if you took too much material off, eventually full power might bend the fingers if they get too thin to transer the power.
Times are GMT -7.   It's 09:14 AM.
