Old 12-04-2008, 11:07 AM   #1
newride OP
newride's Avatar
Oddometer: 668
front brake bleed for an airhead
Hello all again,
yes, I am catching up on years of no maintence on my R90/6. I did a search and could not find if there is a step by step on bleeding the front brake on such a bike. I have never done the fluid in brakes before.
1975 BMW R90/6
2006 DR 650
My moto blog: http://jbloggie1.blogspot.com/
newride is offline   Reply With Quote
Old 12-04-2008, 11:18 AM   #2
Mista Vern
Knows all - tells some.
Mista Vern's Avatar
Oddometer: 12,874
Just Google "how to bleed brakes" and you will get lots of info. It's nice to have a helper on hand, but you can do it yourself. Brake fluid is hard on surfaces, so if you spill any clean it up real well.
Eidt: cars and bikes are generally thesame process, only the brake lever is pumped instead of a pedal. Also, be very careful trying to loosen the bleeder; if it hasn't been opened in a long while it may be tough to get it to turn. Make sure the wrench fits tight or you will round off the bleeder.
Remodeling. Please check again later.
Mista Vern is offline   Reply With Quote
Old 12-04-2008, 11:44 AM   #3
datchew
Don't buy from Brad
datchew's Avatar
Oddometer: 7,403
how long has it been? It might looks like this (notice the chunks):
On tap:Nada
Aging: 3 experiments in mead - blackberry, apple, and straight honey
datchew is offline   Reply With Quote
Old 12-04-2008, 11:57 AM   #4
rain
Ooh Ooh Ahh Ahh
rain's Avatar
Oddometer: 93
Originally Posted by newride
Hello all again,
When I did the brake fluid on my old RS () I used SpeedBleeders ... they're kinda hokey but they make doing the job yourself much easier. If you want someone to come and help with the loosen-squeeze-tighten procedure let me know...
Have: '12 V-Strom 650, '83 R100RS
Had: '96 DR650, '78 R100RS Motorsport
rain is offline   Reply With Quote
Old 12-04-2008, 12:53 PM   #5
kz1
kz1's Avatar
Oddometer: 780
Word of caution
Just a word of caution, do not overtighen the bleeder. They will snap off and they are a bitch to get out. Just tighten then until snug. After your first ride, if they are leaking, snug them up again.
kz1 is offline   Reply With Quote
Old 12-04-2008, 01:05 PM   #6
kbasa
Tinaversal
kbasa's Avatar
Oddometer: 59,288
Send a message via Yahoo to kbasa
Also, do not squeeze the lever all the way in against the bar. You're liable to do some bad things to the piston seal in the master cylinder by moving it out of it's little comfort zone.
It's easy to bleed brakes.
Clean and remove cap on master cylinder.
Get an old beer bottle or something and run a tube of clear hose from the bleed nipple to the bottle. Make sure the tube fits tightly over the bleed nipple.
Apply pressure to the brake lever and hold it.
Loosen the bleed nipple a bit and allow the lever to travel a bit, forcing brake fluid up into the hose.
Tighten the bleed nipple.
Release the brake lever.
Repeat until the lever feels firm and no more air bubbles are coming out of the nipple.
Do not let the master cylinder run low and admit air into the system.
Only use brake fluid of the type specified for the bike and from a sealed container - in short, buy some new stuff.
If you're changing the brake fluid, keep pumping it through until clean stuff comes out the bleed nipple.
And yes, it's easier with a helper. Have the guy doing the bleed nipple tell the other guy when to squeeze and when to release the handle.
IMHO.
Fuck Cancer. Ride bikes. - dave + tina
kbasa is offline   Reply With Quote
Old 12-04-2008, 01:06 PM   #7
kbasa
Tinaversal
kbasa's Avatar
Oddometer: 59,288
If they start to corrode, I just replace them and make sure the little rubber cap is available. BMW carries the little rubber caps and they're only a couple bucks. The new ones have a ring on them and they're retained by the nipple so you can't lose them.
IMHO.
Old 12-04-2008, 01:49 PM   #8
kz1
kz1's Avatar
Oddometer: 780
Speed Bleeders
+1 on the Speed Bleeder. The Speed Bleeder number for your bike is: SB1010S.
