Old 11-29-2008, 02:11 PM   #1
Jonex OP
zipper suited sun god
Jonex's Avatar
Oddometer: 1,357
Soft start for drill press?
I have a POS Harbor Freight floor standing 16 speed drill press. I don't have it bolted to the floor so I can scoot it around when needed. It's like dancing with a wet mop.
When I turn it on, it goes clank and jerks because I'm usually drilling metal with the shortest pulley ratios and there's lots of torque. The harsh start up makes the handles jump on my X/Y table. Grrrr.
I paid $169 for this drill press (and it's worth at least half that), so I don't want to put a $300 VFD on it. I've tried holding the belt tensioner loose when I start it, but that doesn't work.
I'm wondering if one of those router speed controls would work.
Any ideas?
Jonex is offline   Reply With Quote
Old 11-29-2008, 02:29 PM   #2
the_gr8t_waldo
Oddometer: 2,058
for what its worth i,ve had a sim. drill press for 20years now and never experenced a jerk or clank on start up. i would check out the drill press for bad initional set up.
the_gr8t_waldo is offline   Reply With Quote
Old 11-29-2008, 02:36 PM   #3
GreaseMonkey
Preshrunk & Cottony
GreaseMonkey's Avatar
Location: The only county in Illinois with no train tracks
Oddometer: 5,235
I'd suggest making a wooden base and bolting it to the base. You can still slide it around or you want to spend extra time you can put some dolly wheels on it that you can drop down when you want to move it.
The slickest setup I ever saw was a piece of plate steel that had an air chuck nipple tapped into the center. Shop air would get attached to the fitting and the entire tool (it was a table saw) could get slid around. Turn the air off and it wouldn't budge.
I do have to say that I have never had a drill press jump around on me, so you may want to give all the bolts and bearings a once over.
GreaseMonkey is offline   Reply With Quote
Old 11-29-2008, 03:22 PM   #4
mark1305
Old Enough To Know Better
mark1305's Avatar
Oddometer: 5,970
I agree - something isn't secure somewhere in the assembly. Everything clamped onto the column should be tightened down; the motor mounts checked for tightness: belts adjusted properly with no slop; spindle checked for radial and axial play (side to side and vertical). And don't start the drill with the bit touching the workpiece.
If you are doing precision drilling (with an X-Y table), after you get the startup gremlins fixed, you may want to look at using center drills to start the holes, then switch to the regular bits. Center drills don't flex and wander in a drill press like regualr bits. Wish I'd heard of them 30 or 40 years ago.
Mark J
Merritt Island, FL
When a person asks you for advice, they don't want advice. They want corroboration.
mark1305 is offline   Reply With Quote
Old 11-29-2008, 06:47 PM   #5
gsweave
Yinz, blinkers are on.
Oddometer: 11,220
Stick a bit, and you will wish the bastard was mounted to the floor cause you will be dancing with a kickin mule.
I will look up some soft starts for ya on Mon. It's 220V?
"The Holy Spirit does not want you to be afraid of people, but to be wise and strong, and to love them and enjoy being with them" 2 Timothy 1:7
gsweave screwed with this post 11-29-2008 at 06:56 PM
gsweave is offline   Reply With Quote
Old 11-29-2008, 10:02 PM   #6
LoFlow
Oddometer: 949
I have my drill presses hooked up to foot switches. That way when something goes wrong I can just lift my foot instead instead of trying to reach for a switch. They also have variable speed foot switches that work quite well.
LoFlow is offline   Reply With Quote
Old 11-30-2008, 05:15 AM   #7
JDLuke
Ravening for delight
JDLuke's Avatar
Oddometer: 8,644
I learned about center drills when I got into home shop machining. They are an absolute pleasure to use.
Why did I drink all of the ingredients for vomit?
"Used to be Man vs. Nature.. then Man vs. Space.. then Man vs. the Moon. Now it's Man vs. Food" - Dalar
"you cannot reason a person out of something they were not reasoned into." - Jonathan Swift
JDLuke is offline   Reply With Quote
Old 11-30-2008, 06:38 AM   #8
Jonex OP
Jonex's Avatar
Oddometer: 1,357
It's got a 120V motor, I think 3/4 but maybe only 1/2. It's pretty wimpy. If I stick a bit, the chuck just stops and the belts slip. I like it that way.
It only starts harshly when set to the lowest couple of speeds. At higher rpm ratios, it's fine.
I tried hooking up a dimmer switch, but it wasn't quite up to the task. So now the dimmer switch is set up in a box with an outlet and I use it as a router speed control.
Old 11-30-2008, 07:44 AM   #9
JRP
Old guy
JRP's Avatar
Oddometer: 1,472
"variable speed control" plug that into an Ebay search, they have many available. I would stay away from the Dremel models but one for a router should work just fine.
"What could possibly go wrong? " The Jerk
2012 TE 250
2010 F 650 GS
1983 R 80 G/S
JRP is offline   Reply With Quote
Old 11-30-2008, 07:56 AM   #10
showkey
Oddometer: 1,789
speed control
Most if not all the speed controls are setup for brush type motors (universal) and will not work on induction type motors (brushless). Induction motors will not like a dimmer type switch. Induction motors need all the voltage to run correctly....to change the speed of an induction motor you change the frequency with VFD.
showkey is offline   Reply With Quote
Old 11-30-2008, 06:07 PM   #11
gsweave
Oddometer: 11,220
Oh!!! So you won't be drillin any 4" I beam anytime soon, huh?
Old 12-01-2008, 04:35 AM   #12
Jonex OP
Jonex's Avatar
Oddometer: 1,357
Considering the cheap, poorly made, pathetic nature of a Harbor Freight drill press, you might be surprised at what I've gotten out of it. I drilled and tapped a whole slew of 1/2" diam., 1.5" deep bolt holes in 3/4" cold rolled steel when I built my homemade lathe for instance. Slow rpm step drilling with lots of cutting oil and sharp bits did the trick.
It's survived my airplane project, too, drilling countless holes in aluminum, even 3/8" holes through 4" stack ups, over the last 5 years. The switch lasted a week, otherwise it hasn't broken. Pretty good value, overall, but I really should get a Smithy or a nicer drill press.
Old 12-01-2008, 05:04 AM   #13
gsweave
Oddometer: 11,220
Hey,
I have to use the one at work, so you are way ahead of me...
Have ya ever looked at an Ironworker?
http://www.edwardsironworkers.com/
It's the way to go.
Old 12-01-2008, 06:46 AM   #14
bomber60015
Anatomically Correct
bomber60015's Avatar
Oddometer: 9,332
I'm with the guys that are thinkin there's something wrong here -- y DP doesn't jump at all, and it isn't bolted ot weighted to anything -- course, it's a bit on the heavy side, so that may be helping . . . .
plus one on the center drill idea, btw -- drilling aluminum can spoil a fella ;-}
bomber60015 is online now   Reply With Quote
Old 12-02-2008, 07:11 AM   #15
gsweave
Oddometer: 11,220
Sonex
No time to look so far but these are the people I was going to use. Sorry been out the ass busy...
www.newark.com
Times are GMT -7.   It's 01:12 PM.
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
