Old 09-05-2009, 11:40 AM   #151
ErrinV
D Boon!
ErrinV's Avatar
Oddometer: 2,292
You guys that have ordered the Batteries Plus version, did you order the 14-BS? I thought we needed a 14-S, but I don't see that option available.
This is the battery?
Thunderbird 1 - '14 BMW F800GS ADV
"Love comes in spurts!"--Richard Hell
ErrinV is offline   Reply With Quote
Old 09-16-2009, 01:14 AM   #152
Vicks
I love sand !!!
Vicks's Avatar
Oddometer: 3,127
Originally Posted by Mr.Vicks
Originally Posted by Head2wind
Received the X2-9 batteries, started doing the comparisons to the B106 Braille. Based upon what I can tell, externally these are identical batteries. Cases, markings, posts and everything external except the labels are very similar.
Both the X2-9 batteries came in one day, one had 12.63v and one was at 12.79.
I put both on my OptiMate 4 smart charger until it went into "maintain" mode, let them sit over night and rechecked Vdc. both have settled to ~ 12.7-12.8Vdc range.
I slid one of them into a 950 that I am working on that needed a battery, real world use/testing will commence with that battery. the second one will be used for load testing as soon as I get my hands on a carbon pile......
Short of cutting them open and comparing the internals I will do load/charge testing as soon as I acquire some equipment.
any updates on the comparo between X2-9 and the B106 ??
I will be ordering a new battery soon and would like to see some comparison before doing it.
cheers
hey, any results / updates ?
GO !!! Berglund brothers #148 #149
GO !!! CS Santosh #59
Vicks is online now   Reply With Quote
Old 09-16-2009, 02:12 PM   #153
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,568
so far comparisons and performance from the X2-9 batteries is the same as the B106 that is in my motorcycle. I have not done any carbon pile load tests, however have had one in my 950 now since purchasing it and recently did a bunch of stop/starting at the KTM rally while riding trails. battery performed perfectly.
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla
2006 KTM 970 frankinADVsmSD
ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
Head2Wind is offline   Reply With Quote
Old 09-17-2009, 12:46 AM   #154
Vicks
I love sand !!!
Vicks's Avatar
Oddometer: 3,127
guys, there is a VARTA battery of specifications that closely match the stock Yuasa.
Product data
VARTA FUNSTART AGM 511 902 023 A514
Article number511 902 023 A514
Product lineFUNSTART AGM
Voltage [V]12
Battery Capacity [Ah]11
Cold-test Current, EN [A]230
Length [mm]150
Width [mm]87
Height [mm]110
Hold-down TypeB00
Pole Positions1
Terminal TypeY11
SC
and it sells for approx 110$ here
does anybody have experiece with VARTA batteries ? especially in hot/humid climates ?
Old 09-17-2009, 12:50 AM   #155
SeanW
Oddometer: 117
Has anyone tried the new Lithium Ion Polymer batteries for bikes?
Half the weight, half the size, so theoretically twice as good ?
SeanW is offline   Reply With Quote
Old 09-17-2009, 12:51 AM   #156
xdbx
Motorcycle Connoisseur
xdbx's Avatar
Oddometer: 2,493
Guys, I walked into a Batteries Plus last week after reading this thread and inquired about the X2-9. The guy showed me one, said $80 and its yours. Done deal, it's working just fine. What's not to love?
xdbx is offline   Reply With Quote
Old 09-17-2009, 12:54 AM   #157
xdbx
xdbx's Avatar
Oddometer: 2,493
Li-po (lithium polymer) is a deadly combination for what we do with bikes. The batteries are highly unstable to shock, puncture, and heat. They also require advanced charging ciruits. DO NOT USE.
Old 09-17-2009, 08:04 AM   #158
Rapid Dog
bikes, booze, broads...
Rapid Dog's Avatar
Oddometer: 9,347
Well, since I bit on the Braille fiasco, I have a perfectly good 950 ADV Yuasa and a BMW R12GS battery(s) sitting on the bench if anyone needs one...e-me and we can cut a dealio.
'91 R100GSPD Derelict Deux , '81 R100RS Rattlecandy Red/'06 950 ADV Orangeboom/91 R100GSPD Derelict etc.
Rapid Dog is offline   Reply With Quote
Old 09-17-2009, 08:45 AM   #159
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,568
From what I have found, Lithium Iron Polymer (LiFePo4) are stable and could be used in this application. LiPo batteries need to be charged correctly and therefore may not be well suited for most motorcycles as the charging systems are typically not designed for anything other than LA batteries. IF you run a LiPo battery, adding a charge controller will significantly reduce the chances of flaming a battery/bike.
Old 09-17-2009, 08:59 AM   #160
SeanW
Oddometer: 117
Hi Guys
These batteries manufacturers seem to think that their Lithium Ion batteries are just the thing we need for our bikes.
E-batt www.ebattonline.com
Super-B www.super-b.com
Turntech www.turntechbattery.com
Can anyone foresee any problems ??? They do seem quite confident.
Old 10-15-2009, 08:11 AM   #161
NothingClever
Dirt Winger
NothingClever's Avatar
Oddometer: 1,097
Yes, Varta came stock in Husqvarnas (might still) and are notoriously unpredictable.....some just fine after several seasons, some shot within a few months.
Flying the Austrian Adventure Airlines at 3ft AGL
And a little Swedish rocket from Varese, Italy has me a mile high
NothingClever is offline   Reply With Quote
Old 10-15-2009, 10:43 AM   #162
Johnf3
Oddometer: 1,046
I sent an email off to TurnTech about making me a battery suitable for the 950. I'll post back what I find out. I do know from reading lots of feedback from the battery owners of the ones he makes for single cylinder e start four strokes that they are a viable alternative. About half the weight too.
Edit: I am going to try out a 5Ah battery from TurnTech. It's less than two pounds! Joe, the owner of the company, said the 950 MAY need more capacity but the 5AH might get it done. I sent him a short email with a few questions and he sent me back a VERY detailed reply. Looks promising.
'06 950 Adventure S
'10 Husaberg FX 450
'01 KTM 520exc
Johnf3 screwed with this post 10-15-2009 at 02:15 PM
Johnf3 is offline   Reply With Quote
Old 10-15-2009, 02:55 PM   #163
sp4ce
Orange Invader
sp4ce's Avatar
Oddometer: 431
Please keep us posted. I'm very interested in these.
sp4ce is offline   Reply With Quote
Old 10-15-2009, 04:43 PM   #164
WIsixfitty
ceiling unlimited
Oddometer: 2,160
fwiw after installing a Braille this past spring I have had zero problems with it to date.
sideways and smiling
WIsixfitty is offline   Reply With Quote
Old 10-15-2009, 07:22 PM   #165
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,568
for the most part this should be true. the rub is that EastPenn (the OEM of the Braille) OEMs for a couple other brands and is the EXACT battery for half or 1/3 the asking price of a Braille. As far as I can tell Braille performance numbers = creative testing+marketing. Technically these batteries WILL perform as advertised by Braille, the gotcha is they wont last very long if you abuse them, just like every other VRLA battery out there. None the less, the EastPenn battery seems to be holding up well, both branded as Braille and X2-9. One in my bike and one in a buddies. The other X2-9 is on the bench getting abused to see what it will put up with.
Times are GMT -7.   It's 10:15 AM.
