Old 09-15-2012, 05:34 PM   #14536
woodsxr
Oddometer: 241
Originally Posted by Buell78753 View Post
The chain adjusting bolts snapped off in the swingarm, due to corrosion on the threads.
All I can say is thank goodness for the SwingArm Buddy!
The most difficult (and most important) part of the procedure is drilling out the broken bolts. You have to work your way up to with two smaller diameter drill bits before using the 3/8" bit provided in the kit. At least one of the smaller bits needs to be extra-long, otherwise your it will not clear the swingarm and you will drill crooked. Also critical, is making a very deep center punch mark - in the center of the broken bolt. I hit the center punch several times to be sure to get a deep punch mark. The finished 3/8" hole must be centered in the swingarm... not a procedure for the squeamish!
The kit makes a very solid repair and I applied anti-seize to the new adjusting bolts. The only down-side to the kit, is the new bolts are 5/16" american, which means you have to use a 1/2 wrench to adjust your chain, which may mean having to pack an extra wrench in your tool kit, although you might still get away with using a 13mm metric.
The steel insert is slightly over-sized compared to the 3/8" drill bit, so it is a good press fit into the swingarm.
That is what I was planning on doing when the time comes
woodsxr is offline   Reply With Quote
Old 09-15-2012, 07:24 PM   #14537
slickwill
Exhiled
Oddometer: 209
If you keep fresh anti-seize on them the time won't ever come.
slickwill is offline   Reply With Quote
Old 09-15-2012, 08:03 PM   #14538
Shibby!
Oddometer: 1,666
Originally Posted by Sean-0 View Post
Plug for the Busted Nutz Ride
yes i do crash again
What was the gesture at 7:23??
"two more?" or "F**** you!"
Tour of Idaho T1 Challenge - https://spotwalla.com/tripViewer.php...551f1642711d75
Eat. Sleep. Ride - The Great Divide: http://advrider.com/forums/showthrea...4#post19193704
Go, Get Lost - Heading South: http://advrider.com/forums/showthread.php?t=735690
Dirt Donkeys Do Baja: http://advrider.com/forums/showthread.php?t=671095
Shibby! is offline   Reply With Quote
Old 09-15-2012, 08:20 PM   #14539
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,510
just a thank you and a 1 more
the dust was bad ..video dont show it but it was real bad
Sean-0 is offline   Reply With Quote
Old 09-15-2012, 09:51 PM   #14540
woodsxr
Oddometer: 241
It is the 8 years before I bought the bike is what I need to catch up with
Old 09-16-2012, 04:11 AM   #14541
ZXRaziel
ZXRaziel's Avatar
Location: Grey skyes and rain of Good old England ( NEast)
Oddometer: 634
Originally Posted by Capt. Egregious View Post
I stand corrected. Thats funny. I was just looking at it yesterday on my phone and now its gone.
Sadly the Borynack site is gone
ZXRaziel is offline   Reply With Quote
Old 09-16-2012, 04:12 AM   #14542
ZXRaziel
ZXRaziel's Avatar
Oddometer: 634
More lucky this time that there was no tree in the way
Old 09-16-2012, 08:37 AM   #14543
CeeBee
The Cake Baker
Oddometer: 168
Originally Posted by crypto666 View Post
Looks just like my disassembly; cardboard on the floor. Its a pretty messy job.
What kind of case saver is that? Can you give us a close up? I just like the color, but was wondering if it offers other advantages over the xrso.
It doesn't look that pretty anymore! I hard to get a scotch brite pad and clean it off just to read who made it. It was a xr's only set up
Later, Chuck
CeeBee is offline   Reply With Quote
Old 09-16-2012, 08:45 AM   #14544
CeeBee
The Cake Baker
Oddometer: 168
[QUOTE=Buell78753;19602496]The chain adjusting bolts snapped off in the swingarm, due to corrosion on the threads.
That happened to me TWICE. Had to get the torch out and heat them up to get it to break loose.
always wondered if there was a fix if they broke. Thanks for the info.
Heard if you drill a 1/8 inch hole in the bottom of the swing arm it would drain the water that seeps in and it won't happen as often or be as bad - Is that true???
