Old 08-29-2012, 01:39 PM   #14281
Garthe
ROCKS ARE YOUR FRIENDS...
Garthe's Avatar
Oddometer: 4,357
Thanks guys, great info. Sounds like a found a tank that will work for me.
Now, I just have to find the $$$$$.
2007 XR650R
2001 Montessa 315R
Garthe is offline   Reply With Quote
Old 08-29-2012, 02:02 PM   #14282
Garthe
Garthe's Avatar
Oddometer: 4,357
Originally Posted by hontri View Post
I have the IMS 7 in red. As a bonus you can see the fuel level even with the red tank
Now you have me thinking about red...
Is it fighting red?
Does it match the front fender?
2007 XR650R
2001 Montessa 315R
Old 08-29-2012, 04:12 PM   #14283
Deadly99
Fast and Far
Deadly99's Avatar
Oddometer: 10,151
Originally Posted by BuRPsa View Post
Yeah, I also thought it is narrower, I checked lotsa pics before I bought.
Here's views, and note the small reserve compartment.
May I enquire about your frame protectors ?
Sweet bike
Roaming Rally 2015
GRAVEL TRAVEL CANADA - Canada's source for overland routes
Tales From The Bivouac Rally Print Publications
Deadly99 is offline   Reply With Quote
Old 08-29-2012, 04:59 PM   #14284
hontri
Global Bummer!
hontri's Avatar
Oddometer: 305
Is it fighting red?
It is a pretty darn close match
hontri is online now   Reply With Quote
Old 08-29-2012, 06:21 PM   #14285
Dread Pendragon
throttle to the donk
Dread Pendragon's Avatar
Oddometer: 2,560
For anyone thinking about an IMS 7, I think you need to leave the petcock on "reserve" all the time, because once the fuel level gets low enough the only gas that gets to the engine is that getting pushed into the basin by the pump. The depth of the basin is about as deep as the reserve level on the petcock, so if it isn't on reserve the gas isn't deep enough to drain through the petcock.
"Never get excited in a rally, its a race, but its never a race at that exact moment" -Quinn Cody
Dread Pendragon is offline   Reply With Quote
Old 08-29-2012, 07:29 PM   #14286
cragdweller
Oddometer: 28
Best bearing kits
Just looking for feedback on the quality of the various linkage/swingarm/wheel bearing kits out there. I have seen All Balls, Moose, Pivot Works, and of course Honda OEM. I've searched and not found much on the aftermarket parts quality. Had my shock serviced and am taking the opportunity to check all the bearings in the rear. Of course the swingarm pivot bearings were completely toast, and one of the three shock linkage bearings is wasted. Rear wheel bearings are also not looking good...
Thanks for any feedback.
cragdweller is offline   Reply With Quote
Old 08-29-2012, 07:49 PM   #14287
Garthe
Garthe's Avatar
Oddometer: 4,357
I've always used pivot works, I blame marketing.
The BIG red tank, sure looks good...
2007 XR650R
2001 Montessa 315R
Old 08-29-2012, 08:20 PM   #14288
Shibby!
Oddometer: 1,666
You don't have to go with a kit, but if you do make sure they use proper, high quality bearings. SKF being one of the larger players, FAG is another one, etc.
Pretty much standard is SKF though. Moose usually rebrands quality products. I wouldn't hesitate to try theirs.
Proper care and those bearings should last a good long time. Keeping them greased is key.
Tour of Idaho T1 Challenge - https://spotwalla.com/tripViewer.php...551f1642711d75
Eat. Sleep. Ride - The Great Divide: http://advrider.com/forums/showthrea...4#post19193704
Go, Get Lost - Heading South: http://advrider.com/forums/showthread.php?t=735690
Dirt Donkeys Do Baja: http://advrider.com/forums/showthread.php?t=671095
Shibby! is offline   Reply With Quote
Old 08-29-2012, 09:16 PM   #14289
crypto666
Oddometer: 1,449
Sweet kickstand mod!
crypto666 is offline   Reply With Quote
Old 08-30-2012, 05:59 AM   #14290
cdogg44
Oddometer: 223
Don't do it. I had one and hated it. It fit great and rode well, but the mess of fuel and vacuum lines was a nightmare. After 3 orders to Mcmaster-Carr I finally had the correct quick connect fittings with built in shut off valves which helped the installation a ton. One more order and I finally got some spare o-rings that fit.
However, I had one of the o-rings in a quick connect fail over the winter and leak ~3 gallons of fuel in my garage while I was gone to work one day. Be sure and factor that into your reliability.
I bought the popular Acerbis 6.3 for $250 shipped from Rocky Mountain ATV a few months ago and haven't looked back. An extra .7 gal of fuel is not worth the vacuum/fuel hose nightmare.
cdogg44 is offline   Reply With Quote
Old 08-30-2012, 06:41 AM   #14291
Garthe
Garthe's Avatar
Oddometer: 4,357
Thanks for the warning, if you read my past posts regarding the acerbic, you'll understand why I won't use it. I had one, then sold it. The .7 gallons of fuel, has nothing to do with my selection of the IMS.
2007 XR650R
2001 Montessa 315R
Old 08-30-2012, 10:22 AM   #14292
BuRPsa
Finally growing up..
BuRPsa's Avatar
Oddometer: 548
Deadly,
Yeah you may mate: Ozzi-made!
For the life of me I cannot remember who makes them, but I googled for them & found them down under - try? They make bashplates mainly I think, should help.
Cdogg,
yip, the O-rings rip easily, and I read there was some problem with them sometime. Hence I replaced all mine with those brown types (heat resistant stuff) which are better fuel resistant. And, some grease goes a long way here, plus patient alignment plus correct depressing that slide during dis/connecting. I've taken it off often when I was building the bike, have not had a problem yet.
BuRPsa is offline   Reply With Quote
Old 08-30-2012, 06:05 PM   #14293
RZRob
RZRob's Avatar
Oddometer: 1,753
HRC UnCorking Kit
So I've yet to even ride my new XR650R and am already ordering upgrades.
I ordered the "uncorking" components (sans HRC exhaust tip) via Service Honda.
Then, I ordered the Applied Racing smog pump block-off kit. Yes it was the most expensive, but I liked the construction better than the Baja Designs or IMS kits.
Then I can go womping!
RZ Rob
RZRob is offline   Reply With Quote
Old 08-30-2012, 06:35 PM   #14294
Deadly99
Fast and Far
Deadly99's Avatar
Oddometer: 10,151
Deadly,
yet.
Demonfx in the UK carries them..cheers and thanks
Roaming Rally 2015
Old 08-30-2012, 07:32 PM   #14295
Shibby!
Oddometer: 1,666
RZ Rob
You'll want to revalve and respring the suspension. Also rewind the stator and put a better headlight on it if you plan to do any night riding or get stuck at night.
Times are GMT -7.   It's 01:22 PM.
