Old 09-22-2012, 05:38 PM   #14611
jm-2008
jm-2008's Avatar
Oddometer: 517
[QUOTE=RideFreak;19651967]Here's some dualsportin on the XR from last weekend. Pretty tame stuff out on the Continental Divide Trail. This section is a 120mi leg of a 230 mi ride. It's a stretch of the CDT between Grants NM and SanYsidro NM. This is our outback, BFE to be exact. We were cruisin pretty easy for the first part of the vid, about 1/2 way through we decided our gas would get back and remembered there was beer on ice back at the truck
2:37 & 3:37
That usually me!
Thanks for the Vid and inspiration Chris.
Getting a little warmer here now, hope to get out soon.
Stay safe.
JM
jm-2008 is offline   Reply With Quote
Old 09-23-2012, 07:11 AM   #14612
babuja
babuja's Avatar
Oddometer: 353
XR 65O R Rear Shock Adjustments
Hi,
need some help with rear shock adjustments starting point:
Compression:?
Rebound:?
By the way, when I ear some one say, 5 clicks, this is from Soft to Hard (clockwise)?
Rear Shock: Stock
Weight: 80Kg
Terrain: Soft to Medium
Cheers guys
Babuja
________
KTM 950 ADV
www.babuja.smugmug.com
http://www.nomadstrail.net/site/
babuja is offline   Reply With Quote
Old 09-23-2012, 04:40 PM   #14613
DocAxeYarYar
RideDualSport.com
DocAxeYarYar's Avatar
Oddometer: 788
The RDS Red Sled Is Waiting to be Fed
We made a big push this weekend, by installing an upgraded clutch hub bushing, installing the tank, finalizing the baja designs install, tightening all frame fittings, routing cables and installing the TCI Products skid plate and engine gards.
The beast runs, and is ready to roll bones at the Roll The Bones Rally and go to Big Bend Ranch State Park!
Before:
After:
My XR650R Build:
http://ridedualsport.com/forum/index.php?topic=2748.0
DocAxeYarYar screwed with this post 09-23-2012 at 05:08 PM
DocAxeYarYar is offline   Reply With Quote
Old 09-23-2012, 05:09 PM   #14614
AtomicGeo
Chile Eater
AtomicGeo's Avatar
Oddometer: 4,328
Originally Posted by babuja View Post
Hi,
Compression:?
Rebound:?
Rear Shock: Stock
Weight: 80Kg
I am at C-10,R-15 with spring rate of 9.8 kg/mm. For 80 kg weight (I assume that is with all your gear) you should start at 9.2 or 9.5 spring rate. I think stock is 9.2, but 80 kg is near the upper limit for 9.2.
2003 KX250 - plated
2014 WR450F - plated
AtomicGeo Videos
AtomicGeo is offline   Reply With Quote
Old 09-23-2012, 05:53 PM   #14615
jungleplant
Motorcyle Stuff
jungleplant's Avatar
Oddometer: 1,858
Before:
After:
they look good in red , nice job, might have to do a few hundred in that colors
www.manracks.com
jungleplant is offline   Reply With Quote
Old 09-23-2012, 06:01 PM   #14616
Shibby!
Oddometer: 1,666
Fun ride! I've done that section before and NM surprised me. Good riding for sure. I can't pin-point it but I think we camped somewhere along this ride you just did.
As for riding, my buddy and I ride side by side a lot. Not the safest, but sure beats the dust. We trust eachother and know when we're doing it.
Love the sound of the XRR!
I think all these spotless XRR's on this thread lately have to actually go get used. Shiny bikes aren't worth much to me because it means I haven't rode them!
Tour of Idaho T1 Challenge - https://spotwalla.com/tripViewer.php...551f1642711d75
Eat. Sleep. Ride - The Great Divide: http://advrider.com/forums/showthrea...4#post19193704
Go, Get Lost - Heading South: http://advrider.com/forums/showthread.php?t=735690
Dirt Donkeys Do Baja: http://advrider.com/forums/showthread.php?t=671095
Shibby! is offline   Reply With Quote
Old 09-23-2012, 06:02 PM   #14617
Shibby!
Oddometer: 1,666
Originally Posted by larryboy View Post
Listed my dirt bike XRR the other day, pretty sure it's the cheapest one on adv.
www.advrider.com/forums/showthread.php?t=827888
What's it's replacement?
Old 09-23-2012, 06:13 PM   #14618
DocAxeYarYar
RideDualSport.com
Oddometer: 788
ManRacks
Thanks dude, Ayers Garage did the work and I could tell you the color I think. It looks good, and I like how the ManRack is right-sized for the XRR! Looking forward to packing up for a trip!
My XR650R Build:
Old 09-23-2012, 06:17 PM   #14619
jungleplant
Motorcyle Stuff
Oddometer: 1,858
great ask him for the code ok, do ya need a set of fork tiedowns , pm me
www.manracks.com
Old 09-23-2012, 06:28 PM   #14620
stepink104
Oddometer: 10
hey what is the biggest tire i can install on a 650 xrl.............thanks pm me.
stepink104 is offline   Reply With Quote
Old 09-23-2012, 07:42 PM   #14621
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 15,165
Nothing right now. I'm commuting 175 miles per day and seriously don't have time for the XRR, I could mothball it and save it, but I figured I'd turn it over and let somebody else have some fun with it. I'm saving towards buying a second house closer to work, then maybe another big thumper for solo dirt travel.
Old 09-23-2012, 10:33 PM   #14622
RZRob
RZRob's Avatar
Oddometer: 1,748
Turn Signal Heat Shield
Hey folks, I'm setting my XR up for street use and put the turn signals on, but had some concern about the exhaust heat doing right rear in so I fabbed-up this heat shield just in case. It's smaller than it looks. I know some would say, why did you put the signal there, but it's not in the direct path of the exhaust, but no matter where I put it around there, it'd be in the heat range. I made the plate base too.
RZRob is offline   Reply With Quote
Old 09-24-2012, 06:38 AM   #14623
Shibby!
Oddometer: 1,666
Looks good. Should perform as needed. Pretty heavy guage for a non-offroad model =) Looks like it shouldn't affect the exhaust noise either. Sometimes you can get that baffle noise if placed in the direct path of the exhaust.
Wow. 174 miles. I don't commute that far in 9 days of work. Not trying to be an ass, but did your place of work move or how did that come about? Understandable why you don't have any time in the day!
Old 09-24-2012, 09:18 AM   #14624
RalphyDo
Oddometer: 308
This is the R thread. Someone might know about the L. Are you talking rear tire or front?
RalphyDo is offline   Reply With Quote
Old 09-24-2012, 09:24 AM   #14625
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 15,165
No worries, PM'd ya.
Times are GMT -7.   It's 04:40 PM.