Old 12-04-2008, 02:25 PM   #9
crazydrummerdude
Wacky Bongo Boy
crazydrummerdude's Avatar
Oddometer: 6,901
Send a message via AIM to crazydrummerdude
In my case, it snapped when I was taking it off. Then the EZ-out snapped (what else do they EVER do?). Then, I had to Dremel the bleeder valve out, around the tip of the EZ-out, but not into the threads of the caliper. Then, it all fell out.
Cleaned it up, and installed a new valve with the little rubber bit on the end.
crazydrummerdude is offline   Reply With Quote
Old 12-04-2008, 02:34 PM   #10
Mista Vern
Mista Vern's Avatar
Oddometer: 12,874
Nice save!
Old 12-04-2008, 06:10 PM   #11
jtwind
Wisconsin Airhead
jtwind's Avatar
Oddometer: 3,451
Though they work fine, you don't need to buy speed bleeders for each bike. The tool in Datchew's photo above is by Motion Pro and it's piece of tubing with a check valve in it. Works the same as a speed bleeder yet you can use it on all your bikes. Just put it on, crack the bleed nipple and pump away, just don't run the reservoir dry.
I gave up on speed bleeders after I discovered it.
JT
www.northwoodsairheads.com
www.jefftrappwindsors.com
"Between two explanations, choose the clearest; between two forms,
the most elementary; between two expressions, the shortest."
Between two motorcycles the simplest (DW)
Eugeni d' Ors (1881-1954); Spanish writer.
jtwind is offline   Reply With Quote
Old 12-05-2008, 10:34 AM   #12
newride OP
newride's Avatar
Oddometer: 668
Thanksfor the offer man,
I am going to tackle that maybe in 2 or 3 weeks, I will let you know.
J
1975 BMW R90/6
2006 DR 650
Old 06-18-2012, 02:28 PM   #13
gasolinePony
gasolinePony's Avatar
Oddometer: 27
Fluid Brand?
Is there a particular brand anyone recommends for Dot 4 brake fluid?
gasolinePony is offline   Reply With Quote
Old 06-18-2012, 02:47 PM   #14
patanga
BMWAirheadsDownunder
patanga's Avatar
Oddometer: 155
Easy bleeding tip
Hi gasolinePony. Welcome to the forum. As you can see, there's more than one way. I've tried most methods and below is a link to the method I use. Scroll down the thread link below until you find the picture of the syringe. There you will see a cheap tool to make bleeding an easy one man job. Just top up the reservoir, connect syringe to caliper nipple via clear pvc tubing and draw the fluid through. The suction from the syringe should be plenty to bleed your brakes. Avoid pumping the brake lever when bleeding as that can stir up junk at the bottom of the M/C and wreck the seals.
Read the info in the posts and you'll come across a small safety mod also. You'll see that there are a number of variations in syringe tip design that might make tube fitment easier for you. I usually draw the fluid through from the filled reservoir with the syringe, but one inmate mentions that he fills the syringe with fluid and back pressure fills/bleeds the brake system from the bottom up. Never tired it that way, but that method also sounds plausible.
Most brake fluid brands are pretty good. Stick to the name brands is your best bet. Cheers. http://www.advrider.com/forums/showt...169507&page=45
____________________
"The only reason people get lost in thought is because it's unfamiliar territory" (Joe Garcia)
Check us out on facebook at "BMW Airheads Downunder", (The Australia and New Zealand Airhead Community). "B.A.D"
http://www.facebook.com/groups/anzairheads/
patanga screwed with this post 06-19-2012 at 12:21 AM
patanga is offline   Reply With Quote
Old 10-08-2012, 08:50 PM   #15
gasolinePony
Oddometer: 27
syringe worked a treat.
Thanks for the advice! I ended up doing it the tried and true way, because I'm new at it. I did however, use the syringe to pull the fluid down, while my buddy pumped the brake--nice method to get the draw going. So far it's working out, save a little leakage at the nipple, despite snugness.
Times are GMT -7.   It's 07:51 AM.
