Old 09-24-2011, 07:14 PM   #2566
HeadTrauma
\_(ツ)_/
HeadTrauma's Avatar
Oddometer: 1,260
I can see that it's cast, but it doesn't look original to me. Then again, I can't see the rest of it, either. Stock pistons are usually dished. If it's bigger than 97mm, it's definitely not original.
1995 XR628R -Lots of goodies...room for more.
"Another breakdown, suicidal shakedown,
Feels like I'm livin' on a chain gang."
HeadTrauma is offline   Reply With Quote
Old 09-24-2011, 07:29 PM   #2567
Ghost_Mutant
looking for bionics
Ghost_Mutant's Avatar
Oddometer: 713
HT, he is working on an 83 XR500 RFVC. Its the original piston, it looks just like mine.
Ghost_Mutant is offline   Reply With Quote
Old 09-24-2011, 09:35 PM   #2568
Blakebird
r-u-n-n-o-f-t
Blakebird's Avatar
Oddometer: 15,974
Originally Posted by J_Mobs View Post
If it IS the cam journal what do I do then?
my center journal got roughed up pretty good when my 628 let go.... XR's Only welds it up and machines it back to spec for $150
IBA #11735 . 1968-present
Blakebird is offline   Reply With Quote
Old 09-25-2011, 12:06 AM   #2569
HeadTrauma
\_(ツ)_/
HeadTrauma's Avatar
Oddometer: 1,260
Since that wasn't mentioned, I had assumed we were still talking about XR600s....
Old 09-25-2011, 02:01 PM   #2570
J_Mobs
J_Mobs's Avatar
Oddometer: 29
Originally Posted by HeadTrauma View Post
Is it shiny silver or more of a gray color? Magnetic or not? Gray is often from aluminum and obviously isn't magnetic. Metallic silver is typically from steel. If for some odd reason you ever see copper in the oil, that's from the conrod thrust washers. I would pull the frame strainer as a matter of course at this point.
Wait, how long was it run without oil flowing?
The oil flows fine. When I got it back in November of 2010 and drained the oil, it had small silver flakes, tiny ones. I got it running and noticed problems, so I rebuilt the top end. I put new oil in and ran it for a while, then had to address another problem. I opened the oil cover to replace the o-ring and oil was held up in the oil filter...section. It had some more silver flakes in it, still small though.
1985 XR600R
1973 CL350
"Nothing worth having comes without a fight"
J_Mobs is offline   Reply With Quote
Old 09-25-2011, 02:03 PM   #2571
J_Mobs
J_Mobs's Avatar
Oddometer: 29
No clue what he's talking about
I'm working on an 85' XR600R
1985 XR600R
1973 CL350
Old 09-25-2011, 03:51 PM   #2572
Ghost_Mutant
looking for bionics
Oddometer: 713
We were talking about the other question regarding this piston:
Its a stock Honda piston for an 83 RFVC XR500R, 92 mm bore. I have four pistons that look just like it. Thankfully two of my pistons are inside running engines without problems.............for the moment
Old 09-28-2011, 03:55 AM   #2573
enigma--
enigma--'s Avatar
Oddometer: 29
Hopefully going to look at one of these beasties to start my dirt adventure in the next couple of days. I've read a lot, however, this particular bike, a 93 model, has 27k km. How much is to high? The guy claims it is running fine and all other hits are in good condition.
The destination is but an excuse for the journey!
enigma-- is offline   Reply With Quote
Old 09-29-2011, 10:27 AM   #2574
elsalvadorklr
southern xr rider
Oddometer: 4,154
jetting at 5000feet and humid?
Hey doods, its been a while so Hi! jajaj
Anybody have some tips for my jetting at this altitude?????????..
We are moving to the mountains up here and its rainforesty, humid and anywhere from 4000 feet to 6000feet .last time I rode the hell out of the bike and managed to have a really nice ride with only a small tipover in some slimy muddy hardpack...did feel a bit low on power in the twisties...but not in the dirt.
but...I smell a lot of gas when at idle mostly, and blip it good...puffs out some smoke of the black kind! and its smelly.
again!
I have a 62 pilot at 2 1/2 turns out(thought about going in half a turn?)
And a 155 main, 3rd clip needle, thing is its not a keihin jet, some jet marked with an AB? should I go stock to 152?
Its first kick starter when cold with full choke, and first kick or so when hot, if it gets really hot and such after singletracking it will puff and die on me, then I use the drill and kick trough ten times, kill switch and full throttle and it will start right up so its pretty decent as is...
Thanks to all...
NEED SOME RIDING BUDDIES DOWN HERE BTW!
stay tuned for the bar opening and invitation to all adv members! yay!
christian
elsalvadorklr is offline   Reply With Quote
Old 09-29-2011, 01:58 PM   #2575
mcma111
mcma111's Avatar
Oddometer: 12,062
Jetting For Altitude
Christian,
Here ya go:
http://www.4strokes.com/tech/howtojet.asp
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 09-29-2011, 02:14 PM   #2576
elsalvadorklr
southern xr rider
Oddometer: 4,154
interesting! they say 1 size down on the mainjet for every 2000 feet, so that means I would need a 148-152? maybe I ll just go back to stock 152(which I don't have btw!) bummer
would you leave the 62 pilot in steve? I turned the screw in half a turn...it smells though when idling! jaja pretty bad
cheers and thanks
Old 09-29-2011, 02:51 PM   #2577
mcma111
mcma111's Avatar
Oddometer: 12,062
C,
YEAH IF YOU GET TO PLAYING WITH THE CARB IT CAN'T HURT TO GO DOWN A SIZE ON THE PILOT JET. I will be easier starting and be more responsive at the low end.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 09-29-2011, 05:27 PM   #2578
elsalvadorklr
southern xr rider
Oddometer: 4,154
if i ever get some time(big wedding on saturday) jajaj I will try to order some jets...is there such a thing as a 150main? starting is easy peasy, cause its rich, its a one kick wonder, thing is it stinks and soots up or blips black...I know Im rich...
anywhoo...
regular post for jets should work...jajaja
BTW my old triple top clamp was bent! Im assuming from the crash...the left side was higher than the righ,t I proved this by replacing it with the one you sent down and guess what? the left leg was higher than the right...that and I took off the brace just to see how it handled...
the tig welding on the exhaust is great except there is still a very very minor leak behind that little bracket stub, apparently its a common fault of the fmf powercore pipes...so I left the frame mount off for now...
dont have time to fiddle around and reweld it either...just want to ride! after the honeymoon of course, or NOT! ajajaja
cheers
Old 09-29-2011, 06:17 PM   #2579
mcma111
mcma111's Avatar
Oddometer: 12,062
Jets
C,
Let me know what jets you want AGAIN and I'll take a look see of what I have. I can mail them to you taped to a piece of cardboard in the envelope.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 09-29-2011, 09:31 PM   #2580
rj95lss
Been There
rj95lss's Avatar
Oddometer: 197
Just picked up a '93 XR600R in "ok" shape, got it running just long enough to ride it up/down the block and paid the guy $600 for it. Went to the courthouse today with the title and walked out with a new/clean title and IA plates for it. Very happy. Now begins the tear-down so by spring I have a street legal dirt bike to ride to the OHV parks and back.
Got a Clark tank, a pipe, and some other stuff in the deal too.
Probably going to see me around here asking questions....
82 XL500R
Past: 07 R1200S, 07 KLR, 97 F650 Funduro, 93 XR600R, 75 CB400f Super Sport, 75 CB360T, and many more...
rj95lss is offline   Reply With Quote
Times are GMT -7.   It's 07:28 PM.
