Old 10-15-2010, 04:00 PM   #1501
RustySpokes
Two-bit throttle bum
RustySpokes's Avatar
Oddometer: 1,040
Originally Posted by 3uba296
Don´t really know what to think about this build.
It´s a -00 XR600.
I think it's cool as hell! But I've been called an idiot before too...
Got a link with more info?
"The beauty of fishing on motorcycles is that you’re riding motorcycles in great places whether you catch anything or not." - John Burns
RustySpokes is offline   Reply With Quote
Old 10-15-2010, 06:15 PM   #1502
MortimerSickle
Semi-Adventurer
MortimerSickle's Avatar
Oddometer: 12,136
Just don't make sit on that seat.
I miss round headlights.
"When I was a young man, I liked to race my horse...." -
G.H.W.S. 1878-1962
MortimerSickle is offline   Reply With Quote
Old 10-15-2010, 08:34 PM   #1503
HeadTrauma
¯\_(ツ)_/¯
HeadTrauma's Avatar
Oddometer: 1,260
Originally Posted by Blakebird
I don't spend much time there at all anymore - the XR600 threads get pretty stale and repetitive.
Yeah, I find myself spending less time there lately too. The same topics seem to run on a two-week loop.
1995 XR628R -Lots of goodies...room for more.
"Another breakdown, suicidal shakedown,
Feels like I'm livin' on a chain gang."
HeadTrauma is offline   Reply With Quote
Old 10-17-2010, 03:09 PM   #1504
polson
2 wheels !!!!
polson's Avatar
Oddometer: 242
Need Help!
My 1993 xr600 is having trouble. It starts, usually first kick, and runs but when I am riding and give it a quick full throttle it bogs down? I can slowly go to full throttle without a problem.
It only happens when I hammer on the throttle. Any ideas?
Also, I finally got a temp guage for this bike, what is an okay temp? It seems to run at 190-215 degrees.
thanks
polson is offline   Reply With Quote
Old 10-17-2010, 03:25 PM   #1505
Callahan
Callahan's Avatar
Oddometer: 1,181
thanks
First guess is,
- remove, completely disassemble and then clean all parts and tubes/orifices of the carburetor and the air filter, oh yeah put it back again.
If not joy,
- adjust your float to allow more fuel
If no joy,
- new jet (larger) though most likley not necessary. (altitude dependant)
I had this same problem and this worked for me.
Callahan is offline   Reply With Quote
Old 10-17-2010, 07:40 PM   #1506
archangelrider
archangelrider's Avatar
Oddometer: 1
my archangel
I have a 1985 xl600r, I have been on this sight for two years searching for any info on how to improve my bike Ive spent 5 years building it, I call her archangel , xrs only built the engine 618 big bore piston kit , paris to daker cam, hardned rockers, ported and polished, big header pipe, I run old air box, should I go pod filters, run on street and dirt. Any info on how to make her better, im all ears. Im HAVING TROUBLE uploading pics, if you want to see, go to my utube sight, channel 120970able1, arch was originally built for a hollywood project, BUT the money feel thru. any advice on how to increase horse power or performance would gladly be appreciated. thanks
archangelrider is offline   Reply With Quote
Old 10-17-2010, 08:45 PM   #1507
polson
2 wheels !!!!
polson's Avatar
Oddometer: 242
First guess is,
I thought at first it wasn't getting enough fuel quickly. I will tear down carb after looking at the air filter. Come to mention its been a while since I did clean the air filter.
thanks
Old 10-17-2010, 09:04 PM   #1508
Blakebird
r-u-n-n-o-f-t
Blakebird's Avatar
Oddometer: 15,831
thanks
what size pilot jet (what's your main as well, and what elevation do you ride at?)
Dubuque must be 800-1000 ASL?
*edit* 617 ft...just checked.
IBA #11735 . 1968-present
Blakebird is offline   Reply With Quote
Old 10-18-2010, 12:12 AM   #1509
HeadTrauma
¯\_(ツ)_/¯
HeadTrauma's Avatar
Oddometer: 1,260
Most likely your problem says "Keihin" and "PD8A" on the side. It's not a bad carburetor; it's just not a pumper carb and that throttle-snap bog will always be there with it. Going fat on the pilot can alleviate it somewhat while incurring its own side effects.
Old 10-18-2010, 02:35 AM   #1510
whozaberg
whozaberg's Avatar
Oddometer: 168
Slip It
A flick of the clutch gives it the pumper effect.
whozaberg is offline   Reply With Quote
Old 10-18-2010, 06:29 AM   #1511
brucifer
brucifer's Avatar
Oddometer: 2,377
Nice job on your XL.
If you haven't already, you should post this in the XL600 thread.
2014.5 Kawasaki KLR650 NE-2008 Yamaha TTR110-2006 Buell XB12SS-1993 Kawasaki KX500-1984 Honda XL600R/XR650L Hybrid-1984 Yamaha TT600L-1980 Honda CB750F-1977 Yamaha TT500
For sale--1996 Honda XR600R--
brucifer is online now   Reply With Quote
Old 10-18-2010, 10:28 AM   #1512
polson
2 wheels !!!!
polson's Avatar
Oddometer: 242
I don't think its the pilot jet. I change that when I moved to dubuque from colorado. I am going to start with the air filter it has been a while since that has been cleaned.
What temps are you guys running? Is north of 200 degrees too much?
Old 10-18-2010, 01:00 PM   #1513
mike_o
Oddometer: 9
[quote=Emile]hey mike o
where do you live ?? because here at my local bikeshop in germany it was no problem to order the bearing and you can also try this dutch dirtbike performance parts brand www.pro-x.com they have a good price bought mine there.
see you around
Emile[/quote
In Copenhagen. I'll try your link,thanks
mike_o is offline   Reply With Quote
Old 10-18-2010, 01:34 PM   #1514
veetwo _tls
RENOVATIO:
veetwo _tls's Avatar
Oddometer: 1,832
Originally Posted by mike_o
Blakebird,
thanks, I did give them a chance, but they quoted $62 for shipping a $49 bearing, so I gave it up...
Any other suggestions?
mike just a heads up
make sure if you buy after market bearings.
there HIGH SPEED bearings needed for the crank.
there NOT normal bearings as most others you can replace with on the bike.
i myself back in 2000 tried to find aftermarket with no luck i ended up buying OEM crank bearings. when i was replacing them i also noticed one side was slipping in the cases so i used locktite on the case where the bearing sat in. fixed the problem. (think what caused it was from take off's/dropping the clutch when i raced it)
nothing wrong with Orange i've gone that way.
KTM950SE = 3 x XR6's
KTM640ADV/625SMC rear
parts are cheap & easy to get if you got a friend in USA to shop & post for you (2 week wait via regular USPS or 4 days USPS express "to australia" )
Sent from my HTC ONE X - Using Rooted S-OFF , Open Home 6 & Buuf icon pack
http://forum.xda-developers.com/ BUILD YOUR OWN PHONE
CHEERS: brett
MY07 950 SER
veetwo _tls screwed with this post 10-18-2010 at 01:55 PM
veetwo _tls is offline   Reply With Quote
Old 10-18-2010, 01:51 PM   #1515
veetwo _tls
RENOVATIO:
Oddometer: 1,832
Most likely your problem says "Keihin" and "PD8A" on the side. It's not a bad carburetor; it's just not a pumper carb and that throttle-snap bog will always be there with it. .
+1
CHEERS: brett
MY07 950 SER
Times are GMT -7.   It's 08:09 AM.
