Old 03-05-2009, 06:25 PM   #211
Lomax
Nanu-Nanu Adventurer
Lomax's Avatar
Oddometer: 9,126
OK Really stupid question for you XR Guru's. Can the decompression lever be used while the bike is running or is that really bad stuff for the valves.
Not that I would ever use it for a descent brake but I have always wondered. In the good old days we used to do things like that.
Marc
84 R100RS LE, 14 Ducati MTSGT, 73 850 Commando, 78 CT90, 14 Ural, 74 Eldorado police, 64 R50/2, 13 TR650, 01 DRZ400E
http://s22.photobucket.com/albums/b327/lomaxcm/?sc=3
Lomax screwed with this post 03-05-2009 at 06:37 PM
Lomax is online now   Reply With Quote
Old 03-05-2009, 06:34 PM   #212
mcma111
mcma111's Avatar
Oddometer: 12,402
Decompression Lever
The decompressor pushes on the right exhaust valve rocker arm. Holding the arm open will stall the engine. Does not make for a very good brake.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 03-05-2009, 06:39 PM   #213
Lomax
Lomax's Avatar
Oddometer: 9,126
OOPS, fixed. I did not mean decent brake, I meant descent brake. Kind of like a Jake brake. We used to use them all the time on the old 2 smokes for going down big hills but I have never done it on a 4 smoke as I just figured it would induce the valve into the piston.
But what do I know about mechanics?
Marc
Old 03-05-2009, 07:56 PM   #214
Blakebird
r-u-n-n-o-f-t
Blakebird's Avatar
Oddometer: 16,289
those were the days....
My 3rd bike was a '69 Kawasaki C2 T120 Roadrunner, my first 2 stroke, and it had a compression release (and an expansion chamber - a mini orchestra!)
IBA #11735 . 1968-present
Blakebird is offline   Reply With Quote
Old 03-05-2009, 08:13 PM   #215
XRider
Almost Lifelike
XRider's Avatar
Oddometer: 1,275
I had an old '73 CZ 400 with dual plugs and a compression release. Lots of holes in the head. God help you if it kicked back while trying to start it.
XR650R Plated Supermoto
XR628R Plated and highly modified
CR500R Still rips after all these beers
RZ350L Kenny Roberts Special
BMW R1200GS Adv Kind of a space ship
XRider is offline   Reply With Quote
Old 03-10-2009, 10:25 PM   #216
docious
Shit Needs a Rebuild...
Oddometer: 32
Originally Posted by docious
I just installed a Baja Designs DS kit on my '92 XR600R complete with analog speedo. After I put everything together I realized that my bike was dying if I turned a sharp right. I figured out that there was too much force being put on the compression release cable and causing it to open up just enough to kill the bike.
Has any one had this problem, or have an idea of how to fix it. I tried re-routing the cable, but I am still having problems...
I finally figured out how to route it so that it would not pinch the cable. I still don't like the placement for the decompression lever. Maybe one of these days I will get around to moving it. Anyone have any great placement ideas?
1992 XR600R (Plated)
docious is offline   Reply With Quote
Old 03-16-2009, 10:23 PM   #217
Pablo83
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,814
http://thekneeslider.com/archives/20...engine-update/
Pablo83 is offline   Reply With Quote
Old 03-17-2009, 01:17 AM   #218
Zombie_Stomp
Aspiring human
Zombie_Stomp's Avatar
Oddometer: 2,231
I just fitted an XR600 front end on my '83 xl600r, and in the post-swap debugging process, was wondering what that "best routing" for that cable is. Could you tell us about it, I'm missing my XL manual.
I also recently put my nice dual-carb head on the single carb XR600 engine I had been using. Runs like a champ now, lots of power.
1982 4x4 longbed, a rolling daily driver work-in-progress...
1987 Yamaha XT600 2KF (German)
STOLEN: RED XL600 in Portland
I do heavy-duty textile repair, upholstery, and design/manufacture bags.
Zombie_Stomp is offline   Reply With Quote
Old 03-17-2009, 01:19 AM   #219
Zombie_Stomp
Aspiring human
Oddometer: 2,231
Originally Posted by pablo83
Yes!!! Thnaks for posting that, I had seen the early pic of the cylinders going on the block and wondered if he ever made it run! I'll have to read on now to find out!
Old 03-19-2009, 10:38 AM   #220
todd5774
Hillbilly
todd5774's Avatar
Oddometer: 196
My 93 Xr600r.
89 Yamaha Xtz850 Dead and parted out.
93 Xr600r sold
02 Gasgas ec300 now a 250
todd5774 is offline   Reply With Quote
Old 03-19-2009, 05:26 PM   #221
XRider
Almost Lifelike
XRider's Avatar
Oddometer: 1,275
Sharp looking XR600.
Old 03-19-2009, 06:22 PM   #222
JAB
Unsprung Weight
JAB's Avatar
Oddometer: 1,286
Here's my '91 in Death Valley.
1991 Honda XR628R
1978 Yamaha XT500
JAB is offline   Reply With Quote
Old 03-21-2009, 09:32 AM   #223
docious
Oddometer: 32
The trick was that I had to run the cable behind the right side bolt of the gas tank. It runs behind the left fork tube, in front of the headstock, behind the right fork tube, and then behind the right bolt of the tank.
I hope that helps!
Old 03-21-2009, 07:29 PM   #224
Zombie_Stomp
Aspiring human
Oddometer: 2,231
Thumb
I hope that helps!
Thanks, The gas tank doesn't bolt in on mine, but I'll make sure it is the XL600 equivalent of that routing. Thanks.
Joel
Old 03-21-2009, 08:21 PM   #225
atkxr600
Oddometer: 6
Well I don't want to be left out here, I bought a 1986 XR600R, brand new in 1985. It has been my faithful companion since then. It has been extensively modified, so modified, that none of the 86 parts are even still on it. The last rebuild, used parts from a 1991 donor bike. As sad as it may seem, I have decided to part ways with the old girl, ever since the CRF450R followed me home, the XR doesn't get used. I thought I would keep it just for sentimental sake, but just do not have the room. Anyhow, heres a few pics of my old friend.
atkxr600 is offline   Reply With Quote
Times are GMT -7.   It's 06:12 AM.
