Old 09-16-2011, 12:11 PM   #391
WitsBusa
in training.....
Oddometer: 113
Originally Posted by Poddy View Post
Cheers
Poddy
I was about to razz you for cutting that corner but then realized you all must use the opposite side of the road down under..
WitsBusa is offline   Reply With Quote
Old 09-16-2011, 12:35 PM   #392
olie
olie's Avatar
Oddometer: 1,171
Originally Posted by bross View Post
Damn, do any of you Concours owners have jobs? 5000, 8000, 10,000 mile trips.
yes, we call them vacation days and ride fast to maximize them.
13 ZG /C14 blue, Remus HexaCone Ti, CF hugger, CB Ultra W'shield, GSG Sliders
12 XT12 black, Akrapovic, Givi W'shield, Kappa saddlebags
olie is offline   Reply With Quote
Old 09-16-2011, 12:39 PM   #393
bross
Where we riding to?
bross's Avatar
Oddometer: 4,700
I shouldn't complain, my wife and I are on day 3 of a 3 week ride. But well deserved after working 7 days a week straight for the past 2 months!
Old 09-18-2011, 06:51 AM   #394
Poddy
Oddometer: 25
Yes we do and our "Loo's" flush the opposite way as well
Poddy is offline   Reply With Quote
Old 09-30-2011, 04:16 AM   #395
MKorn
2whl Addict
MKorn's Avatar
Oddometer: 752
Eagle Harbor
Even after a 1475 mile ride ... i am still smitten by this bike!
Always looking for a place to ride !
13 F800GS
09 Concours 14 ABS (sold)
02 Nighthawk 750 (sold)
06 DRz 400s
MKorn is offline   Reply With Quote
Old 09-30-2011, 05:06 AM   #396
PDsgt
Realistic about life
PDsgt's Avatar
Oddometer: 304
Russell Group buy.
Hey folks. Over on one of the Concours owners group forums, they are looking into a group buy discount on the famous Russell day long saddles. If you like to travel on your bike for any kind of distance they are well worth the money. Usually the more people that get in, the better the price. Attached is the link if your interested.
http://forum.zg1000.org/index.php/to...cseen.html#new
2013 Triumph Explorer
2012 Harley-Davidson Electraglide.
PDsgt is offline   Reply With Quote
Old 09-30-2011, 04:41 PM   #397
pat.murphy
Oddometer: 2
I got back last week from a 1700 mile trip from Cinci to the Texarkana, Ar area. The ride took 4 days although I had planned on a longer time wise ride. I rode 590 miles the last day to get home.
The bike was perfect. MPG around 48. The only real issue I had was with the seat. I bought a Sargent seat and never got numb butt. I did however have problems with my lower back due the seating angle. Figured it out into the ride so it was not a major issue on the way home. The bike has way more HP than needed but it sure is fun to zip past semis and car on the highway.
pat.murphy is offline   Reply With Quote
Old 10-01-2011, 05:20 AM   #398
Barry
Just Beastly
Barry's Avatar
Oddometer: 7,383
I'm posting this just because.... C14 rocks!
Tail of the Dragon at Deal's Gap... Avoid it now, do a trackday.
Do not do business with Myrtle West Cycle... Not a reputable vendor by a long shot.
Barry is online now   Reply With Quote
Old 10-01-2011, 05:27 AM   #399
WSikorski
WSikorski's Avatar
Oddometer: 2,517
Yes it does! Oh, and the make great winter transport...
2010 Kawasaki Concours 14 ABS
Wayne aka "CigarSki"
error id:1Øt
WSikorski is offline   Reply With Quote
Old 10-01-2011, 12:26 PM   #400
dsavage
Oddometer: 301
Have a question about fuses
I just bought a new Connie and am planning a west coast trip starting next Sunday. I have tested my heated gear and gps on the accessory plug and they work fine. Here's my question.....My airpump/compressor that has an inline 5 amp fuse blew the acc. plug 5 amp fuse. Do you see any problem with changing the acc.plug fuse from 5 amp to 7.5? I know it's not the compressor shorting it out because I hooked it up to my truck and GSA and it works fine. The only time I'd change the fuse would be by the side of the road fixing a flat. My knowledge of motorcycle electronics is lacking.
dsavage is offline   Reply With Quote
Old 10-01-2011, 12:53 PM   #401
cablebandit
Web Adventurer
cablebandit's Avatar
Oddometer: 706
What year is your Concours? They changed the cigarette plug wiring on the 2010 and newer and it only has a 5 amp fuse. You could change it out to a higher one if you want to burn the bike to the ground.
IBA #33260
cablebandit is offline   Reply With Quote
Old 10-01-2011, 01:35 PM   #402
dsavage
Oddometer: 301
fuse
It's a 2011. Are you saying that changing out the fuse from 5 to 7.5 just to run a compressor in an emergency situation would burn my bike to the ground? Should I wire a pigtail to the battery as a just in case situation? What would you do? I'm not going on a long road trip without an air compressor. So what's the best idea to circumvent a 5 amp accessory plug fuse? I'm leaving a week from tomorrow and want to get this sorted out. Appreciate the help.
Old 10-01-2011, 01:43 PM   #403
cablebandit
Web Adventurer
Oddometer: 706
The wire is sized for 5 amps. Anything over that and it will melt. Just wire it up to the battery, then when you get time put in an auxiliary fuse block and wire in a powerlet plug with whatever size fuse you want. Using the appropriate wire of course.
I'm not sure what kind of heated gear you were running off the Cig. plug but it's really not meant for that. It's only there for a GPS/radar/etc.
IBA #33260
Old 10-01-2011, 01:51 PM   #404
dsavage
Oddometer: 301
Fuses
I'm running an old Gerbing vest that I've had for at least 12 years. It doesn't get much work here in central Texas. I have no idea how many amps it draws but when I tested it the warming time was about the same as it is in my GSA. If there is five amps of power, and if the heated wear draws less than that, then why shouldn't it be used for heated wear? Just asking. Thanks.
Old 10-01-2011, 01:54 PM   #405
cablebandit
Web Adventurer
Oddometer: 706
Sounds like it's less than 60 watts then if it's not blowing the fuse. You should be ok then. Most modern stuff is quite a bit more.
IBA #33260
Times are GMT -7.   It's 02:22 AM.