Later, Chuck
Old 09-16-2012, 08:49 AM   #14545
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 15,192
Later, Chuck
I drilled weep holes on my 2002 XRR, you could hear the water sloshing in the swingarm before I drilled it. Bolts came out and I anti-seized them, stayed good with the weep holes.
Thanks for sharing that fix Buell78753, didn't know that was available!!
You're welcome for the answer and pic of the Hinson basket.
Old 09-16-2012, 08:50 AM   #14546
CeeBee
The Cake Baker
Oddometer: 168
Originally Posted by BuRPsa View Post
Never mind the hammer Ceebee,
explain why you got/had two cranks? Rods seem to be different too.
I mean, if you were after turning it into a twin you're doing it wrong
Lurve the comments here, "very VW"
Never can have too much power!!! If ones good two MUST be better - Right?
The one crank/rod set up were seized as one and had to be replaced. Just put a new stock setup in.
Later, Chuck
Old 09-16-2012, 09:42 AM   #14547
SpeedoJosh
SpeedoJosh's Avatar
Oddometer: 832
Edelbrock question.
This is for the XR250 eddie, but it's pretty much the same carb.
Anyway, let the XR sit for a few months and failed to drain the carb. So went to clean out the bowl and realized the gas ate away at the black mesh-spongy screen in the bottom of the carb. I just took it out, and reinstalled everything without it. Bike starts fine, but am curious what exactly that mesh screen is for, and should I look at getting another one?
My edumacted guess is that it screens/traps/catches particles in the fuel, and stops them from circulating in the bowl.
Any insight?
-Josh
2000 XR250R - Tagged
1998 XR400R - To be tagged
2003 XR650R - Sold 2006 Ducati Monster -Sold
'Cause I like to party - Story of 2 XR650s conquering Florida
http://www.advrider.com/forums/showthread.php?t=754094
SpeedoJosh is offline   Reply With Quote
Old 09-16-2012, 04:20 PM   #14548
medisyn
Oddometer: 149
OK upon your guys suggestion a few pages back I tore the carb off my bike to clean it. Turns out the needles are clean, but its using the stock needle sizes with a pipe on it! 125 main and 65s is stock right? Damn previous owner told me the bike was jetted! No idea why he ran the bike like this...
The bike stalls every once in a while on idle (scary for me as a new kick starter in traffic ) and backfires/pops when I let off the gas. The mods on it are a Uni filter and a FMF titanium pipe. Also say if I am in 3rd and run it out and shift into 4th, as soon as I peg the gas there is a second or two of hesitation. At first I assumed the bike was running quite rich but it has to be lean has hell correct? When cold the bike will die if I give it full choke as well.
I am going to check the plug soon too so I can get an idea if it was lean or rich...
My altitude is near sea level (under 1000ft) and temps are around 70-90f during the day (Bay Area CA.) I am thinking 170 or 175 main and 68s idle. Does this sound good with a pipe and filter? Where is a good place to order the jets? I assume the bike will run better after, but will it have more power too? I am not sure what is "normal" power wise. Should this bike wheelie if I grab a lot of throttle in 1st? I have sumo wheels and a 15t front sprocket and it does not seem like that is possible with my 220lbs ass on the bike as it is now.
My plan while I have the carb off is to check the valves and other tender loving care to my new to me BRP.
EDIT: Are there any other parts I need to order to "uncork" the carb?
medisyn screwed with this post 09-16-2012 at 04:35 PM
medisyn is offline   Reply With Quote
Old 09-16-2012, 05:20 PM   #14549
oldxr
oldxr's Avatar
Oddometer: 1,151
Jetting should be 175 main,b53e needle in 3rd groove from the top,68s pilot jet.Make sure it has the correct intake manifold-the oem manifold had a restriction in it.Take a hole saw and saw out the middle of the baffle in the pipe.A aftermarkit pipe will help.If you run 1 of those airbox screen kits from xr's only you can jet up to 178.Also try a 1996 xr400 cdi box.
oldxr is offline   Reply With Quote
Old 09-16-2012, 05:29 PM   #14550
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 15,192
I'm in Elk Grove and run a 165 main and 68s, but I always head for higher ground when riding the thumpers, never really ride around the low elevations.
Good uncork article:
www.4strokes.com/tech/honda/uncork_brp/
Being a California bike you might have the smog stuff still on it, eliminate that junk too.
Times are GMT -7.   It's 01:03 AM.
