Go Back   ADVrider > Riding > Regional forums > Pacific Northwet - Where it's green. And wet.
Old 01-12-2012, 08:57 AM   #6721
asrvivor
Rabies Cure ????
asrvivor's Avatar
Oddometer: 1,877
Originally Posted by oremike View Post
Of you guys that have had a Dunlop 606 chunk out Vs. those of you that haven't had the problem what tire pressures do you run? My hypothesis is that the higher pressures cause the chunking by not allowing the tire to flex, putting that energy into the knobs.
24 and 21. I have tried different pressures though. Talking with SlowJoe, he is under the impression that what is happening is someone in the factory is putting their finger on the tire prior to it being completely set. IDK They still work fine. They just scream like hell on the highway.
Staring straight into the shining sun....
Just cause I'm wrong, don't make you right / Needtobreathe
Our OBDR Trip http://advrider.com/forums/showthread.php?t=712724
Our UTBDR Trip http://advrider.com/forums/showthread.php?t=816500
asrvivor is offline   Reply With Quote
Old 01-12-2012, 09:53 AM   #6722
peterman
cop magnet
peterman's Avatar
Oddometer: 13,806
TKC80's are speed rated,,D606's are not.
I have never had a problem with either tire, but the 606's are far cheaper.
I run 32 rear and 26 to 28 front on pavement, and drop both 10psi for off pavement.
peterman
___________________________
"Your God, your rules,,YOU go burn in hell!" LLV
peterman is offline   Reply With Quote
Old 01-12-2012, 10:53 AM   #6723
wibby
BrotherFromAnotherMother
wibby's Avatar
Oddometer: 10,599
22psi on road 13psi offroad
My next dualsport is going to have an 18" rear tire, so I can just run real knobbies
'05 DL650
'92 KDX200
wibby screwed with this post 01-12-2012 at 11:32 AM
wibby is offline   Reply With Quote
Old 01-12-2012, 11:35 AM   #6724
RideAbout
Mentally Retired
RideAbout's Avatar
Oddometer: 1,741
... what tire pressures do you run? My hypothesis is that the higher pressures cause the chunking by not allowing the tire to flex, putting that energy into the knobs.
Well my $0.02 would be the opposite. What I have read/heard/been lied to/personal experience is that Knobbies don't like high speed droning with a load and "low" pressure. Heat builds up and knobs flake off.
I tend to run high pressure at high speeds... and my own particular voodoo is to run them through some heat/cool cycles before I run them a long time at speed. I once spooned on a new 50/50 tire, rode it to the Alvord loaded with gear, arrived, chunks missing, checked pressure... whoops, low 20's. YMMV
My personal outlook is if I run a knobby at prolonged high speeds and get chunking or ride with street tires in the mud and crash.... well, I was asking for it!
West - "Oeste Sanchez"
RideAbout is offline   Reply With Quote
Old 01-12-2012, 06:38 PM   #6725
oremike
Motorcyclest
oremike's Avatar
Oddometer: 2,401
Thanks guys, coming from a street bike background and running modern street radials I'd run 36F & 40R but with the dual sports I've been running 25 F&R. On this last ride I was at 20 psi front and rear. I was thinking I'd get more traction in the mud with less pressure. Somewhere, some time I was told that's as low as I should got without rim locks. I guess like most things in life, you places your bets and takes your chances.
Ride what makes you giggle in your helmet
oremike is online now   Reply With Quote
Old 01-12-2012, 06:44 PM   #6726
oldmonkeybut
Digital Emigrant
oldmonkeybut's Avatar
Oddometer: 2,640
For the type of riding we were doing last Sunday I was running 15psi Rear and 18psi front. If it was muddier I drop about 3psi on both ends. If it was rocky I go up 3psi on both ends.
oldmonkeybut is offline   Reply With Quote
Old 01-12-2012, 09:03 PM   #6727
wibby
wibby's Avatar
Oddometer: 10,599
Hmmmm running any kind of dirt, 13 is my max
I used to run the stock deathwings down to around 8psi on the rear without locks
I put rim locks on my DR front and rear when I started running knobbies
I was ripping out valves stems at 22psi on the street
'05 DL650
'92 KDX200
Old 01-12-2012, 09:41 PM   #6728
Miguel Sanchez
VD #93
Miguel Sanchez's Avatar
Oddometer: 1,203
Rim locks
Did Honda remove the rim locks..? My '04 650L came stock with one each, front and rear. My '95 came the same way.
YMMV on tire pressures. With the 650, I like to run a little more pressure (15 to 17 front, 12 to 15 rear) because I hate changing flats. My Montesa runs 4 psi in the rear and about 6 in the front .
- Miguel
01 GS1150, 02 WR426F, 04 XR650L, 04 315R, 04 CRF230F, 81 R100RT (S), 56 G80CS, 87 MT11, 71 TS185, 74 98SR, 74 99RT, 76 TL250, 70 MX125, 80 DR400, 80 RS175, 80 RS250, 78 XR75, 74 RD350, 70 CT70, 06 Monster 620 Dark, and about a dozen more I can't think of right now...
Miguel Sanchez is offline   Reply With Quote
Old 01-12-2012, 09:55 PM   #6729
wibby
wibby's Avatar
Oddometer: 10,599
Hmmm, Only flat I ever had on the DR offroad was from running a really rocky section without airing down and I punctured the tire on a rock. I think I'd been ok had I been running low pressure
'05 DL650
'92 KDX200
Old 01-12-2012, 10:16 PM   #6730
oremike
Motorcyclest
oremike's Avatar
Oddometer: 2,401
On my '09 the rims are drilled for rim locks but it didn't come with them.
Old 01-13-2012, 10:07 AM   #6731
RideAbout
Mentally Retired
RideAbout's Avatar
Oddometer: 1,741
...I like to run a little more pressure (15 to 17 front, 12 to 15 rear) because I hate changing flats .
Or you guys could just call it good at 25psi F/R and learn to ride!
I know, I'm a
RideAbout screwed with this post 01-13-2012 at 10:12 AM
Old 01-13-2012, 12:57 PM   #6732
oremike
Motorcyclest
oremike's Avatar
Oddometer: 2,401
West about mid point of the ride you made a comment that still makes me grin. That was just after you'd rode your XR up and down the clay hill, you said after all the years of chasing the Sanchez brothers around with your KLR, you realized how much they were cheating by riding XR's.
Old 01-13-2012, 01:22 PM   #6733
Miguel Sanchez
VD #93
Oddometer: 1,203
I like to think of it as best utilizing the resources available to me.. . Plus, it's a proven fact that Honda riders get WAY more pussy than those KLR guys do!
That West guy has always been a bit over-inflated in my opinion.
- Miguel
Old 01-13-2012, 06:18 PM   #6734
RideAbout
Mentally Retired
RideAbout's Avatar
Oddometer: 1,741
Hey, don't hate me cause I'm fat!
Old 01-13-2012, 07:23 PM   #6735
Used2BeFast2
Chupacabra Rider
Used2BeFast2's Avatar
Oddometer: 570
I hear DR riders never get enough
Cat herder....really!
Used2BeFast2 is offline   Reply With Quote
Times are GMT -7.   It's 05:46 AM.
