Old 05-08-2009, 10:29 PM   #256
Zecatfish
XTique Rider
Zecatfish's Avatar
Oddometer: 7,927
85 Xr600
I just bought one of these, but its a parts bike, I'm going to use the Front End for a franken bike project, and the rest is going to be parted out.
Engine of unknown character, I will sell it Head, Cylinder, then the tranny, side covered.
Once I figure out how bad it is. No idea at the moment what kind of shape it is in.
Rear Shock,
Swing Arm,
Frame,
Might have the carbs too. I got to look at it again.
Rear wheel.
Its an 85 XR600.
Watch for it in a couple weeks in the Flea Market as I get time.
So whats everyones opinion of the 43mm forks on the mid 80's XR600's for use on a DS bike? I've already been told they're not for MX racing. I didn't expect them to be. But the over all feeling of the forks.
Anything special to help these forks? Maybe heavier fork oil? Or fork oil volume, specs say 631cc per leg.
I'll be looking for a fork brace if any of you have one.
Google Earth GPS Howto (still a work in progress) use USGS TOPO Maps to layout trails.
http://home.windstream.net/catfish/GPS
The Early Bird gets the worm, but the second mouse gets the cheese.
https://sites.google.com/site/ozarkadventuretours/
Zecatfish is offline   Reply With Quote
Old 05-08-2009, 10:56 PM   #257
Zombie_Stomp
Aspiring human
Zombie_Stomp's Avatar
Oddometer: 2,231
Originally Posted by Blakebird
You're overfilling it. There's a method to checking the oil in this semi-drysump motor. It needs to be run to temperature, and if you've done high speed to get it there, rumble down the street, let it idle a bit....then shut it down and check it.
If you let the bike sit overnight and check it cold, you'll get a low reading. Oil can migrate out of the frame downtube into the sump, and give you a low dipstick reading.
Drain what you have in it from the engine drain plug and frame plug - then refill with 2 qts.
2.6 qts
1982 4x4 longbed, a rolling daily driver work-in-progress...
1987 Yamaha XT600 2KF (German)
STOLEN: RED XL600 in Portland
I do heavy-duty textile repair, upholstery, and design/manufacture bags.
Zombie_Stomp is offline   Reply With Quote
Old 05-09-2009, 05:31 AM   #258
Lomax
Nanu-Nanu Adventurer
Lomax's Avatar
Oddometer: 8,898
My 96 XR600R only holds 2 qts. so it may depend on the year.
Marc
84 R100RS LE, 2012 Stelvio, 2013 V7R, 73 850 Commando, 78 CT90, 14 Ural, 74 Eldorado police, 64 R50/2, 13 TR650
http://s22.photobucket.com/albums/b327/lomaxcm/?sc=3
Lomax is online now   Reply With Quote
Old 05-09-2009, 10:15 PM   #259
Blakebird
r-u-n-n-o-f-t
Blakebird's Avatar
Oddometer: 15,832
Originally Posted by Zombie_Stomp
2.6 qts
That's from bone dry, as in after a re-assembly (and the correct amount is 2.4 US qts)
For an oil & filter change, 2.1 US qts. (2 qts is what most do, 'cause it's easy)
http://www.justxr.com/models/88_600.html
IBA #11735 . 1968-present
Blakebird screwed with this post 05-09-2009 at 10:20 PM
Blakebird is offline   Reply With Quote
Old 05-09-2009, 10:27 PM   #260
Blakebird
r-u-n-n-o-f-t
Blakebird's Avatar
Oddometer: 15,832
Zombie's got an XL600R, which does have a 2.6 qt capacity.
Old 05-11-2009, 03:31 PM   #261
Not for Highway Use
Wannabe hasbeen
Not for Highway Use's Avatar
Oddometer: 996
I know this has been done to death but I've tried searching but there are too many hits.
How do I put a rear disc brakes setup on my '89 XR6? I'd happy with just links.
