Old 05-07-2004, 06:40 AM   #1
gorgopodaros OP
gorgopodaros's Avatar
Oddometer: 286
Laugh Carbon - Kevlar Help
I bought all stuff needed to make a nice couple of carbon -kevlar protection pads for my tank on the 950.
I've seen it's been done beofre.
How do you glue them ?
Hot silicone would be OK or will they come off at the first crash ?
3 layers are enough ? (that's what I've been told at the carbon shop)
If I place them only on the lower part of the tank as the ones I've seen on this forum will it be OK or should I make bigger ones to cover the higher part as well ?
Anyone that crashed allready ? Barbasma I think you did ? was it OK or would you ask for protection higher up???
Thank you all
gorgopodaros screwed with this post 05-11-2004 at 01:27 AM
gorgopodaros is offline   Reply With Quote
Old 05-07-2004, 09:38 AM   #2
barbasma
100% CAROTONE
barbasma's Avatar
Oddometer: 1,821
Kevlar
JUST SILICONE (FOR BATHROOM USE) ARE GOOD... JUST FEW...
YES... MINE ARE 2 LAYERS...
I'VE CRASH MANY TIMES IN THE MUD AND GRAVEL.. BUT NO PROBLEMS WITH KEVLAR PROTECTION... ON THE SIDE FRONT PANEL... JUST LITTLE SUPERFICIAL CUT... THE ACERBIS PLASTIC IS EXPENSIVE BUT REALLY GOOD AND FLEXIBLE.... JUST REPAINT THE TRASPARENT... AND GO...
Thank you all
"Dakar must be a race for few people, Dakar is a dream, the dream of the Rose Lake, if everybody finish it, the dream is over" Fabrizio Meoni
ciao Matteo
www.barbasma.smugmug.com
www.lc8.org
www.adventureschool.it
KTM 950 ADV S 2003 80.000 KM..... and gooooo...
barbasma is offline   Reply With Quote
Old 05-08-2004, 02:32 PM   #3
BigTwin
Adventure Hound
BigTwin's Avatar
Oddometer: 141
You can make them so that they don't require any adhesive at all to hold them in place, that way they can be removed when the bike is cleaned.
Just extend the fabric up under the upper fairing and wrap it around the front of the tank so that they hook in place. Also use the two bolts that attach the black plastic OEM guard to help hold your kevlar guards in place.
I still use six layers of fabric on any surface that could come in contact with the ground and three layers at the sharp bends. Personally I would say that if you are going to the trouble of making them, then use six layers.
This is six layers on Woodsrider's bike.
MOTOREX
Oils and Cycle Care Products
BigTwin is offline   Reply With Quote
Old 05-09-2004, 02:51 AM   #4
barbasma
100% CAROTONE
barbasma's Avatar
Oddometer: 1,821
the best carbonkevlar protection that i ever seen....
ciao Matteo
www.lc8.org
Old 05-10-2004, 11:06 PM   #5
gorgopodaros OP
Oddometer: 286
C-K protection
Ok, I've done it !
I would like to thank all of you guys that inspired me to do this...
This is one step before the final trimming and laquering.
Old 05-10-2004, 11:08 PM   #6
gorgopodaros OP
Oddometer: 286
please notice that I took it one step further and chosed to protect the fuel "switches" as well, since I was already there why not ???
Old 05-10-2004, 11:10 PM   #7
gorgopodaros OP
Oddometer: 286
the other side ....
thanx again
Old 05-10-2004, 11:14 PM   #8
gorgopodaros OP
Oddometer: 286
I guess the under-body protection is the next project.
And the front fender after that,
and the chain guard,
and the side panels
and
and
Old 05-11-2004, 01:17 AM   #9
claferal
Oddometer: 156
Hi folks,
I have a question. How do you do to avoid the carbon-kevlar glued to the tank when you are making the piece? I think that the epoxy resin weld to the tank as well to the carbon-kevlar mat.
claferal is offline   Reply With Quote
Old 05-11-2004, 01:23 AM   #10
gorgopodaros OP
Oddometer: 286
If everything goes as it's supposed to, the piece will come off as it has 4 layers of wax underneath.
If.....
I'll let you know in 2 days when I'll (try to) take it off
Times are GMT -7.   It's 08:33 AM.
