Old 06-27-2009, 07:53 PM   #346
mcma111
mcma111's Avatar
Oddometer: 11,901
Opps
Turn the engine COUNTER-CLOCKWISE. Do not go CLOCKWISE if you miss TDC.
Sorry for the screw-up. The steaks were on the BBQ and I was in a hurry to post.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 06-27-2009, 08:13 PM   #347
Dave JP
BRP Rider
Dave JP's Avatar
Oddometer: 372
Originally Posted by docious
Everything was looking good, but the right exhaust valve was being tricky as always. After fiddling around for a few minutes I accidentally turned the flywheel clockwise instead of counterclockwise and it made a click. Now it is making the click every time it make a full rotation.
Also, now the valves are only loose after it make the click, not when it is aligned with the T at TDC...
docious:
I don't know if this helps, but with the XR650R, if you mess up initially, the manual says to turn the flywheel counter-clockwise ~3 times before trying to line up "T" again.
I've got my toes crossed for ya!
Dave
Dave JP is offline   Reply With Quote
Old 06-28-2009, 05:27 PM   #348
mrfixit54016
Wisconsin Dual Sporter
mrfixit54016's Avatar
Oddometer: 634
Can you identify this piston?
Guys I need help identifying this piston. This is on my 1985 XR600 that I picked up used last fall. It ran, but 2nd gear is gone and it smoked bad. I expected to find a scored and abused OEM piston and jug, but to my suprise, it has a newer piston and a clean bore job, so I suspect that it just needs rings. I can see that it is first-size overbore by the .50 mm on the top.
So can anyone tell me what brand of piston this is so I can order the replacement rings? Or are all the brands the same when it comes to ring sizes. ( I would probably order Wiseco if that's the case )
Thanks for any assistance...
mrfixit54016 is offline   Reply With Quote
Old 06-28-2009, 05:57 PM   #349
mcma111
mcma111's Avatar
Oddometer: 11,901
Piston
That is a Wiseco +.5mm piston. It's an older part #. You can order directly from Wiseco. Just tell them the number on the piston and they will set you up with the correct rings. If I were you a light hone for the cylinder and some new valve guide seals. Wiseco has top end gasket sets also. Ask if thet sets include valve guide seals. One stop shopping!!
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 06-28-2009, 05:58 PM   #350
lewismedlock
lewismedlock's Avatar
Oddometer: 13,257
I just found this picture or my 600R when it was a few months old. I still have it.
lewismedlock is offline   Reply With Quote
Old 06-28-2009, 06:13 PM   #351
Zombie_Stomp
Aspiring human
Zombie_Stomp's Avatar
Oddometer: 2,231
Nice find, man. I love the looks of the XR600s, even more than the XL600s.
My guess is that it is a Wiseco. I put a wiseco in my XR600 engine and it looked like that except it had an indented top area, as it was a 9:1 compression ratio piston. Yours has a raised center and valve cutaways, so it is probably a wiseco 10.5 or 11:1. I don't have a photo of my wiseco so you could see the skirt pattern, but here are some photos of Gregster's Wiseco 11:1 from his rebuild thread on NBDSC:
Now here is another forged aftermarket piston called a Venolia. I'd say it's definitely not one of these. This one was for an XL600.
I also typed in Wiseco 4366P2 like it says on top of your piston, and I found a site that had a list of Wiseco pistons for sale, and 4366P2 ws listed as fitting the XR600, see below.
PISTON M09750 XR600R '85-01 3839XH
4366P2 $207.95
Looks like I answered it for you!
1982 4x4 longbed, a rolling daily driver work-in-progress...
1987 Yamaha XT600 2KF (German)
STOLEN: RED XL600 in Portland
I do heavy-duty textile repair, upholstery, and design/manufacture bags.
Zombie_Stomp is offline   Reply With Quote
Old 06-28-2009, 06:14 PM   #352
Zombie_Stomp
Aspiring human
Oddometer: 2,231
Damn you, Steve, beating me to the punch efforlessly!
Old 06-28-2009, 06:27 PM   #353
mcma111
mcma111's Avatar
Oddometer: 11,901
Punch Drunk
BTW, Gregster's piston is a 11to1 101mm slug.
Nice Venolia piston you have there. Even has my initials in it, SS
$207.95 is list. Same price as directly from Wiseco.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 06-28-2009, 06:42 PM   #354
mrfixit54016
Oddometer: 634
Wow! You guys jumped on that like the general just gave you the orders!
Thanks for the fast reply. Now will Steve or Zombie kindly fly to Wisconsin to help me install the new transmission gears. I have rebuilt top-ends before, but never had to split the cases.
I do have new valve seals for the head already, and a good transmission gear set from an XL600. This thing was just too complete to not rebuild.
Old 06-28-2009, 06:51 PM   #355
mcma111
mcma111's Avatar
Oddometer: 11,901
Fly In
Sure, You buy 'n I'll fly in. I'll even bring the tools.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 06-28-2009, 10:09 PM   #356
HeadTrauma
\_(ツ)_/
HeadTrauma's Avatar
Oddometer: 1,260
I am intrigued by that Venolia piston. I didn't know they ever made slugs for these bikes, although I suppose it could be a special order.
1995 XR628R -Lots of goodies...room for more.
"Another breakdown, suicidal shakedown,
Feels like I'm livin' on a chain gang."
HeadTrauma is offline   Reply With Quote
Old 06-28-2009, 10:09 PM   #357
mrfixit54016
Oddometer: 634
Engine ID
I have another question regarding that old 85 XR of mine. Is there any resource that allows you to tell what year your engine is using the serial number stamped on the engine case? I know that the 85 XR's had black engines, but this one is silver. It still has the dual carbs, so it is not newer than an 87, but I am wondering if it is an 87 engine, or did someone just do an awesome blasting job on the 85 engine to strip every fleck of paint off???
Old 06-28-2009, 10:15 PM   #358
HeadTrauma
\_(ツ)_/
HeadTrauma's Avatar
Oddometer: 1,260
Looks like it is probably an '87 engine. I don't see any evidence that it was ever painted or media blasted. The black and red engines commonly have overspray inside the cases, side covers, and head.
Old 06-29-2009, 12:34 AM   #359
Zombie_Stomp
Aspiring human
Oddometer: 2,231
Damn it. I just spent a long time writing a long post only to visit this site and find out that it is simply an '87 engine. I forgot about that magic year being the only Honda X-bike having a silver engine and dual carbs.
Zombie_Stomp screwed with this post 06-29-2009 at 12:41 AM
Old 06-29-2009, 08:41 AM   #360
Clif
GoEasyStepLightlyStayFree
Clif's Avatar
Oddometer: 354
## Question
Is the engine ## supposed to be the same as the frame ## ?
My frame is very close to the article that ZS put up but the engine is very diff.
Do XL ##'s vary much from XR's ? engine = PDO3E-5100xxx & frame is a proper JH2PE0409FK number
kt
Clif is offline   Reply With Quote
Times are GMT -7.   It's 12:56 AM.