DL650, DRZ400,CRF250X, PW80
Legend in my own Control Panel
Not for Highway Use screwed with this post 05-11-2009 at 04:07 PM
Not for Highway Use is offline   Reply With Quote
Old 05-12-2009, 09:00 PM   #262
scrminbanshee
Awsome
scrminbanshee's Avatar
Oddometer: 803
does anybody know if a 1985 honda xl600r motor would fit into a 1991 rolling chasis....i got an 85 with no frame might be able to get a 91 xr rolling frame for 200 bucks....what do you guy think....
scrminbanshee is offline   Reply With Quote
Old 05-13-2009, 04:51 PM   #263
LilDirtRat
Oddometer: 256
Xr!
Yo dudes! Here's my new acquisition.. it's 94.. "genuine" HRC cam, BD street legal stuff, and 17" Excels laced to Talon hubs.
What a f**&^ng RIOT to ride.. This is probably the most fun I've ever had on a motorcycle..
.. So the PO told me that the HRC cam came straight from someone that worked for HRC.. But as I'm trying to dial this thing in, I'm a little confused.. Since it's got this HRC cam in it, how the f*&$ do I know where to set my timing and valve clearances? Wouldn't those be totally different than stock? I know someone out there's got some info on this thing, so hook a brotha up!
oh, and yes, I have dirt wheels for it, too
"Ignorance is bliss, but then there's Murphy and his damn law"
LilDirtRat screwed with this post 05-13-2009 at 06:48 PM
LilDirtRat is offline   Reply With Quote
Old 05-13-2009, 07:11 PM   #264
Zombie_Stomp
Aspiring human
Oddometer: 2,231
It is an XL600 but it has an XR600 engine in it. I guess the difference in capacity is in the frame.
Old 05-25-2009, 01:23 PM   #265
zipper2680
couch traveller
zipper2680's Avatar
Oddometer: 67
Hi!
This is my 94 XR600 SM..
94 XR600R
2000 Transalp 650
zipper2680 is offline   Reply With Quote
Old 05-25-2009, 01:34 PM   #266
Not for Highway Use
Wannabe hasbeen
Oddometer: 996
I like that colour scheme.
Old 05-25-2009, 01:42 PM   #267
zipper2680
couch traveller
zipper2680's Avatar
Oddometer: 67
Thanks..
Here some more of my small trips...
94 XR600R
2000 Transalp 650
Old 05-25-2009, 07:50 PM   #268
brucifer
brucifer's Avatar
Oddometer: 2,382
Ya know, the XR600R has to be one of the most versatile bikes ever built.
2014.5 Kawasaki KLR650 NE-2008 Yamaha TTR110-2006 Buell XB12SS-1993 Kawasaki KX500-1984 Honda XL600R/XR650L Hybrid-1984 Yamaha TT600L-1980 Honda CB750F-1977 Yamaha TT500
For sale--1996 Honda XR600R--
brucifer is offline   Reply With Quote
Old 05-25-2009, 08:52 PM   #269
XRider
Almost Lifelike
XRider's Avatar
Oddometer: 1,265
In regards to your timing, if you mean ignition timing that will take care of itself with the CDI control module. If you mean valve timing, the same TDC mark on the rotor when viewed through the inspection hole in the left side cover is all you need. That doesn't change no matter what cam is installed. The HRC cam has longer duration but nearly the same lift as the stock cam so with that in mind I'd set the lash at .004 intake and .005 exhaust. Part of the beauty of useing a cam made by Honda is its compatability with all the stock valve train components.
XR650R Plated Supermoto
XR628R Plated and highly modified
CR500R Still rips after all these beers
RZ350L Kenny Roberts Special
BMW 1150GS It's like ridding a Barkalounger
XRider is offline   Reply With Quote
Old 05-25-2009, 09:33 PM   #270
LilDirtRat
Oddometer: 256
Originally Posted by XRider
.....I'd set the lash at .004 intake and .005 exhaust....
Oddly enough, I checked this the other day & set the clearances to stock specs.. I still had a stalling issue when sitting at idle.. I then re-set the clearances to .005 and .006, and the stalling issue seems to have gone away completely.. If the rise is 'nearly' the same, I'm guessing it's just a bit taller and the little extra valve clearance is needed.. I suppose I'll never know exactly what the specs should be, but for now it seems to be doing better with a bit 'slappier' valves.. slappy valves are happy valves, right?
Times are GMT -7.   It's 04:08 PM.
